This page provides information about the V-Ray Diffuse Render Channel in V-Ray for Blender.
The Diffuse Render Channel shows the colors and textures used in materials, flatly applied to objects with no lighting information. The colors are the actual colors set in the material definition, and each texture appears as it does in the texture (file) itself. There are no highlights or shadows, and every background image is excluded.
Other render channels that include colors from materials are said to include the diffuse contribution or the diffuse component of the rendered scene. The Diffuse Render Channel contributes to this diffuse component; any render channel that includes this diffuse component is a combination of vrayRE_Diffuse and other render channel(s).
Note that the Diffuse  Render Channel is affected by reflection and refraction combined weight.
This render channel is useful for making overall adjustments and enhancements to base colors and textures during compositing without affecting reflections and highlights.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Advanced > V-Ray Diffuse
Properties
Enable Deep Output  Specifies whether to include this render channel in deep images.
Color Mapping – Applies the color mapping options specified in the Color Mapping rollout of the V-Ray tab in the Render Settings window to this render channel. This option is enabled by default.
Filtering –  Applies an image filter to this channel.
