This page contains release notes for V-Ray for Blender, organized by build version number.
V-Ray for Blender Public Beta Update 2
Official release, hotfix 1
Date - Jan 30, 2025
Download the V-Ray for Blender Beta
Take the Blender Setup survey, so we can improve your V-Ray for Blender experience.
New and Modified Features
V-Ray
- Add a Lights list to the LightSelect render channel
- Fix V-Ray Proxy import. Show V-Ray Proxy properties in the 'Data' property page
- Support Alembic in V-Ray Proxy
- Add a label with the channel type to the render channel properties
- Set V-Ray render engine thread priority to 'low' for production renders
- Temporarily hide V-Ray Scene from the UI
- Add Firefly Removal value property field
Bug Fixes
V-Ray
- Fix LightMix implementation
- Error occurs when Packing an Image through the World Properties panel
- Fix several issues with V-Ray Mtl's UI
- Update the link to Online Documentation in the V-Ray menu
- Do not export unused materials to V-Ray
- VFB Layers were not reset on scene reload
- Removing an Object or Collection in V-Ray Distance doesn’t trigger an IPR update
- V-Ray Object Select node applied to V-Ray Aerial Perspective doesn't affect the result
V-Ray ZmqServer
- Sign In prompt should not be shown on error -200, "No connection with the license server"
