Version 1 Next »
This page provides information about the User Integer node in V-Ray for Cinema 4D.
The User Integer node texture allows the user to read and return a single integer value from the currently shaded object as a result. This can be useful if the same material or texture is applied to several objects in the scene, but you want to control some of its properties with user-defined properties.
Properties
User Attribute – Specifies the name of the user attribute that is looked up and returned from this utility texture.
Default value – Specifies the value to return if the user attribute is not found on the shaded object.
