©BBB3viz
« Previous Version 6 Current »
This section contains information on licensing agreements and copyrights for V-Ray for 3ds Max.
The following pages contain detailed licensing information related to V-Ray:
Product Support Lifecycle Policy
For all of our products, we typically support compatibility with the current and past three versions of each host application. For example, V-Ray 7 for Maya supports Maya 2022, 2023, 2024 and 2025. Only the newest version of V-Ray will be updated to be compatible with new versions of the host application.
Throughout the year, between major releases, we typically release Software Updates and Hotfixes. While both are free, Updates containing new features and improvements are made available only for the latest version of V-Ray. Hotfixes, which consist of bug fixes only, may be made available for previous versions as well.
Hotfixes for older versions of V-Ray are only released when an essential fix is required for an issue that occurred after the release of the software. An example of this would be if a host application or an operating system update causes a critical error in V-Ray.
Chaos provides support and technical assistance to clients for the current and one previous V-Ray major versions. For example, if the current shipping V-Ray version is 7, Chaos will support and assist users of V-Ray 7 and V-Ray 6.x. You can also find community support for all current and previous versions of our software in the Chaos forum. Keep in mind that sometimes the only way to resolve an issue in a previous version of our software is to upgrade to the latest version.
