This page provides information on the GI Render Channel in V-Ray for Blender.
The Global Illumination Render Channel is a color image that stores indirect lighting information coming from reflected diffuse light in a scene (without direct light and reflection contributions) when Global Illumination is enabled in Render Settings. This channel may be used directly in Back to Beauty compositing and adjusted for brightness and color to control the final image easily.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Beauty > V-Ray GI
Properties
Enable Deep Output  Specifies whether to include this render channel in deep images.
Color Mapping – Applies the color mapping options specified in the Color Mapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default.
Filtering –  Applies an image filter to this channel.
