This page collects various useful utilities like the V-Ray Fur Styler, the mudbox2vrmesh, the vdenoise for Nuke and other tools related to V-Ray, which are not part of the official V-Ray installations.
VRMat migration utility tool
This command line tool allows batch migration of outdated XML-based .vismat or .vrmat files.
By default each file is updated to a version corresponding with V-Ray 5.1. This output version can be specified to accommodate for earlier V-Ray versions as well.
Note that legacy .vismat files that are not xml-based will not be migrated. If the contents of a .vismat file are not readable when opened with a text editor, it means the file cannot be migrated.
Usage:
vrmatmigrate [-h] [-v version] [-ow] [-gh] <paths>...
Command line options:
-h : Displays the tool's help info and a version lookup table
-v version : Upgrade the file(s) up to the specified version instead of the latest
-gh : Generates the color/float texture handler plugins
-ow : Overwrites the input file on save, instead of creating a copy with appended "_mig" suffix
-s : Specifies to search the subdirectories if the input path(s) are directories
<paths>... : One or more paths to files or directories to search for vismat/vrmat/vropt files
Example:
vrmatmigrate -ow -s "C:\%UserProfile%\Desktop\legacy_vismat_mtls"
Download version 1.0 (March 8th, 2021)
VRayFur styler
This modifier allows you to paint the initial and bend directions for VRayFur objects so that you can sort of "style" the appearance of VRayFur.
Download for 3ds Max 2018-2023: VRayFurStyler_VRay6.zip
For 3ds Max versions that use the Plugin Package Format (2022 and later) the .dlo file needs to be added to C:\ProgramData\Autodesk\ApplicationPlugins\VRay3ds Max20nn\plugins, and the XML must be manually edited so that it includes the new DLO in the list here: C:\ProgramData\Autodesk\ApplicationPlugins\VRay3dsMax20nn\PackageContents.xml (where nn stands for the number of V-Ray for 3ds Max version).
Example:
<ComponentEntry AppName="VRayFurStyler" Version="5.20.23" ModuleName="./plugins/vrayfurstyler2022.dlo" />
Mudbox to .vrmesh exporter
This is a Mudbox exporter plugin that allows the user to export .vrmesh files directly from Mudbox. The exporter allows to choose a subdivision level to use as viewport preview, and can store painted color maps as vertex colors for use in shaders.
Download for Mudbox 2015-2016: mudbox2vrmesh.zip
VRayDenoiser plugin for Nuke
A freeware Nuke plugin that implements the V-Ray denoiser as a Nuke node.
BY DOWNLOADING THIS CONTENT YOU AGREE TO BE BOUND BY THE TERMS OF THE EULA ATTACHED
Download for Nuke 8-13.2 for Windows and Linux: vdenoise_nuke.zip
For more information on how to use the plugin, visit the V-Ray Denoiser | VRayDenoiser page.
V-Ray Lens Effects plugin for Nuke
A freeware Nuke plugin that implements the V-Ray Lens Effects as a Nuke node.
Download for Nuke 11.0-13.2 for Windows and Linux: lenseffects_nuke.zip
maketx 1.4.12
A 64-bit recompile of the maketx tool from the OpenImageIO library. Can be used to convert common texture formats to tiled .tx or .exr files for use with V-Ray.
Download version 1.4.12, 64-bit: maketx-1.4.12.zip
blendimg
This little program can be used to blend multiple images together. Originally it was designed to blend images produced by the photon mapping engine of V-Ray when you need to shoot an enourmous amount of photons. It can also be used to sort of render progressive path tracing in distributed rendering mode, where you blend the PPT images produced from several different machines.
Download: blendimg.zip
Bercon Metaballs 1.14
This is a recompile for V-Ray 2.0 of the original open-source plugin Bercon Metaballs 1.14 by Jerry Ylilammi; includes full source code under Apache License 2.0.
Download for 3ds Max 9-2013 for V-Ray 2.x: bercon_metaballs_vray23.zip
Bercon Maps
This is a recompile for 3ds Max 2020 of the original open-source plugins Bercon Map by Jerry Ylilammi; includes full source code under Apache License 2.0.
Download for 3ds Max 2013-2020: BerconMaps_3ds_Max_2013-2020
Note that 3ds Max 2021 can work with the BerconMaps file for 3ds Max 2020. The BerconMaps file for 3ds Max 2020 must be copied in the Plugins directory of 3ds Max 2021. There is no need to rename the file.
vrscene dehexer
This tool can be used to un-hex vrscene files written with hex-encoded transform and/or mesh data. The resulting un-hexed vrscene is written out separately. Another use for the tool is to compare vrscenes and return a status (false) if they are different.
Usage: Run the executable from a command prompt.
- to un-hex a vrscene, use the -u flag. Example: vrscene_dehexer.exe -u source.vrscene result.vrscene.
- to compare vrscenes, use the -d flag. Example: vrscene_dehexer.exe -d scene1.vrscene scene2.vrscene.
- run the program without arguments to print a help message.
Download for Windows: vrscene_dehexer.zip
