Version 1 Next »
This page provides information about the Override Attribute in V-Ray for SketchUp.
An Add Attribute button is provided for some V-Ray materials. Select additional attributes to add up to the appearance of the material. For more information see the Add Attributes on the  How to Work with Materials page.
Shadows – The material that is used when a shadow ray hits the surface.
Reflection – The material that is used when a reflection ray hits the surface.
Refraction– The material that is used when a refraction ray hits the surface.
GI – The material that is used when a GI ray hits the surface.
Environment – The texture that will be used instead of the scene environment maps.
SketchUp2023_VRay6.2_Material_Attributes_Override
