« Previous Version 43 Current »
This page provides information about the supported .vrscene features exported from V-Ray for 3ds Max.
Chaos Vantage has better support for .vrscene files exported from V-Ray Next and later. It is recommend to use the latest officially released V-Ray version.
Lights
UINative nameV-Ray plugin name (plugin/parameter)Support
On
enabled(tick)
Light Type:
Spot
Directional
Omni
LightSpotMax
LightDirectMax
LightOmniMax
(tick)
(tick)
(tick)
Targeted(tick)
Shadowsshadows(tick)
Use Global Settingsuse_global_light_level(tick)
Shadow Type
Adv. Raytraced
Area Shadows
Shadow Map
Ray Traced Shadows
VRayShadow
(minus)
(minus)
(minus)
(minus)
(tick)
Exclude...
SettingsLightLinker/ignored_lights
SettingsLightLinker/ ignored_shadow_lights
(error)
(error)
Transparent shadows –(minus)
BiasshadowBias (tick)
Area shadow:
Box
Sphere
shadowShape=0
shadowShape=1
(tick)
(tick)
U sizeshadowRadius
(tick)
V sizeshadowRadius1
(tick)
W sizeshadowRadius2
(tick)
Multiplierintensity
(tick)
Colorcolor
(tick)
Decay Type:
None
Inverse
Inverse Sqaure
decay_type=0
decay_type=1
decay_type=2
(tick)
(tick)
(tick)
Decay Startdecay_start(tick)
Near Attenuation:
Use
Show
Start
End
near_attenuation
near_attenuation_start
near_attenuation_end
(tick)
(minus)
(tick)
(tick)
Far Attenuation:
Use
Show
Start
End
far_attenuation
far_attenuation_start
far_attenuation_end
(tick)
(minus)
(tick)
(tick)
Show Clone(minus)
Overshootovershoot(tick)
Hotspot/Beamhotspot(tick)
Falloff/Fieldfallsize(tick)
Cirleshape_type=0(tick)
Rectangleshape_type=1(tick)
Aspectrect_aspect(tick)
Bitmap Fit...(minus)
Contrast(minus)
Soften Diff. Edge(minus)
DiffuseaffectDiffuse(tick)
SpecularaffectSpecular(tick)
Ambient Only
Mapprojector_map(tick)
Object Shadows:
Color
Density
Map
Light Affects Shadow Color
shadowColor
(error)
(minus)
(minus)
(minus)
Atmosphere Shadows:
On
Opacity
Color Amount
(minus)
(minus)
(minus)
Ray Bias
(error)
2 Sided Shadows(error)
Max Quadtree Depth(error)
V-Ray Plane Light LightRectangle/is_disc=0(tick)
Onenabled(tick)
Targeted(tick)
Length/Radiusu_size(tick)
Widthv_size(tick)
W size-(minus)
Units:
Default (image)
Luminous power (lm)
Luminance (lm/m2/sr)
Radiant power (W)
Radiance (W/m2/sr)
units=0
units=1
units=2
units=3
units=4
(tick)
(tick)
(tick)
(tick)
(tick)
Multiplierintensity(tick)
Mode:
Color
Temperature
(tick)
(tick)
Colorcolor(tick)
Temperaturecolor(tick)
Texture
use_rect_tex
(tick)
Map
rect_tex
(tick)
Directionaldirectional
(tick)
Preview:
Selected
Always
Never
(minus)
(minus)
(minus)
Texmap preview(minus)
Exclude
(error)
Cast shadowsshadows(error)
Double-sideddoubleSided
(tick)
Invisibleinvisible
(tick)
Occlude other lightsoccludeLights(error)
Affect diffuseaffectDiffuse
(tick)
Diffuse contributiondiffuse_contribution
(tick)
Affect specularaffectSpecular
(tick)
Specular contributionspecular_contribution
(tick)
Affect reflectionsaffectReflections
(tick)
Shadow biasshadowBias
(tick)
CutoffcutoffThreshold(error)
Tex resolutiontex_resolution(tick)
Near on decay_near_on(error)
Near start decay_near_start(error)
Near end decay_near_end
(error)
Far on decay_far_on(error)
Far start decay_far_start(error)
Far end decay_far_end(error)
Preview:
Selected
Always
Never
(minus)
(minus)
(minus)
Enable viewport shading(minus)
Viewport wire color(minus)
Intensity rays-(minus)
Icon text(minus)
V-Ray Disc Light LightRectangle/is_disc=1(tick)
Onenabled(tick)
Targeted(tick)
Radiusu_size(tick)
Widthv_size(tick)
W size-(minus)
Units:
Default (image)
Luminous power (lm)
Radiant power (W)
Radiance (W/m2/sr)
units=0
units=1
units=2
units=3
units=4
(tick)
(tick)
(tick)
(tick)
(tick)
Mode:
Color
Temperature
(tick)
(tick)
Colorcolor(tick)
Texture
use_rect_tex
(tick)
Map
rect_tex
(tick)
(tick)
Preview:
Selected
Always
Never
(minus)
(minus)
(minus)
Exclude
(error)
(tick)
Invisibleinvisible
(tick)
(tick)
(tick)
(tick)
(tick)
(tick)
(tick)
Near end decay_near_end(error)
Preview:
Selected
Always
Never
(minus)
(minus)
(minus)
Icon text(minus)
V-Ray Dome Light LightDome(tick)
Onenabled(tick)
Targeted(tick)
Radiusu_size(tick)
Proj heightv_size(tick)
Ground blend-(minus)
Units:
Default (image)
Luminous power (lm)
Radiant power (W)
Radiance (W/m2/sr)
units=0
units=1
units=2
units=3
units=4
(tick)
(tick)
(tick)
(tick)
(tick)
Mode:
Color
Temperature
(tick)
(tick)
Colorcolor(tick)
Texture
use_dome_tex
(tick)
Map
dome_tex
(tick)
Spherical (full dome)dome_spherical
(tick)
Finite domedome_finite_on(error)
Affect alphaaffect_alpha(error)
Lock texture to icon(minus)
Ray dist:
None
From GI
Explicit
dome_rayDistanceMode=0
dome_rayDistanceMode=1
dome_rayDistanceMode=2
(error)
(error)
(error)
Distancedome_rayDistance(error)
Target radius(minus)
Emit radius(minus)
Adaptive domedome_adaptive(error)
Exclude
(error)
(error)
Invisibleinvisible
(error)
(error)
(error)
Affect specularaffectSpecular(error)
(error)
(error)
(error)
Icon text(minus)
V-Ray Sphere Light LightSphere
(tick)
Onenabled(tick)
Targeted(tick)
Radiusu_size(tick)
V sizev_size(tick)
W size-(minus)
Units:
Default (image)
Luminous power (lm)
Radiant power (W)
Radiance (W/m2/sr)
units=0
units=1
units=2
units=3
units=4
(tick)
(tick)
(tick)
(tick)
(tick)
Mode:
Color
Temperature
(tick)
(tick)
Colorcolor(tick)
Texture-(minus)
Map-(minus)
Exclude
(error)
(tick)
Invisibleinvisible
(tick)
(tick)
(tick)
(tick)
(tick)
(tick)
(tick)
Preview:
Selected
Always
Never
(minus)
(minus)
(minus)
Icon text(minus)
V-Ray Mesh Light LightMesh(tick)
Onenabled(tick)
Targeted(tick)
U size-(minus)
V size-(minus)
W size-(minus)
Units:
Default (image)
Luminous power (lm)
Radiant power (W)
Radiance (W/m2/sr)
units=0
units=1
units=2
units=3
units=4
(tick)
(tick)
(tick)
(tick)
(tick)
Mode:
Color
Temperature
(tick)
(tick)
Colorcolor(tick)
Texture
use_tex
(tick)
Maptex
(tick)
Flip normals(minus)
Pick meshLightMesh/geometry(tick)
Replace mesh with light(minus)
Extract mesh as node(minus)
Exclude
(error)
(tick)
Invisibleinvisible
(tick)
(tick)
(tick)
(tick)
(tick)
(tick)
(tick)
Preview:
Selected
Always
Never
(minus)
(minus)
(minus)
Icon text(minus)
V-Ray IES Light LightIESMax(tick)
Enabledenabled
(tick)
Targeted
(tick)
Ies fileies_file
(tick)
Intensity valuepower(tick)
Intensity type:
power (lm)
intensity (cd)
(tick)
(tick)
Override intensity:
rescale
replace
override_prescribed_power=0
override_prescribed_power=1
(tick)
(tick)
Color mode:
Color
Temperature
(tick)
(tick)
Color color(tick)
Color temperaturecolor(tick)
Rotation X
(tick)
Rotation Y
(tick)
Rotation Z
(tick)
Override shapeies_light_shape(tick)
Shapeies_light_shape(tick)
Heighties_light_height(tick)
Widthies_light_width(tick)
Lengthies_light_length(tick)
Diameteries_light_diameter(tick)
Exclude
SettingsLightLinker/ignored_shadow_lights
(error)
(error)
Use light shape:
No
For shadows only
For illumination and shadows
soft_shadows=0
soft_shadows=1
soft_shadows=2
(error)
(error)
(error)
Cast shadowsshadows(tick)
Affect diffuseaffectDiffuse(tick)
Diffuse contributiondiffuse_contribution(tick)
Affect specularaffectSpecular(tick)
Specular contributionspecular_contribution(tick)
Affect atmospheric
Area specularsarea_speculars(tick)
Show distribution(minus)
Icon text(minus)
Shadow biasshadowBias(tick)
Near startdecay_near_start (error)
Near end decay_near_end (error)
Far ondecay_far_on  (error)
Far start decay_far_start (error)
Far enddecay_far_start(error)
V-Ray Ambient Light LightAmbientMax(error)
Enabledenabled
(error)
Mode:
Direct + GI
Direct light
GI
mode=0
mode=1
mode=2
(error)
(error)
(error)
GI min distancegi_min_distance
(error)
Colorcolor
(error)
Intensitycolor
(error)
Light map
(error)
Compensate exposurecompensate_exposure
(error)
Exclude...
(error)
(error)
V-Ray SunSunLight(tick)
Enabled
  enabled
(tick)
Intensity multiplierintensity_multiplier
(tick)
Size multipliersize_multiplier
(tick)
Filter colorfilter_color
(tick)
Color mode:
filter
direct
override
color_mode=0
color_mode=1
color_mode=2
(tick)
(tick)
(tick)
Sky model:
Preetham et al.
CIE clear
CIE overcast
Hosek et al.
PRG Clear Sky
sky_model.0
sky_model=1
sky_model=2
sky_model=3
sky_model=4
(tick)
(tick)
(tick)
(tick)
(tick)
Ground albedoground_albedo
(tick)
Indirect horiz illuminationhoriz_illum
(tick)
Blend angleblend_angle
(tick)
Horizon offsethorizon_offset
(tick)
Turbidityturbidity
(tick)
Ozoneozone
(tick)
Exclude
(error)
(error)
Invisibleinvisible
(tick)
(tick)
(tick)
Affect atmosphericaffectAtmospherics(error)
Atmospheric conrtibutionatmospherics_contribution(error)
Cast atmospheric shadowsatmos_shadows(error)
(tick)
Photon emit radiusphoton_radius(error)
Clouds on clouds_on (tick)
Ground shadowsclouds_ground_shadows  (tick)
Density clouds_density (tick)
Density multiplier clouds_density_multiplier (error)
Variety clouds_variety (tick)
Seed clouds_seed(error)
Cirrus amount clouds_cirrus_amount (tick)
Offset X (m)clouds_offset_x (tick)
Offset Y (m)clouds_offset_y (tick)
Height (m)clouds_height  (tick)
Thickness (m)clouds_thickness (tick)
Phase X (%)clouds_phase_x  (tick)
Phase Y (%)clouds_phase_y (tick)
Enable contrailsclouds_contrails_on  (error)
Number of contrailsclouds_contrails_num_planes (error)
Contrails strengthclouds_contrails_strength  (error)
Contrails distortionclouds_contrails_distortion  (error)
Contrails offset X (m)clouds_contrails_offset_x  (error)
Contrails offset Y (m)clouds_contrails_offset_y (error)
Contrails timeclouds_contrails_time(error)
Physical Camera
UINative nameV-Ray Plugin nameSupport
Physical CameraCameraPhysical
Targeted
(tick)
Target Distance
target_distance
(tick)
Show Cone:
When Selected
Always
Never
(minus)
(minus)
(minus)
Show Horizon Line(minus)
Texture Resolutionbmpaperture_resolution
(error)
Use Lens Filedistortion_type=2
(error)
Lens Filelens_file
(error)
Preset(minus)
Widthfilm_width
(tick)
Focal Lengthfocal_length
(tick)
Specify FOVspecify_fov
(tick)
FOVfov
(tick)
Zoomzoom_factor
(tick)
Aperturef_number
(tick)
Use Target Distancetargeted=1
(tick)
Customtargeted=0
(tick)
Focus Distancefocus_distance
(tick)
Lens Breathing
(tick)
Enable Depth of Fielduse_dof
(tick)
Shutter Type(minus)
Durationshutter_speed
(tick)
Offsetshutter_offset
(error)
Enable Motion Bluruse_moblur
(error)
Exposure ControlSettingsColorMapping/exposure
(error)
ManualISO
(tick)
Target
(error)
Illuminantwhite_balance
(error)
Temperaturewhite_balance
(error)
Customwhite_balance
(error)
Enable Vignettingvignetting
(error)
Amountvignetting
(error)
Aperture Shape:
Circular
Bladed
blades_enable=0
blades_enable=1
(tick)
(tick)
Bladesblades_num
(tick)
Rotationblades_rotation
(tick)
Custom Texturebmpaperture_tex
(error)
Affect Exposurebmpaperture_affects_exposure
(error)
Center Bias (Ring Effect)center_bias
(error)
Optical Vignetting (Cat Eye)optical_vignetting
(error)
Anisotropy (Anamorphic Lens)anisotropy
(error)
Lens Shift:
Horizontal
Vertical
horizontal_offset
vertical_offset
(tick)
(tick)
Tilt Correction:
Horizontal
Vertical
horizontal_shift
lens_shift
(tick)
(tick)
Auto Vertical Tilt Correction
(tick)
Distortion Type:
None
Cubic
distortion=0
distortion_type=1
(error)
(error)
Amountdistortion
(error)
Texturelens_file
(error)
EnableRenderView/clipping
(tick)
Clipping NearRenderView/clipping_near
(tick)
Clipping FarRenderView/clipping_far
(tick)
Environment Near Range(minus)
Environment Far Range-(minus)
V-Ray Physical CameraCameraPhysical
Targeted –
(tick)
Camera Type:
Still cam
Movie cam
Video cam
type=0
type=1
type=2
(tick)
(error)
(error)
Target distancetarget_distance
(tick)
Focus distancefocus_distance
(tick)
Show cone/grid(minus)
Show horizon line(minus)
Use Field of viewspecify_fov
(tick)
Field of viewfov
(tick)
Film gate (mm)film_width
(tick)
Focal length (mm)focal_length
(tick)
Zoom factorzoom_factor
(tick)
Film speed (ISO)ISO
(tick)
F-Numberf_number
(tick)
Shutter speedshutter_speed
(tick)
Shutter angleshutter_angle
(error)
Shutter offsetshutter_offset
(error)
Latency (s)latency
(error)
Depth of fielduse_dof
(tick)
Motion bluruse_moblur
(error)
Exposure:
No exposure
Physical exposure
Exposure value (EV)
exposure=0
exposure=1
exposure=2
(tick)
(tick)
(tick)
Exposure valueexposure_value
(tick)
(error)
White balancewhite_balance
(tick)
Custom balancewhite_balance
(tick)
Temperature (K)white_balance
(tick)
Override 3ds Max resolutionoverride_resolution (tick)
Widthoverride_width  (tick)
Heightoverride_height
(tick)
Aspect ratio - (minus)
Swap W/H - (minus)
Auto update -(minus)
Update-(minus)
Automatic vertical tilt
(tick)
Tilt:
Vertical
Horizontal
lens_shift
horizontal_shift
(tick)
(tick)
Shift:
Vertical
Horizontal
vertical_offset
horizontal_offset
(tick)
(tick)
Guess vert tilt
(tick)
Guess horiz tilt
(tick)
Enable Bladesblades_enable
(tick)
Bladesblades_num
(tick)
(tick)
Center biascenter_bias
(error)
Anisotropyanisotropy
(error)
Optical vignettingoptical_vignetting
(error)
Bitmap aperturebmpaperture_enable
(error)
Affect exposurebmpaperture_affects_exposure
(error)
Bitmap resolutionbmpaperture_resolution
(error)
Bitmap
bmpaperture_tex
(error)
Distortion type:
Quadratic
Cubic
Lens file
Texture
distortion_type=0
distortion_type=1
distortion_type=2
distortion_type=3
(error)
(error)
(error)
(error)
Amountdistortion
(error)
Lens filelens_file
(error)
Map
distortion_tex
(error)
ClippingRenderView/clipping
(tick)
Near clipping planeRenderView/clipping_near
(tick)
Far clipping planeRenderView/clipping_far
(tick)
Near env range(minus)
Far env range(minus)
Mode:
Disabled
Top to bottom
Bottom to top
Left to right
Right to left
rolling_shutter_mode=0
rolling_shutter_mode=1
rolling_shutter_mode=2
rolling_shutter_mode=3
rolling_shutter_mode=4
(error)
(error)
(error)
(error)
(error)
Duration (s^-1)rolling_shutter_duration
(error)
Enabled -(minus)
Map -(minus)
Custom-
(minus)
Rows - (minus)
Columns -(minus)
Golden grids - (minus)
Golden spiral -(minus)
Golden triangle -(minus)
Flip hor. -(minus)
Flip ver.-(minus)
Geometry
Native NameV-Ray Plugin NameSupport
Chaos Scatter
GeomInstancer
(tick)
V-Ray Clipper
VRayClipper
(error)
V-Ray DecalVRayDecal
(error)
V-Ray Displacement:
2D Mapping
3D Mapping
Subdivision
GeomDisplacedMesh
GeomDisplacedMesh
GeomStaticSmoothedMesh
partial
(tick)
(tick)
V-Ray EnmeshGeomEnmesh
(error)
V-Ray Fur
GeomHair
(tick)
V-Ray Instancer
Instancer
(tick)
V-Ray MetaBall
(minus)
V-Ray PlaneGeomPlane
(error)
V-Ray Proxy
GeomMeshFile
(tick)
V-Ray SceneVRayScene
(tick)
V-Ray Sphere
(minus)
V-Ray VolumeGrid
PhxShaderSimVol
(error)
Environment
VRayEnvironmentFog
(tick)
Materials
V-Ray ALSurfaceBRDFALSurface
  • Diffuse
  • Diffuse strength
  • Reflect color
  • Reflect strength
  • Reflect roughness
  • Reflect IOR
  • Reflect distribution GGX
VRayBlendMtlBRDFLayered
  • Base material
  • Coat materials
  • Blend amount color
  • Blend amount texture
  • Blend amount
VRayBumpMtl
BRDFBump
  • Base material
  • Bump map
  • Bump amount
VRayCarPaintMtl
BRDFCarPaint
  • Base color
  • Base reflection
  • Base glossiness
  • Coat color
  • Coat strength
  • Coat glossiness
VRayCarPaintMtl2BRDFCarPaint2
  • Base color
  • Base reflection
  • Base glossiness
  • Base glossiness tail
  • Coat color
  • Coat amount
  • Coat ior
  • Coat glossiness
VRayLightMtl
BRDFLight
  • Color
  • Color multiplier
VRayScatterVolume
BRDFScatterVolume
  • Overall color
  • Scatter Color
VRayFastSSS2
BRDFSSS2Complex
  • IOR
  • Subsurface color
  • Specular color
  • Specular amount
  • Specular glossiness
VRayStochasticFlakesMtl
BRDFStochasticFlakes
  • Hilight glossiness
  • Reflection filter
  • BRDF Type: GGX
Two SidedMtl2Sided
  • Front Material
  • Back Material
  • Translucency
VRayToonMtl
BRDFToonMtl
Loads as BRDFVRayMtl, toon parameters are ignored.
VRayPointParticleMtl
BSDFPointParticle
Loads as a simple diffuse BRDF.
VRayFlakesMtl BRDFFlakes (error)
VRayFlakesMtl2 BRDFFlakes2 (error)
VRayGLSMtl MtlGLSL(error)
VRayMDLMtl MtlMDL(error)
VRayHairNextMtlBRDFHair4
  • Melanin
  • Pheomelanin
  • Dye color
  • Diffuse color
  • Gossiness
  • Primary grlossiness
  • Softness
  • Highlight shift
  • IOR
  • Glint
  • Gray hair density
  • Randomizations
  • Primary tint
  • Secondary tint
  • Transmission tint
VRayMtlWrapper MtlWrapper
  • Base  material
VRayOSLMtl MtlOSL (error)
VRayOverrideMtl MtlOverride
  • Base material
  • GI material
  • Reflect material
  • Refract material
VRayPluginNodeMtl  (error)
VRayScannedMtl BRDFScanned(error)
VRaySwitchedMtl MtlMulti
  • Material 0
VRayVectorDisplBake  (error)
VRayVRmatMtl MtlVRmat(error)
VRayMtl
UINative nameV-Ray plugin Name (plugin/parameter)Support
VRayMtlBRDFVRayMtl
Diffuse
diffuse
(tick)
Diffuse Texturediffuse
(tick)
Roughnessroughness
(error)
Roughness Textureroughness
(error)
Preset-
(tick)
Enable Bump map-
(tick)
Bump amountbump_amount
(tick)
Bump Texturebump_tex
(tick)
Reflectreflect
(tick)
Reflect Texturereflect
(tick)
Reflect Glossinessreflect_glossiness
(tick)
Reflect Glossiness Texturereflect_glossiness
(tick)
Fresnel reflectionsfresnel
(tick)
Fresnel IOR
fresnel_ior
(tick)
Fresnel IOR Lockfresnel_ior_lock
(tick)
Fresnel IOR Texturefresnel_ior
(tick)
Metalnessmetalness
(tick)
Metalness Texturemetalness
(tick)
Max depthreflect_depth
(error)
Reflect on back sideoption_reflect_on_back
(tick)
Dim distance
reflect_dim_distance
(error)
Dim fall offreflect_dim_distance_falloff
(error)
Affect channel:
Color only
Color+alpha
All Channels
reflect_affect_alpha=0
reflect_affect_alpha=1
reflect_affect_alpha=2
(error)
(error)
(error)
Refractrefract
(tick)
Refract Texturerefract
(tick)
Refract Glossinessrefract_glossiness
(tick)
Refract Glossiness Texturerefract_glossiness
(tick)
IORrefract_ior
(tick)
IOR Texturerefract_ior
(tick)
Abbe numberdispersion
(error)
Max depthrefract_depth
(error)
Affect shadowsrefract_affect_shadows
(tick)
Affect channel:
Color only
Color+alpha
All Channels
refract_affect_alpha=0
refract_affect_alpha=1
refract_affect_alpha=2
(error)
(error)
(error)
Thin-walledrefract_thin_walled
(error)
Translucency:
None
Volumetric
SSS
translucency=0
translucency=5
translucency=6
(error)
(error)
(error)
Fog color / Scatter raduisfog_color
(tick)
Fog color Texture / Scatter radius Texturefog_color_tex
(error)
Depth (cm) / Scale (cm)fog_mult
(tick)
Illumination:
Uniform
Directional
(error)
(error)
Scatter colortranslucency_color
(error)
Scatter color Texturetranslucency_color
(error)
SSS amounttranslucency_amount
(error)
Self-Illuminationself_illumination
(tick)
Self-IlluminationTextureself_illumination
(tick)
GIself_illumination_gi
(tick)
MultTexCombineColor / result_multiplier
(tick)
Compensate camera exposurecompensate_camera_exposure
(error)
Coat amountcoat_amount
(tick)
Coat amount Texturecoat_amount
(tick)
Coat glossinesscoat_glossiness
(tick)
Coat glossiness Texturecoat_glossiness
(tick)
Coat IORcoat_ior
(tick)
Coat IOR Texturecoat_ior
(tick)
Coat colorcoat_color
(tick)
Coat color Texturecoat_color
(tick)
Lock coat bump to base bumpcoat_bump_lock
(tick)
Enable Coat bump-
(error)
Coat bump amountcoat_bump_amount
(error)
Coat bump Texturecoat_bump_map
(error)
Enable thin filmthin_film_on
(error)
IORthin_film_ior
(error)
Min thickness (nm) thin_film_thickness_min(error)
Max thickness (nm)thin_film_thickness_max(error)
Sheen colorsheen_color
(error)
Sheen color Texturessheen_color
(error)
Sheen glossinesssheen_glossiness
(error)
Sheen glossiness Texturesheen_glossiness
(error)
BRDF:
Phong
Blinn
Ward
Microfacet GTR (GGX)
brdf_type=0
brdf_type=1
brdf_type=2
brdf_type=4
(tick)
(tick)
(tick)
(tick)
Use glossiness / Use roughnessoption_use_roughness
(tick)
GTR tail falloffgtr_gamma
(tick)
GTR tail falloff Texturegtr_gamma
(error)
(error)
Anisotropy Textureanisotropy
(error)
Rotation
anisotropy_rotation
(error)
Rotation Textureanisotropy_rotation
(error)
Local axisanisotropy_axis
(error)
Map channelanisotropy_derivation
(error)
Trace reflectionsreflect_trace
(error)
Trace refractionsrefract_trace
(error)
Cutoffoption_cutoff
(error)
Env. priorityenvironment_priority
(error)
Preserve energy:
RGB
Monochrome
option_energy_mode=0
option_energy_mode=1
(error)
(error)
Double-sidedoption_double_sided
(tick)
Use irradiance mapoption_use_irradiance_map
(error)
Fog system units scalingfog_unit_scale_on
(error)
Effect IDMtlMaterialID / material_id_number
(error)
Opacity mode:
Normal
Clip
Stochastic
opacity_mode=0
opacity_mode=1
opacity_mode=2
(error)
(tick) 1
(error)
Diffuse Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Reflect Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Reflect Glossiness Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Refract Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Refract Glossiness Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Opacity Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Bump Texture Multiplierbump_amount
(tick)
Displace Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Self -illum Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Diff. rough Texture MultiplierTexCombineColor / texture_multiplier
(error)
Fresnel IOR Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Metalness Texture Multiplier
(error)
Anisotropy Texture MultiplierTexCombineColor / texture_multiplier
(error)
An. rotation Texture MultiplierTexCombineColor / texture_multiplier
(error)
GTR falloff Texture MultiplierTexCombineColor / texture_multiplier
(error)
(tick)
Translucent Texture MultiplierTexCombineColor / texture_multiplier
(error)
Translucent Amount TexCombineColor / texture_multiplier(error)
Fog color Texture MultiplierTexCombineColor / texture_multiplier
(error)
Coat amount Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Coat gloss Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Coat IOR Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Coat color Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Coat bump Texture Multipliercoat_bump_amount
(error)
Thin Film Thickness  TexCombineColor / texture_multiplier(error)
Thin Film IORTexCombineColor / texture_multiplier(error)
Sheen color Texture MultiplierTexCombineColor / texture_multiplier
(error)
Sheen gloss Texture MultiplierTexCombineColor / texture_multiplier
(error)
Environment TextureBRDFVRayMtl / environment_override
(error)
Maps
Native NameV-Ray plugin NameSupportNote
General Maps
Advanced Wood
(error)
BerconGradient
TexBerconGrad
(error)
BerconMapping
TexBerconDistortion
(error)
BerconNoise
TexBerconNoise
(error)
BerconTile
TexBerconTile
(tick)Not supported in bump and opacity mapping
BerconWood
TexBerconWood
(error)
Bitmap
TexBitmap
(tick)
BlendedBoxMap
(error)
Camera Map Per Pixel(error)
CellularTexCellular              (tick)Not supported in bump and opacity mapping
CheckerTexChecker(tick)Not supported in bump and opacity mapping
ColorCorrectionColorCorrection(tick)Not supported in bump and opacity mapping
ColorCorrect 1 ColorCorrect(tick)Not supported in bump and opacity mapping
ColorMap
TexMaxGamma(error)
Compound-(tick)
Combustion 1 (error)
Complex FresnelTexComplexFresnel(tick)
Composite
TexLayeredMax
DentTexDent(error)
FalloffTexFalloff(tick)Not supported in bump and opacity mapping
ForestColorTexForestColor(tick)Not supported in bump and opacity mapping
GradientTexGradient(tick)Not supported in bump and opacity mapping
Gradient Ramp
TexGradRamp
Map Output Selector(error)
MarbleTexMarbleMax      (tick)Not supported in bump and opacity mapping
MaskTexMaskMax(tick)Not supported in bump and opacity mapping
MixTexMix                   (tick)Not supported in bump and opacity mapping
MultiTextureTexMultiX(tick)Not supported in bump and opacity mapping
MultiTitle(error)
NoiseTexNoiseMax      (tick)Not supported in bump and opacity mapping
OSL MapTexOSL(error)
OutputTexOutput       (tick)Not supported in bump and opacity mapping
Particle Age(error)
Particle MBlur(error)
Perlin Marble(error)
RGB MultiplyTexRGBMultiplyMax(tick)Not supported in bump and opacity mapping
RGB TintTexRGBTintMax(tick)Not supported in bump and opacity mapping
SigerScratchesTexSigerScratches(minus)
ShapeMap(error)
SmokeTexSmoke(tick)Not supported in bump and opacity mapping
SpeckleTexSpeckle(tick)Not supported in bump and opacity mapping
SplatTexSplat                 (tick)Not supported in bump and opacity mapping
StuccoTexStucco(tick)Not supported in bump and opacity mapping
Substance(error)
Substance2RawBitmapBuffer(tick)
SwirlTexSwirl(tick)Not supported in bump and opacity mapping
TexMap(error)
TextureObjMask(error)
Thin FilmTexThinFilm(tick)
TilesTexTiles(tick)Not supported in bump and opacity mapping
Vector Displacement(error)
Vector Map(error)
VertexColorTexUVW(tick)Not supported in bump and opacity mapping
WavesTexWaves(error)
V-Ray Maps
VRayBitmap (VRayHDRI)TexBitmap(tick)
VRayBump2Normal(error)
VRayColorTexAColor(tick)Not supported in bump and opacity mapping
VRayColor2Bump(error)
VRayCompTexTexCompMax(tick)Not supported in bump and opacity mapping
VRayCurvatureTexCurvature(error)
VRayDirtTexDirt(error)
VRayDistanceTexTexDistance(error)
VRayEdgesTexTexEdgesPartial
'Color' parameters only
VRayFakeFresnelTex 2 (error)
VRayGLSLTexMtlGLSL(error)
VRayHairInfoTexTexMaxHairInfo(error)
VRayHDRI(VRayBitmap)
TexBitmap(tick)
VRayICCTexICC(error)
VRayLutTexLut(error)
VRayMultiSubTexTexMulti(tick)Not supported in bump and opacity mapping
VRayNoiseTex
TexNoiseMax
VRayNormalMapTexNormalBump(tick)
VRayOCIOTexOCIO(error)
VRayOSLOutputSelectorTexOSLOutputSelector(error)
VRayOSLTexTexOSL(error)
VRayParticleTexTexParticleDiffuse(error)
VRayPointCloudColorTexMaxPointCloudColor(error)
VRayPluginNodeTex(error)
VRayPtexTexPtex(error)
VRaySamplerInfoTex(error)
VRaySkyTexSky(tick)Not supported in bump and opacity mapping
VRaySoftboxTexSoftbox(error)
VRayTriplanarTexTexTriplanar(tick)Not supported in bump and opacity mapping
VRayUserColorTexUserColor(error)
VRayUserScalarTexUserScalar(error)
VRayUVWRandomizerTexUVWRandomizer(tick)Not supported in bump and opacity mapping
  1. This feature is not available in 3ds Max 2024.
  2. This feature is not available in V-Ray 6 and above.
