©BBB3viz
« Previous Version 16 Current »
This page provides information on the Bump Material.
The VRayBumpMtl gives the ability to add bump map and normal map effects when using any material.
Simply connect a material into the VRayBumpMtl node to add additional bump or normal map functionality. Stacking multiple VRayBumpMtl nodes together can create a more complex surface material by allowing the use of several bump and or normal maps together easily.
© Milo Liao
Base material – Allows you to select the base material to which the bump effect is added.
Bump map – Specifies the bump/normal map that is going to be used.
Bump amount – Specifies a multiplier for the bump effect.
