Version 1 Next »
This page contains release notes for V-Ray for Blender, organized by build version number.
V-Ray for Blender Public Beta Update 2
Official release, hotfix 1
Date
New and Modified Features
V-Ray
  • Add a Lights list to the LightSelect render channel
  • Fix V-Ray Proxy import. Show V-Ray Proxy properties in the 'Data' property page
  • Support Alembic in V-Ray Proxy
  • Add a label with the channel type to the render channel properties
  • Set V-Ray render engine thread priority to 'low' for production renders
  • Temporarily hide V-Ray Scene from the UI
  • Add Firefly Removal value property field
Bug Fixes
V-Ray
  • Fix LightMix implementation
  • Error occurs when Packing an Image through the World Properties panel
  • Fix several issues with V-Ray Mtl's UI
  • Update the link to Online Documentation in the V-Ray menu
  • Do not export unused materials to V-Ray
  • VFB Layers were not reset on scene reload
  • Removing an Object or Collection in V-Ray Distance doesn’t trigger an IPR update
  • V-Ray Object Select node applied to V-Ray Aerial Perspective doesn't affect the result
V-Ray ZmqServer
  • Sign In prompt should not be shown on error -200, "No connection with the license server"
