Version 1 Current »
Error rendering macro 'rw-search'
Enscape 4.4.0 Preview 1
Release Notes 12.02.2025
New
  • Emissive Materials as Ray-Traced Light Sources: Emissive materials now behave as true light sources when hardware ray tracing is enabled. This ensures more predictable lighting, reduces noise artifacts, and removes the need for inefficient modeling workarounds (e.g., manually placing thousands of light sources).
    • Cleaner, more consistent lighting behavior across all emissive materials.
    • Enhanced filtering and sampling methods minimize noise and ensure efficiency in both small and large-scale projects.
    • Matches the behavior of analytical and mesh lights for greater realism.
Please Note: This feature requires hardware ray tracing.
  • SketchUp 2025 Beta Support: Initial compatibility with SketchUp 2025 Beta. Please note, new SketchUp 2025 advanced features are not yet supported and will roll out in future updates.
  • Revit 2026 Preview Support: Initial compatibility with Revit 2026 Preview, enabling you to work seamlessly with the latest version.
  • Announcement - Phased Removal of Old Host Versions: Starting in 2025, we will remove unsupported host application versions from our installer three months after their official end-of-support announcement. While we’ve historically included older releases (for example, the latest Enscape version can still be installed for Revit 2015 - 2021, even though these versions are no longer officially supported), we’ve found that continuing to bundle out-of-date versions creates additional complexity for both developers and customer support teams. Since these older releases are no longer supported by their original publishers, phasing them out from our latest installers helps us focus on providing the best possible experience for current versions.
Each time we officially support a new host application release, we’ll clearly communicate which older versions will be removed, and when, through our Forum and Release Notes. We understand change could be inconvenient, but this policy ensures better code quality, a streamlined installer, and improved support for you. Stay tuned for more details!
Fixed Bugs
  • Impact - Missing Imperial Equivalents: Resolved an issue where Total Carbon Emission and Energy Use Intensity metrics did not display imperial units.
  • ArtModes - Crash with Alpha Mask: Fixed a crash during screenshot export when using Watercolor, Orthographic, and Apply Alpha Channel.
  • NewForma Konekt - Annotation Without Value Throws Exception: Fixed an issue where creating an annotation without setting a custom attribute value caused an exception in Newforma Konekt.
Known Issues
  • Sun Settings Not Synced to Renderer: Changing sun settings in the CAD application while View Sync is enabled does not update the sun position in the Enscape renderer.
