This page provides details about the Viewport Video Capture dialog.
The Viewport Video Capture dialog allows you to specify the quality preset and frame rate when recording the viewport into a video file.
UI Path
To access the Viewport Video Capture dialog, go to Tools menu > Record Viewport to Video File
Capture resolution – Shows the resolution at which the viewport will be captured. This can be controlled by resizing the Chaos Vantage app window.
Quality Preset – Specifies a preset for the capture quality.
High – High video quality with large file size.
Medium – Medium video quality with reasonable file size .
Low – Low video quality with very little file size.
Frame rate – Sets how many frames per second will be captured. Lower values produce lower file size but video has choppy quality, while large values result in smooth video quality but with large file size.
Capture Microphone – Enables the capture of input audio during viewport capture.
Start – When enabled, opens a Save Video window to specify where the capture will be saved. After confirmation with the Save button, starts the viewport capture.
Cancel – Closes the Viewport Video Capture window.
