« Previous Version 2 Next »
This page provides information about the Frame Info tab of the V-Ray Volumetric Grid.
The Frame Info tab allows you to quickly check the size, dimensions, and contents of the loaded cache file for the current frame.
Container Dimensions – If a file is successfully loaded, shows the size of the bounding box of the cached contents for the current frame, in scene units. Prints [No Frame Loaded] otherwise. This parameter ignores any transformations (such as Scaling) applied to the transform node.
Cache File Content – If a file is successfully loaded, displays information regarding the channels present in the cache for the current frame. The container's size, as well as the total number of cells/voxels, is printed at the top. For each individual channel (such as Velocity, or Smoke), a single line consisting of the name and Min / Max range for that channel is also displayed.
