© Taichi Kobayashi
« Previous Version 10 Next »
This page contains information about the V-Ray TexLut node.
V-Ray TexLut is a V-Ray utility node that allows you to apply a look up table (a .cube file) to any texture for managing resulting colors.
In the example shown, a LC3DL_Fuji3510_log2hd_ConstLmap.cube LUT file has been loaded to define the texture's look.
UI Path: ||mat Network|| > V-Ray > Texture: File > V-Ray LUT
Base Map – A slot to load the map on which the LUT is going to be applied.
LUT File – Specifies the location of the look up table.
Convert to Log Space before applying LUT – Converts the Base Map to a logarithmic color space before applying the look up table.
