This pages provides information about the User Color Node in V-Ray for Cinema 4D.
The V-Ray User Color node texture can be used to read user-defined object properties from the current material and convert them to a color value. This allows you to use the same shading network on several different objects in the scene, but to control various aspects of the material through user-defined properties. This texture also has the ability to read mesh color sets, UV sets, and extra channel information from VRayProxy objects.
Properties
User Attribute – Specifies the name of the user attribute that is looked up and returned from this shading node.
Default Color – Specifies the color to return, if the user attribute is not found on the shaded object.
