©Anton Podvalny
  • User Guide
  • V-Ray Application SDK
    • I. Introduction
    • II. Basic Rendering
    • III. Render Modes
    • IV. Common Events
    • V. Production Events
    • VI. RT Events
    • VII. V-Ray Images
    • VIII. Render Elements
    • IX. Plugins
    • X. Property Types
    • XI. Animations
    • XII. V-Ray Server
    • XIII. Distributed Rendering
    • XIV. Setup
Version 1 Next »
User Guide
I. Introduction
The V-Ray Application SDK allows third-party integrators to initiate and control a rendering process that makes use of the V-Ray engine. It provides a high-level API that enables users to load scenes, render them in a host process as well as in distributed mode and also manipulate the scene objects known as V-Ray plugins. The scenes files that the V-Ray Application SDK works with are ".vrscene" files which are exported from 3D development environments such as Autodesk 3ds Max, Maya etc. or by any other V-Ray integration, such as your own. Rendering can also be done directly from memory without going through a scene file.
II. Basic Rendering
The V-Ray Application SDK exposes a specially designed VRayRenderer class that serves as the entry point for the initiation and control of any rendering process. The class defines high-level methods for loading and rendering a V-Ray scene that hide the inner complexities of the V-Ray engine and yet provide its powerful capabilities.
The basic workflow for starting a render process usually consists of the following steps:
  • Instantiating the configurable VRayRenderer class
  • Either of (or even a combination of):
    • Loading a scene by specifying a path to a .vrscene file (the V-Ray native format for serializing scenes)
    • Creating new instances of V-Ray render plugins to translate your native scene description to V-Ray and setting their parameters
  • Invoking the method for rendering
  • Waiting for the image to become available
  • Cleaning up memory resources by closing the VRayRenderer
All language implementations of the VRayRenderer class offer a method without arguments (render()) that is used to start the rendering of the currently loaded scene. The method is a non-blocking call which internally runs the V-Ray engine in a separate thread. Thus the rendering can conveniently take place as a background process without the need to use language-specific tools for creating threads.
The VRayRenderer class gives access to the current state of the rendered image at any point in time. Irrespective of whether the render process has finished or not, an image can be extracted to track the progress of the rendering. All language implementations expose a method that returns a specialized image class whose purpose is to capture the image data at the point of the image request. The class can be used for direct display or to save the rendered image to a file in one of several supported popular compression formats.
import vray
with vray.VRayRenderer() as renderer:
    renderer.load('./car.vrscene')
    renderer.start()
    renderer.waitForImageReady(6000)
    image = renderer.getImage()
    image.save('car.png')
#include "vraysdk.hpp"
using namespace VRay;
VRayInit init;
VRayRenderer renderer;
renderer.load("./car.vrscene");
renderer.startSync();
renderer.waitForImageReady(6000);
VRayImage* image = renderer.getImage();
image->saveToPngFile("car.png");
delete image;
using VRay;
using (VRayRenderer renderer = new VRayRenderer())
    renderer.Load("./car.vrscene");
    renderer.Start();
    renderer.WaitForImageReady(6000);
    VRayImage image = renderer.GetImage();
    image.SaveToPNG("car.png");
import com.chaosgroup.vray.*;
VRayRenderer renderer = null;
try {
    renderer = new VRayRenderer();
    renderer.render();
    VRayImage image = renderer.getImage();
    image.saveToPNG("car.png");
} catch (VRayException e) {
    System.err.println(e.getMessage());
} finally {
    VRayRenderer.close(renderer);
var vray = require('../vray');
var renderer = vray.VRayRenderer();
renderer.load('./car.vrscene', function(err) {
    if (err) throw err;
    renderer.render();
    renderer.waitForImageReady(6000, function() {
        var image = renderer.getImage();
        image.save('car.png', function() {
            renderer.close();
Figure II.1
III. Render Modes
The V-Ray Application SDK offers the ability to run the V-Ray engine in three distinct render modes - Production, RT CPU and RT GPU. Production mode is suitable for obtaining the final desired image after the scene has been carefully configured as the render process can take a lot of time before a meaningful overview of the whole image is available. The strength of the RT modes on the other hand lies in the fast image preview and progressive image quality improvement which makes them the perfect choice for experimenting with scene settings and modifying content and receiving fast render feedback. The RT engine is supported in two flavors - CPU and GPU. The former utilizes the CPU resources while the latter takes advantage of the graphics card computing power. The GPU rendering type is in turn subdivided into two modes - OpenCL and CUDA (nVidia only) depending on the technology that is used with the GPU.
The type of the rendering initiated with the VRayRenderer class can be chosen easily through an instance of the specialized options class that is passed as an argument to the VRayRenderer constructor. The render mode is determined by the provided options upon instantiating the VRayRenderer. The default render mode for the VRayRenderer class is RT CPU and instantiating the VRayRenderer class without specifying any options is equivalent to passing to the VRayRenderer constructor an instance of the default options. The render mode can be changed between renders to avoid having to re-create or re-load the scene. This allows you to work interactively on a scene with V-Ray RT and then to switch to production mode for final rendering without any overhead.
import vray
with vray.VRayRenderer(renderMode='production') as renderer:
    renderer.start()
VRayInit init;
RendererOptions options;
options.renderMode = RendererOptions::RENDER_MODE_PRODUCTION;
VRayRenderer renderer(options);
delete image;
RendererOptions options = new RendererOptions();
options.RenderMode = RenderMode.Production;
using (VRayRenderer renderer = new VRayRenderer(options))
    renderer.Start();
try {
    options.setRenderMode(RenderMode.PRODUCTION);
    renderer = new VRayRenderer(options);
    renderer.render();
} finally {
var renderer = vray.VRayRenderer({
    renderMode : 'production'
    if (err) throw err;
    renderer.render();
            renderer.close();
Figure III.1
IV. Common Events
During the rendering process that runs in the background in a separate thread a number of events are emitted which are available to AppSDK users. You can subscribe to the rendering events with the help of the main VRayRenderer class.
The V-Ray Application SDK provides the means for attaching callbacks that execute custom client logic when an event occurs. The code of the callbacks is executed in a separate thread that is different from the main V-Ray rendering thread. This design allows the V-Ray rendering process to remain fast without additional overhead and ensures that slow operations in client callback code will not affect the total rendering time.
The events can be broadly classified into three types: events common for all render modes, events specific to Production mode and events specific to RT mode. This section covers the events that are emitted regardless of the used render mode.
The common render events occur when:
  • The image rendering starts and stops
  • V-Ray outputs text messages prior to and during rendering
  • V-Ray switches the current task (i.e. loading, rendering) and reports progress percentage
Start Event
The start event is the first event to be emitted after the render process has been started with the VRayRenderer render() method. The V-Ray Application SDK enables API users to attach a callback without arguments whose code is executed immediately after the start event is emitted.
import vray
def onRenderStart(renderer):
    print 'The V-Ray render process has started!'
    renderer.setOnRenderStart(onRenderStart)
    renderer.start()
void onRenderStart(VRayRenderer& renderer, void* userData)
    printf("The V-Ray render process has started!\n");
VRayInit init;
renderer.setOnRenderStart(onRenderStart);
    renderer.RenderStarted += new EventHandler((source, e) =>
        Console.WriteLine("The V-Ray render process has started!");
    renderer.Start();
try {
    renderer.setOnRenderStart(new OnRenderStartListener() {
        @Override
        public void onRenderStart() {
            System.out.println("The V-Ray render process has started!");
    renderer.render();
} finally {
renderer.on('start', function() {
    console.log('The V-Ray render process has started!');
    if (err) throw err;
    renderer.render();
    renderer.waitForImageReady(6000, function() {});
Figure IV.1
Log Message Event
Output messages are produced by the V-Ray engine during scene loading and rendering and they can be captured by subscribing to the special log event. The callback data that becomes available when a message is logged is the text of the message and the log level type (info, warning or error).
import vray
def onDumpMessage(renderer, message, level):
    print '[{0}] {1}'.format(level, message)
    renderer.setOnDumpMessage(onDumpMessage)
    renderer.start()
void onLogMessage(VRayRenderer& renderer, const char* message, int level, void* userData)
    printf("[%d] %s\n", level, message);
VRayInit init;
renderer.setOnDumpMessage(onLogMessage);
    renderer.MessageLogged += new EventHandler<MessageEventArgs>((source, e) =>
        Console.WriteLine("[{0}] {1}", e.LogLevel.Type, e.Message);
    renderer.Start();
try {
    renderer.setOnLogListener(new OnLogListener() {
        @Override
        public void onLogMessage(String message, LogLevel logLevel) {
            System.out.format("[%s] %s\n", logLevel.getType(), message);
    renderer.render();
} finally {
renderer.on('dumpMessage', function(message, level) {
    console.log('[%d] %s', level, message);
    if (err) throw err;
    renderer.render();
Figure IV.2
Progress Event
Progress events are emitted whenever the current task changes and also when the amount of work done increases. They include a short message with the current task name and two numbers for the total amount of work to do and the work that is already complete.
Image Ready Event
When the rendering process finishes an image ready event is emitted to notify subscribers that the image result of the process can be obtained. The purpose of the event is to mark the end of the rendering process so that API clients are aware of the time after which no more images are produced. Note that this is also emitted when the rendering is aborted, so you can still count on it to perform your cleanup.
import vray
def onImageReady(renderer):
    renderer.setOnImageReady(onImageReady)
    renderer.start()
    renderer.waitForImageReady()
void onImageReady(VRayRenderer& renderer, void* userData)
    delete image;
VRayInit init;
renderer.setOnImageReady(onImageReady);
renderer.waitForImageReady();
    renderer.ImageReady += new EventHandler((source, e) =>
    renderer.Start();
    renderer.WaitForImageReady();
try {
    final VRayRenderer rendererRef = renderer;
    renderer.setOnImageReady(new OnImageReadyListener() {
        @Override
        public void onImageReady() {
            VRayImage image = rendererRef.getImage();
    renderer.render();
} finally {
renderer.on('imageReady', function() {
        renderer.close();
    if (err) throw err;
    renderer.render();
Figure IV.3
There are two types of image sampling in Production mode - "bucket" rendering and progressive rendering. Bucket rendering splits the image into small rectangular sub-images, each processed independently by a different local CPU thread or network server (see the Distributed Rendering section). The sub-images are only returned when completely ready. Progressive rendering works the same way as in RT mode - the whole image is sampled and images are returned for each sampling pass, reducing noise with each pass. This section covers the events which are specific to Production bucket rendering only. The progressive mode emits the image event described in the RT Events section further below.
There are two main phases in Production bucket rendering - assigning a bucket to a render host (or local thread) and rendering the assigned region of the image. This is why there are two events that are raised for each bucket of the image - initializing a bucket and receiving the image result. Users of the API can subscribe to the events via the main VRayRenderer class.
In Production mode the image is perceived as a matrix of buckets each of which holds a part of the final image. The bucket is uniquely identified by the coordinates of its top left corner and the width and height of its rectangular region. The top left corner of the whole image has coordinates (0, 0). The mentioned bucket data is passed as an argument to the callbacks attached to the bucket init and bucket ready events. Consequently, the published event data during the rendering process provides the whole information needed to reconstruct the final image from its constituent parts (buckets).
Bucket Init Event
The bucket init event is raised when the main V-Ray thread assigns a bucket to a network render host or local thread. The callback data that is provided for this event is the bucket size and coordinates as well as the name of the render host (if any) as it appears on the network.
import vray
def onBucketInit(renderer, bucket):
    print 'Starting bucket:'
    print '\t x: ', bucket.x
    print '\t y: ', bucket.y
    print '\t width: ', bucket.width
    print '\t height:', bucket.height
    print '\t host:', bucket.host
    renderer.setOnBucketInit(onBucketInit)
    renderer.start()
void onBucketInit(VRayRenderer& renderer, int x, int y, int width, int height, const char* host, void* userData)
    printf("Starting bucket:\n");
    printf("\t x: %d\n", x);
    printf("\t y: %d\n", y);
    printf("\t width: %d\n", width);
    printf("\t height: %d\n", height);
    printf("\t host: %s\n", host);
VRayInit init;
renderer.setOnBucketInit(onBucketInit);
    renderer.BucketInit += new EventHandler<BucketRegionEventArgs>((source, e) =>
        Console.WriteLine("Starting bucket:");
        Console.WriteLine("\t x:" + e.X);
        Console.WriteLine("\t y:" + e.Y);
        Console.WriteLine("\t width:" + e.Width);
        Console.WriteLine("\t height:" + e.Height);
        Console.WriteLine("\t host:" + e.Host);
    renderer.Start();
try {
    renderer.setOnBucketInit(new OnBucketInitListener() {
        @Override
        public void onBucket(BucketRegion bucket) {
            System.out.println("Starting bucket:");
            System.out.println("\t x:" + bucket.getX());
            System.out.println("\t y:" + bucket.getY());
            System.out.println("\t width:" + bucket.getWidth());
            System.out.println("\t height:" + bucket.getHeight());
            System.out.println("\t host:" + bucket.getHost());
    renderer.render();
} finally {
renderer.on('bucketInit', function(region) {
    console.log('Starting bucket:');
    console.log('\t x:' + region.x);
    console.log('\t y:' + region.y);
    console.log('\t width:' + region.width);
    console.log('\t height:' + region.height);
    console.log('\t host:' + region.host);
    if (err) throw err;
    renderer.render();
    renderer.waitForImageReady(function() {
        renderer.close();
Figure V.1
Bucket Ready Event
The bucket ready event is raised when the render host that has been assigned a bucket has finished rendering the part of the image and has sent its result to the main V-Ray thread. The returned callback data for the event contains the size and coordinates of the region, the render host name and the produced image.
import vray
def onBucketReady(renderer, bucket):
    print 'Bucket ready:'
    fileName = 'car-{0}-{1}.png'.format(bucket.x, bucket.y)
    bucket.save(fileName)
    renderer.setOnBucketReady(onBucketReady)
    renderer.start()
void onBucketReadyCallback(VRayRenderer& renderer, int x, int y, const char* host, VRayImage* image, void* userData)
    printf("Bucket ready:\n");
    printf("\t width: %d\n", image->getWidth());
    printf("\t height: %d\n", image->getHeight());
    char fileName[64];
    sprintf(fileName, "car-%d-%d.png", x, y);
    image->saveToPngFile(fileName);
VRayInit init;
renderer.setOnBucketReady(onBucketReadyCallback);
    renderer.BucketReady += new EventHandler<BucketImageEventArgs>((source, e) =>
        Console.WriteLine("Bucket ready:");
        VRayImage image = e.Image;
        image.SaveToPNG(string.Format("car-{0}-{1}.png", e.X, e.Y));
        image.Dispose();
    renderer.Start();
try {
    renderer.setOnBucketListener(new OnBucketListener() {
        @Override
        public void onBucket(BucketImage bucket) {
            System.out.println("Bucket ready:");
            VRayImage image = bucket.getImage();
            image.saveToPNG(String.format("car-%d-%d.png",
                    bucket.getX(), bucket.getY()));
            image.close();
    renderer.render();
} finally {
renderer.on('bucketReady', function(bucket) {
    console.log('Bucket ready:');
    console.log('\t x:' + bucket.x);
    console.log('\t y:' + bucket.y);
    console.log('\t width:' + bucket.width);
    console.log('\t height:' + bucket.height);
    console.log('\t host:' + bucket.host);
    var fileName = 'car-' + bucket.x + '-' + bucket.y + '.png'
    bucket.save(fileName, function() {
        bucket.close();
    if (err) throw err;
    renderer.render();
        renderer.close();
Figure V.2
VI. RT Events
One of the render modes provided by the V-Ray Application SDK is RT. Its purpose is to allow users to receive fast feedback for the scene they have configured. Noisy images are quickly available when the RT render process starts. As this process continues, it returns new intermediate images with progressively better quality. The V-Ray Application SDK gives access to those intermediate images by publishing image data when the RT engine event for an updated image is emitted. This event is also emitted in production mode when the image sampler is set to progressive mode, not buckets.
import vray
counter = 0
def onImageUpdated(renderer, image):
    global counter
    counter += 1
    fileName = 'car-{0}.jpeg'.format(counter)
    image.save(fileName)
with vray.VRayRenderer(renderMode='rtCPU') as renderer:
    renderer.setOnRtImageUpdated(onImageUpdated)
    renderer.start()
int counter = 0;
void onRTImageUpdated(VRayRenderer& renderer, VRayImage* image, void* userData)
    char fileName[64];
    sprintf(fileName, "car-%d.jpeg", ++counter);
    image->saveToJpegFile(fileName);
VRayInit init;
options.renderMode = RendererOptions::RENDER_MODE_RT_CPU;
renderer.setOnRTImageUpdated(onRTImageUpdated);
options.RenderMode = RenderMode.RT_CPU;
    int counter = 0;
    renderer.RTImageUpdated += new EventHandler<VRayImageEventArgs>((source, e) =>
        string fileName = string.Format("car-{0}.jpeg", ++counter);
        e.Image.SaveToJPEG(fileName);
        e.Image.Dispose();
    renderer.Start();
try {
    options.setRenderMode(RenderMode.RT_CPU);
    renderer.setOnRTImageUpdated(new OnRTImageUpdatedListener() {
        private int counter = 0;
        @Override
        public void onImageUpdated(VRayImage image) {
            String fileName = String.format("car-%s.jpeg", ++counter);
            image.saveToJPEG(fileName);
            image.close();
    renderer.render();
} finally {
    renderMode : 'rtCPU'
var counter = 0;
renderer.on('rtImageUpdated', function(image) {
    var fileName = 'car-' + (++counter) + '.jpeg';
    image.save(fileName, function() {
        image.close();
    if (err) throw err;
    renderer.render();
        renderer.close();
Figure VI.1
VII. V-Ray Images
The VRayImage class provides access to the images rendered by V-Ray. It is used by the VRayRenderer, as well as by some of the arguments of the callbacks invoked when an event occurs. The VRayImage class is specialized to provide utility functions for manipulating the retrieved binary image data. The binary data is in full 32-bit float format and can be accessed directly, but there are convenience methods that perform compression in several of the most popular 8-bit formats - BMP, JPEG, PNG and WebP. Saving EXR and other high dynamic range formats is also possible, but not discussed here.
The methods that are exposed by the VRayImage class come in two flavors. The first group of the methods returns directly the bytes of the compressed image, while the second group compresses the image and saves it to a file.
import vray
    renderer.start()
    data = image.compress('png')
    with open('car.png', 'wb') as outStream:
        outStream.write(data)
VRayInit init;
Png png = image->toPng();
ofstream outputStream("car.png", ofstream::binary);
outputStream.write((char*) png.getBuf(), png.getLen());
outputStream.close();
delete image;
    renderer.Start();
    byte[] data = image.ToPNG();
    using(FileStream outStream = new FileStream("car.png", FileMode.Create, FileAccess.Write))
        outStream.Write(data, 0, data.Length);
FileOutputStream outStream = null;
try {
    renderer.render();
    byte[] data = image.toPNG();
    outStream = new FileOutputStream("car.png");
    outStream.write(data);
} catch (IOException e) {
} finally {
    if (outStream != null) {
        try {
            outStream.close();
var fs = require('fs');
    if (err) throw err;
    renderer.render();
        image.compress('png', function(err, buffer) {
            fs.writeFile('car.png', buffer, function() {
                renderer.close();
Figure VII.1
All instances of the VRayImage class must be closed so that memory resources held by the instance are released. It is recommended to always free the resources (close the image) when you have finished working with the image. However, the platforms that support a garbage collection mechanism will take care to free the internally held resources in the event that the user does not close the retrieved image.
Downscaling
In addition to the utility methods for compression, the VRayImage class supports downscale operations that resize the retrieved image to a smaller one. The result of the downscale operations is another VRayImage instance which has access to the full functionality of the utility methods of the class.
import vray
    renderer.start()
    downscaled = image.downscale(260, 180)
    downscaled.save('car.png')
VRayInit init;
LocalVRayImage image = renderer.getImage();
LocalVRayImage downscaled = image->downscale(260, 180);
downscaled->saveToPngFile("car.png");
    renderer.Start();
    using (VRayImage image = renderer.GetImage())
        using (VRayImage downscaled = image.GetDownscaled(260, 180))
            downscaled.SaveToPNG("car.png");
try {
    renderer.render();
    VRayImage downscaled = image.getDownscaled(260, 180);
    downscaled.saveToPNG("car.png");
    downscaled.close();
    image.close();
} finally {
renderer.load('./car.vrscene', function (err) {
    if (err) throw err;
    renderer.render();
    renderer.waitForImageReady(6000, function () {
        image.downscale(260, 180, function(downscaled) {
            downscaled.save('car.png', function() {
                downscaled.close();  // Not mandatory, can be left to the garbage collector
                image.close();       // Not mandatory, can be left to the garbage collector
                renderer.close();
Figure VII.2
Changing the Image Size
The size of the rendered image can be controlled with the help of the renderer options passed to the constructor of the VRayRenderer class. The width and height of the target image can be changed before instantiating a renderer, and therefore all images rendered by it will have the same dimensions. If the image width and height are not specified (i.e. by default they remain 0) then the size of the rendered image is determined on a scene-by-scene basis by the concrete settings exported in the ".vrscene" file of the currently loaded scene.
import vray
    renderer = vray.VRayRenderer(imageWidth=640, imageHeight=360)
    renderer.start()
VRayInit init;
options.imageWidth = 640;
options.imageHeight = 360;
options.ImageWidth = 640;
options.ImageHeight = 360;
    renderer.Start();
try {
    options.setImageWidth(640);
    options.setImageHeight(360);
    renderer.render();
} finally {
    imageWidth : 640,
    imageHeight : 360
    if (err) throw err;
    renderer.render();
            image.close();
            renderer.close();
Figure VII.3
V-Ray Render Elements (also known as AOVs) are images containing various types of render data encoded as 3-element color, single floats or integers. Some of them are Z-depth, surface normal, UV coordinates, velocity, lighting, reflections etc. Each V-Ray scene may contain an arbitrary number of render elements (also called channels). Each channel is enabled by a unique plugin, except for the RGB and Alpha channels, which are always enabled.
To access the render elements in the current scene, use the VRayRenderer instance where the scene is loaded. Each render element's data can be taken either as a VRayImage, or as raw data (as byte, integer, or float buffers). Optionally, provide a sub-region of interest to the APIs to get that part of the data.
import vray
# Render elements are only available in production mode!
    renderer.start()
    # Render elements are available when the first bucket region is ready
    # Here, we simply wait for the entire image to be completed before we access
    # the render elements
    # Access render elements via the VRayRenderer instance
    renderElements = renderer.renderElements.getAll()
    # Always good to check for null (i.e. non-production mode)
    if not renderElements:
        exit()
    # List all available render elements and process each one
    for r in renderElements:
        print '{0}, Format({1}), PixelFormat({2})'.format(r.name, r.binaryFormat, r.defaultPixelFormat)
        # Output render element's data as an image
        # Optionally, specify an image sub-region, or leave blank to get the
        # entire image
        img = r.getImage()
        img.save(r.name + '.png', preserveAlpha=True)
        # Similar to the image output, get the raw bytes
        # Again, a sub-region can be specified, or the entire data can be
        # obtained if left blank
        rawData = r.getData()
        # Do something with rawData...
// Init V-Ray
VRayInit init("VRaySDKLibrary.dll", true);
// Set up rendering options
options.imageWidth = 320;
options.imageHeight = 200;
// Do some rendering
renderer.load("car.vrscene");
// Render elements are available when the first bucket region is ready
// Here, we simply wait for the entire image to be completed before we access the render elements
// Access render elements via the VRayRenderer instance
RenderElements renderElements = renderer.getRenderElements();
int reCount = renderElements.getCount();
// List all available render elements and process each one
for (int i = 0; i < reCount; i++) {
    RenderElement re = renderElements[i];
    printf("%d. %s, Format(%d), PixelFormat(%d)\n", re.getIndex(), re.getName().c_str(),
        re.getBinaryFormat(), re.getDefaultPixelFormat());
    // Output render element's data as an image
    // Optionally, specify an image sub-region, or leave blank to get the entire image
    LocalVRayImage img = re.getImage();
    img->saveToPngFile(re.getName() + ".png");
    // Similar to the image output, get the raw bytes
    // Again, a sub-region can be specified, or the entire data can be obtained if left blank
    void* data = NULL;
    if (int dataSize = re.getData(&data)) {
        ofstream datFile (re.getName() + ".dat", ios::out | ios::binary);
        datFile.write(reinterpret_cast<unsigned char*>(data), dataSize);
        datFile.close();
        RenderElement::releaseData(data);
options.RenderMode = RenderMode.Production; // Render elements are only available in production mode!
using (VRayRenderer vr = new VRayRenderer(options))
    vr.Load("./car.vrscene");
    RenderElements re = vr.RenderElements;
    // Always good to check for null (i.e. non-production mode)
    if (re == null)
        return;
    // Add render element for normals; it can be as well present in the scene
    re.New(RenderElementType.NORMALS, "NormalsChannel", "Normals Channel");
    vr.Start();
    // Render elements are available as plugins which are part of the scene and can be obtained in both production and RT mode
    // Only "RGB" and "Alpha" are implicit
    // Here, we wait for the entire image to be completed before we access the render elements
    vr.WaitForImageReady();
    // All Get* methods on the render elements may return nulls if data is not available
    var allRenderElements = re.GetAll();
    if (allRenderElements == null)
        return;
    foreach (RenderElement r in allRenderElements)
        Console.WriteLine("{0}, Format({1}), PixelFormat({2})\n", r.Name, r.Format, r.PixelFormat);
        VRayImage img = r.GetImage();
        img.SaveToPNG(true, r.Name + ".png");
        byte[] rawData = r.GetData();
        // Do something with rawData...
options.setRenderMode(RenderMode.PRODUCTION); // Render elements are only available in production mode!
try (VRayRenderer vr = new VRayRenderer(options)) {
    vr.load("./car.vrscene");
    vr.render();
    vr.waitForImageReady();
    RenderElements re = vr.getRenderElements();
    if (re == null) {
        return;
    // All get* methods on the render elements may return nulls if data is not available
    LinkedList<RenderElement> allRenderElements = re.getAll();
    if (allRenderElements == null) {
        return;
    for (RenderElement r : allRenderElements) {
        System.out.printf("%d. %s, Format(%s), PixelFormat(%s)\n", r.getIndex(), r.getName(),
                r.getFormat().toString(), r.getPixelFormat().toString());
        VRayImage img = r.getImage(/*new RectRegion(20, 100, 200, 100)*/);
        img.saveToPNG(r.getName() + ".png", true);
        byte[] rawData = r.getData(new RectRegion(20, 100, 200, 100));
    e.printStackTrace();
var vray = require('./vray.js');
var r = vray.VRayRenderer({ renderMode : "Production", imageWidth: 320, imageHeight: 200 });
r.load('./car_p.vrscene', function(err) {
    if (err) throw err;
    r.render();
        if (r.renderElements == null) {
            r.close();
            return;
        var renderElements = r.renderElements.getAll();
        for (var i in renderElements) {
            var renderElement = renderElements[i];
            console.log(i + ". " + renderElement.name
                + ", Format(" + renderElement.binaryFormat
                + "), PixelFormat(" + renderElement.pixelFormat + ")");
            var reImage = renderElement.getImage();
            reImage.saveSync(renderElement.name + ".png");
            var rawData = renderElement.getData();
            console.log(rawData);
        r.close();
Figure VIII.1
IX. Plugins
The plugins are the objects that specify the lights, geometry, materials or settings that define the 3D scene. Each V-Ray scene consists of a set of plugins instances. The V-Ray Application SDK exposes methods in the main VRayRenderer class that can be used to create plugin instances or list the existing ones in the scene.
Plugin objects can be retrieved by name. Once the user has obtained a Plugin instance its property (a.k.a. parameter) values can be viewed or set to affect the rendered image. The properties of the plugin are identified by their name which is the same across all instances of the same type. In RT mode the changes to the Plugin property values are usually applied immediately during rendering and changes become visible almost instantly, but the image sampling is reset and you get some noisy images initially. In Production mode changes to Plugin property values take effect if they are applied before the rendering process starts. The following example demonstrates how the transform for the render view (camera) in a scene can be changed with the V-Ray Application SDK.
import vray
with vray.VRayRenderer(showFrameBuffer=True) as renderer:
    renderer.start()
    # find the RenderView plugin in the scene
    renderView = renderer.plugins.renderView
    # change the transform value
    newTransform = renderView.transform
    newOffset = newTransform.offset
    newOffset.x = -170
    newOffset.y = 120
    renderView.transform = newTransform
VRayInit init;
options.showFrameBuffer = true;
// find the RenderView plugin in the scene
RenderView renderView = renderer.getPlugin<RenderView>("renderView");
// change the transform value
Transform newTransform = renderView.getTransform("transform");
Vector& newOffset = newTransform.offset;
newOffset.set(-170, 120, newOffset.z);
renderView.set_transform(newTransform);
options.IsFrameBufferShown = true;
    renderer.Start();
    RenderView renderView = renderer.GetPlugin<RenderView>("renderView");
    // change the trasnform value
    Transform newTransform = renderView.Transform;
    newTransform.Offset.Set(new float[] { -170, 120, newTransform.Offset.Z });
    renderView.Transform = newTransform;
try {
    options.setShowFrameBuffer(true);
    renderer.render();
    Plugin renderView = renderer.getPlugin("renderView");
    Vector newOffset = newTransform.getOffset();
    newOffset.set(new float[] { -170, 120, newOffset.getZ() });
    renderView.setValue("transform", newTransform);
} finally {
    showFrameBuffer : true
    if (err) throw err;
    renderer.render();
    var renderView = renderer.plugins.renderView;
    var newTransform = renderView.transform;
    var newOffset = newTransform.offset;
    newOffset.x = -170;
    newOffset.y = 120;
    renderView.transform = newTransform;
        renderer.close();
Figure IX.1
The call to a method that retrieves the value for a Plugin property always returns a copy of the internal value stored in the local V-Ray engine. In order to change the Plugin property value so that it affects the rendered image the specialized setter method from the Plugin class should be called. Simply modifying the value returned by a getter will not lead to changes in the scene as it is a copy, not a reference.
Adding and removing plugins
Besides changing the values of the properties of existing Plugins, Plugins can also be created and removed dynamically with the V-Ray Application SDK. The next example demonstrates how a new light can be created and added to the scene.
import vray
    renderer.load('./softShadows.vrscene')
    # create a new light plugin
    lightOmni = renderer.classes.LightOmni('LightOmniBlue')
    lightOmni.color = 'Color(0, 0, 6000)'
    lightOmni.shadowBias = 0.2
    lightOmni.decay = 2.0
    lightOmni.shadowRadius = 40.0
    lightOmni.transform = vray.Transform(vray.Matrix(vray.Vector(1.0, 0.0, 0.0), vray.Vector(0.0, 0.0, 1.0), vray.Vector(0.0, -1.0, 0.0)), vray.Vector(160, -30, 200))
    renderer.start()
VRayInit init;
renderer.load("./softShadows.vrscene");
// create a new light plugin
LightOmni lightOmni = renderer.newPlugin<LightOmni>("LightOmniBlue");
lightOmni.set_color(Color(0.f, 0.f, 1.f));
lightOmni.set_intensity(60000.f);
lightOmni.set_decay(2.0f);
lightOmni.set_shadowRadius(40.0f);
lightOmni.set_transform(Transform(Matrix(Vector(1.0, 0.0, 0.0), Vector(0.0, 0.0, 1.0), Vector(0.0, -1.0, 0.0)), Vector(160.f, -30.f, 200.f)));
    renderer.Load("./softShadows.vrscene");
    LightOmni lightOmni = renderer.NewPlugin<LightOmni>("LightOmniBlue");
    lightOmni.Color = new Color(0, 0, 60000);
    lightOmni.ShadowBias = 0.2f;
    lightOmni.Decay = 2.0f;
    lightOmni.ShadowRadius = 40.0f;
    lightOmni.Transform = new Transform(new Matrix(new Vector(1.0, 0.0, 0.0)
                        , new Vector(0.0, 0.0, 1.0), new Vector(0.0, -1.0, 0.0))
                        , new Vector(160, -30, 200));
    renderer.Start();
try {
    LightOmni lightOmni = renderer.newPlugin("LightOmniBlue", LightOmni.class);
    lightOmni.setColor(new Color(0f, 0f, 60000f));
    lightOmni.setShadowBias(0.2f);
    lightOmni.setDecay(2.0f);
    lightOmni.setShadowRadius(40.0f);
    Transform transform = Transform.fromString("Transform(Matrix(Vector(1.0, 0.0, 0.0), Vector(0.0, 0.0, 1.0), Vector(0.0, -1.0, 0.0)), Vector(160, -30, 200))");
    lightOmni.setTransform(transform);
    renderer.render();
} finally {
renderer.load('./softShadows.vrscene', function(err) {
    if (err) throw err;
    var lightOmni = renderer.classes.LightOmni('LightOmniBlue');
    lightOmni.color = 'Color(0, 0, 1)';
    lightOmni.intensity = 60000;
    lightOmni.decay = 2.0;
    lightOmni.shadowRadius = 40.0;
                        , vray.Vector(160, -30, 200));
    renderer.render();
        renderer.close();
Figure IX.2
In the following example we remove a sphere plugin by its name:
import vray
    del renderer.plugins.GeoSphere01_node
    renderer.start()
VRayInit init;
Plugin sphere = renderer.getPlugin("GeoSphere01_node");
renderer.removePlugin(sphere);
    Plugin sphere = renderer.GetPlugin("GeoSphere01_node");
    renderer.RemovePlugin(sphere);
    renderer.Start();
try {
    Plugin p = renderer.getPlugin("GeoSphere01_node");
    renderer.removePlugin(p);
    renderer.render();
} finally {
    if (err) throw err;
    delete r.plugins.GeoSphere01_node;
    renderer.render();
        renderer.close();
Figure IX.3
Auto commit of property changes
All changes made to plugin properties should be done before the rendering starts when rendering in Production mode. Any changes after that do not affect the current rendering, but they are not lost. In interactive mode the changes made after the rendering starts are reflected dynamically on the scene. By default each change is applied immediatelly, but the user can decide to make a batch of changes to be applied together, usually for better performance. This is done using the autoCommit property of the VRayRenderer class. In the following example we demonstrate how a group of changes are batched and commit is called explicitly to apply them.
This example shows how to make a group of changes to a scene simultaneously.
The renderer property autoCommit is set to False so changes are applied
with delayed commit. See also addRemovePlugins.py.
from vray import *
import os
def createNewPlugin(renderer):
    lightOmni = renderer.classes.LightOmni()
    lightOmni.color = Color(0, 0, 60000)
    lightOmni.transform = Transform(Matrix(Vector(1.0, 0.0, 0.0),
with VRayRenderer() as r:
    r.autoCommit = False
    r.startSync()
    # This change won't be applied immediatelly
    createNewPlugin(r)
    r.waitForImageReady(2000)
    # Make a group of changes 2 seconds after the render starts
    r.plugins.renderView.fov = 1.5
    del r.plugins.GeoSphere01_node
    # Commit applies all 3 changes
    r.commit()
    r.waitForImageReady(4000)
VRayInit init;
renderer.setAutoCommit(false);
// This change won't be applied immediatelly
lightOmni.set_color(Color(0.f, 0.f, 60000.f));
lightOmni.set_shadowBias(0.2f);
lightOmni.setValueAsString("transform", "Transform(Matrix(Vector(1.0, 0.0, 0.0), Vector(0.0, 0.0, 1.0), Vector(0.0, -1.0, 0.0)), Vector(160, -30, 200))");
renderer.waitForImageReady(2000);
// Make a group of changes 2 seconds after the render starts
renderView.set_fov(1.5f);
// Commit applies all 3 changes
renderer.commit();
renderer.waitForImageReady(4000);
options.AutoCommit = false;
    lightOmni.Transform = Transform.FromString("Transform(Matrix(Vector(1.0, 0.0, 0.0), Vector(0.0, 0.0, 1.0), Vector(0.0, -1.0, 0.0)), Vector(160, -30, 200))");
    renderer.Start();
    renderer.WaitForImageReady(2000);
    renderView.Fov = 1.5f;
    renderer.Commit();
    renderer.WaitForImageReady(4000);
try {
    renderer.render();
    renderer.commit();
} finally {
    renderMode: 'rtCPU',
    autoCommit: false
    if (err) throw err;
    renderer.render();
    var lightOmni = renderer.classes.LightOmni();
    lightOmni.color = 'Color(0, 0, 60000)';
    lightOmni.transform = 'Transform(Matrix(Vector(1.0, 0.0, 0.0), ' +
        'Vector(0.0, 0.0, 1.0),' +
        ' Vector(0.0, -1.0, 0.0)), Vector(160, -30, 200))';
    setTimeout(function() {
        renderer.plugins.renderView.fov = 1.5;
        delete renderer.plugins.GeoSphere01_node;
        renderer.commit();
    }, 2000);
        renderer.close();
Figure IX.4
X. Property Types
The following are the types recognized for property types:
  • Basic types: int, bool, float, Color (3 float RGB), AColor (4 float ARGB), Vector (3 float), string (UTF-8), Matrix (3 Vectors), Transform (a Matrix and a Vector for translation)
  • Objects: references to other plugin instances
  • Typed lists: The typed lists in AppSDK are IntList, FloatList, ColorList and VectorList.
  • Generic heterogenous lists: The AppSDK uses a generic type class called Value for items in a generic list. Note that generic lists can be nested.
  • Output parameters: These are additional values generated by a given plugin which may be used as input by others.
Detailed documentation about working with each type can be found in the API docs as they have some language nuances. All types are in the VRay namespace.
XI. Animations
VRay AppSDK supports rendering of animated scenes. Animated scenes contain animated plugin properties. A plugin property is considered animated if it has a sequence of values, as each value is given for a specific time or frame number. This defines key frames and in the process of sampling, interpolation is done between them.
Two additional events are emitted while rendering a sequence of frames - sequenceStart and sequenceDone. OnImageReady is emitted on each finished frame and one can obtain the current frame number from the sequenceFrame property of the renderer.
import vray
import os
def onImageReady(r):
    print('Image Ready, frame ' + str(r.sequenceFrame) + '  (sequenceDone = ' + str(r.sequenceDone) + ')')
    r.continueSequence()
with vray.VRayRenderer(renderMode='rtGPU', rtSampleLevel=15) as renderer:
    renderer.load('./anim/anim_cube.vrscene')
    # When a single number is passed, it's interpreted as "start", with "end" being the last frame and step=1
    sequence = [{'start': 4, 'end': 5},
        {'start': 1, 'end': 5, 'step': 2},
        9]
    renderer.renderSequence(sequence)
    renderer.waitForSequenceDone()
using namespace std;
VRayInit init;
renderer.load("./anim/anim_cube.vrscene");
renderer.renderSequence();
while (false == renderer.isSequenceDone()) {
    renderer.waitForImageReady(60000);
    printf("Frame %d is ready\n", renderer.getSequenceFrame());
    renderer.continueSequence();
using VRay;
static string CubeSceneFilePath = @"\scenes\anim\anim_cube.vrscene";
static VRayRenderer renderer;
private static void OnImageReady(object sender, EventArgs e)
    Console.WriteLine("Image ready, frame {0}", renderer.SequenceFrame);
    renderer.ContinueSequence();
private static void OnSequenceStarted(object sender, EventArgs e)
    Console.WriteLine("Sequence started.");
private static void OnSequenceDone(object sender, EventArgs e)
    Console.WriteLine("Sequence done.");
public static void Main(string[] args)
    // Set the noise threshold to lower per frame rendering times
    options.RTNoiseThreshold = 0.25f;
    using (renderer = new VRayRenderer(options))
        renderer.Load(CubeSceneFilePath);
        renderer.ImageReady += new EventHandler(OnImageReady);
        renderer.SequenceStarted += new EventHandler(OnSequenceStarted);
        renderer.SequenceDone += new EventHandler(OnSequenceDone);
        // SubSequenceDesc(startFrame, endFrame, step) - the latter two parameters are optional.
        // By default endFrame is the last frame and step is 1, so it could be just a single frame and the implicit step is 1.
        // The range can be inverted and the separate ranges need not be sorted.
        // All these options are seen in the example array.
        SubSequenceDesc[] seq = { new SubSequenceDesc(3, 5), new SubSequenceDesc(1),
            new SubSequenceDesc(2), new SubSequenceDesc(10, 6, 2) };
        renderer.RenderSequence(seq);
        renderer.WaitForSequenceDone();
try {
    public static final String VRAY_SDK = System.getenv("VRAY_SDK");
    public static final String SCENES_FOLDER_PATH = VRAY_SDK + "/scenes/anim/";
    public static final String SCENE_FILENAME = "anim_cube.vrscene";
    public static final String SCENE_FILE = SCENES_FOLDER_PATH + SCENE_FILENAME;
    // create RT renderer
    renderer = new VRayRenderer(new RendererOptions()
        .setRenderMode(RenderMode.RT_GPU_CUDA)
    final VRayRenderer r = renderer;
    // set image ready callback
        @Override
            System.out.format("Image Ready, frame %d (sequenceDone = %b)%n", r.getSequenceFrame(), r.isSequenceDone());
    // load scene
    renderer.load(SCENE_FILE);
    SubSequenceDesc ss[] = {new SubSequenceDesc(1), new SubSequenceDesc(5, 2, 2), new SubSequenceDesc(5, 10)};
    // starts rendering process in new thread - no blocking call
    renderer.renderSequence(ss);
    // wait for some intermediate images to become available
    renderer.waitForSequenceDone();
    Systrem.out.format("Sequence done.%n");
} finally {
    renderMode: 'rtCPU'
renderer.on('imageReady', function () {
    console.log('Image Ready, frame ' + renderer.sequenceFrame +
            '  (sequenceDone = ' + renderer.sequenceDone + ')');
renderer.on('sequenceStart', function () {
    console.log('Sequence started.');
renderer.on('sequenceDone', function () {
    console.log('Sequence done. Closing renderer...');
    renderer.close();
renderer.load('./anim/anim_cube.vrscene', function (err) {
    if (err) {
        renderer.close();
        throw err;
    // renderSequence() arguments can be in an array but it's not obligatory
    // simple example: renderSequence({ start: 3, end: 8})
    // When a single number is passed, it's interpreted as "start", with "end" being the last frame and step=1
    renderer.renderSequence([{ start: 4, end: 5}, 1, 3, 2,
                             { start: 10, end: 1, step: -2}, 5, { start: 2, end: 6}]);
Figure XI.1
XII. V-Ray Server
A V-Ray Server is used as a remote render host during the rendering of a scene. The server is a process that listens for render requests on a specific network port and clients such as instances of the VRayRenderer class can connect to the server to delegate part of the image rendering. The server cannot be used on its own to start a rendering process but plays an essential role when completing distributed tasks initiated by clients. In order to take advantage of the distributed rendering capabilities of V-Ray, such servers need to be run and be available for requests.
The V-Ray Application SDK allows for easily preparing V-Ray server processes that can be used in distributed rendering. The API offers a specialized class VRayServer that exposes methods for starting and stopping server processes. In addition the VRayServer class enables users to subscribe to V-Ray server specific events so that custom logic can be executed upon their occurrence.
The supported events occur when:
  • The server process starts and is ready to accept render requests
  • A render client connects to the server to request a distributed rendering task
  • A render client disconnects from the server
  • A server message is produced to denote a change in the server status or to track the progress of the server work
The next code snippet demonstrates how the VRayServer can be instantiated and used to start a server process.
import vray
def onStart(server):
    print 'Server is ready.'
def onDumpMessage(server, message, level):
def onDisconnect(server, host):
    print 'Host {0} disconnected from server.'.format(host)
def onConnect(server, host):
    print 'Host {0} connected to server.'.format(host)
server = vray.VRayServer(portNumber=20207)
server.setOnStart(onStart)
server.setOnDumpMessage(onDumpMessage)
server.setOnDisconnect(onDisconnect)
server.setOnConnect(onConnect)
server.run()
#include "vraysrv.hpp"
void onLogMessage(VRayServer& server, const char* message, int level, void* userData)
VRayServerInit init;
ServerOptions options;
options.portNumber = 20207;
VRayServer server(options);
server.setOnDumpMessage(onLogMessage);
server.run();
ServerOptions options = new ServerOptions();
options.PortNumber = 20207;
using (VRayServer server = new VRayServer(options))
    server.Started += new EventHandler((source, e) =>
        Console.WriteLine("Server is ready");
    server.HostConnected += new EventHandler<HostEventArgs>((source, e) =>
        Console.WriteLine("Host {0} connected to server.", e.Host);
    server.HostDisconnected += new EventHandler<HostEventArgs>((source, e) =>
        Console.WriteLine("Host {0} disconnected from server.", e.Host);
    server.MessageLogged += new EventHandler<MessageEventArgs>((source, e) =>
    server.Run();
options.setPortNumber(20207);
VRayServer server = null;
try {
    server = new VRayServer(options);
    server.setOnServerEventListener(new OnServerEventListener() {
        @Override
        public void onStart() {
            System.out.println("Server is ready");
        @Override
        @Override
        public void onDisconnect(String host) {
            System.out.format("Host %s disconnected from server.\n", host);
        @Override
        public void onConnect(String host) {
            System.out.format("Host %s connected to server.\n");
    server.run();
} finally {
    if (server != null) {
        server.close();
var server = vray.VRayServer({
    portNumber : 20207
server.on('start', function() {
    console.log('Server is ready');
server.on('connect', function(host) {
    console.log('Host ' + host + ' connected to server.');
server.on('disconnect', function(host) {
    console.log('Host ' + host + ' disconnected from server.');
server.on('dumpMessage', function(message, level) {
server.start();
process.on('exit', function() {
    server.close();
Figure XII.1
The V-Ray Application SDK allows third party integrators to make full use of the V-Ray distributed rendering engine. The distributed rendering gives the ability parts of the image to be rendered in parallel by multiple render hosts. The client process which initiates the rendering synchronizes the results produced by the render servers also known as render slaves. All render modes support distributed rendering.
Render hosts can be dynamically added and removed at any point in time during the rendering process. The render hosts should have a V-Ray server running on them when the render client tries to add them to its list of active hosts because the client verifies whether a connection can be established for a distributed task at that time.
Each render host is identified by an address:port pair specifying the IP or DNS address of the machine with the V-Ray server and the port on which this server is listening for render requests. The VRayRenderer class exposes methods for the dynamic addition and removal of hosts. Irrespective of the progress made by the main render process in the client, remote machines can successfully begin to participate in the rendering as long as the they have running V-Ray servers.
import vray
import time
    renderer.start()
    # attach several hosts after a few seconds
    # If port is ommitted, it defaults to 20207
    time.sleep(6)
    renderer.addHosts('10.0.0.132:20207;10.0.0.132:20208')
    # display render host info
    print 'Active hosts: ', renderer.getActiveHosts()
    print 'All hosts: ', renderer.getAllHosts()
    # wait for the final image no more than the specified number of
    # milliseconds
VRayInit init;
// Attach several hosts after a few seconds
// If port is ommitted, it defaults to 20207
renderer.addHosts("10.0.0.132:20207;10.0.0.132:20208");
// display render host info
printf("Active hosts: %s\n", renderer.getActiveHosts().c_str());
printf("All hosts: %s\n", renderer.getAllHosts().c_str());
// wait for the final image no more than the specified number of milliseconds
    renderer.Start();
    // attach several hosts after a few seconds
    System.Threading.Thread.Sleep(6000);
    renderer.AddHosts("10.0.0.132:20207;10.0.0.132:20208");
    Console.WriteLine("Active hosts: {0}", renderer.ActiveHosts);
    Console.WriteLine("All hosts: {0}", renderer.AllHosts);
try {
    renderer.render();
    Thread.sleep(6000);
    System.out.println("Active hosts: " + renderer.getActiveHosts());
    System.out.println("All hosts: " + renderer.getAllHosts());
} catch (InterruptedException e) {
} finally {
    if (err) throw err;
    renderer.render();
        renderer.addHosts("10.0.0.132:20207;10.0.0.132:20208", function() {
            console.log("Active hosts: " + renderer.getActiveHostsSync());
            console.log("All hosts: " + renderer.getAllHostsSync());
                renderer.close();
    }, 6000);
Figure XIII.1
Removal of render hosts is just as easy as adding ones. Even if all remote render hosts disconnect or are deleted from the rendering host list the rendering process will continue on the client machine which has initiated it.
import vray
import time
    renderer.start()
    # detach a host after a few seconds
    time.sleep(6)
    renderer.removeHosts('10.0.0.132:20208')
    print 'Inactive hosts: ', renderer.getInactiveHosts()
    # milliseconds
VRayInit init;
// detach a host after a few seconds
renderer.removeHosts("10.0.0.132:20208");
printf("Inactive hosts: %s\n", renderer.getInactiveHosts().c_str());
// wait for the final image no more than the specified number of seconds
    renderer.Start();
    renderer.RemoveHosts("10.0.0.132:20208");
    Console.WriteLine("Inactive hosts: {0}", renderer.InactiveHosts);
try {
    renderer.render();
    Thread.sleep(6000);
    System.out.println("Inactive hosts: " + renderer.getInactiveHosts());
} finally {
        if (err) throw err;
        renderer.render();
            renderer.removeHosts("10.0.0.132:20208", function() {
                console.log("Inactive hosts: " + renderer.getInactiveHostsSync());
                    renderer.close();
        }, 6000);
Figure XIII.2
XIV. Setup
Each time AppSDK is used, the script setenv{python version}.sh should be run to setup some environment variables. Run either if you're not interested in Python. The following variables are set:
  • PATH (Windows) - Appended with the path to V-Ray's and the SDK's binaries
  • LD_LIBRARY_PATH (Linux) - Appended with the path to V-Ray's and the SDK's binaries
  • DYLD_LIBRARY_PATH (MacOS) - Appended with the path to V-Ray's and the SDK's binaries
  • VRAY_PATH - Path to where V-Ray and its plugins reside
  • PYTHONPATH - Used only by the Python binding
  • VRAY_SDK - Path to the main SDK folder used only by code examples
Users can pass the path contained in VRAY_PATH to the VRayRenderer constructor options (pluginLibraryPath) instead.
© Chaos Software 2016
