« Previous Version 3 Current »
Error rendering macro 'rw-search'
Release Notes 23.04.2025
New
  • Revit 2026 Support: Enscape now supports Revit 2026, ensuring a smooth and uninterrupted workflow for users upgrading to the latest version. This update maintains compatibility so you can take full advantage of Revit’s newest features, performance improvements, and stability enhancements without compromising your visualization process.
* With Revit 2026 now supported, Enscape continues to follow its policy of supporting the latest 4 Revit versions (2023–2026). As a result, Revit 2022 will be removed from the installer and no longer supported 3 months from the official release. We recommend updating to a supported version to ensure compatibility.
  • Improved Support for Revit Filters and Graphic Overrides: Enscape now supports Revit Filters and Graphics Overrides for linked models, enhancing visual consistency between Revit and Enscape renderings. The update also includes support for background patterns.
 Note: The “Custom” Display Settings option and accurate override display for nested links are not yet supported; these features will be added in a future release.
  • Update to DLSS 4 Super Resolution with Optimized Presets: Better image quality and same or faster performance compared to previous versions.
  • Trial Survey Prompt After Exit: A survey prompt will now appear after closing Enscape with a trial license, allowing users to provide feedback, delay the reminder, or opt out entirely.
  • Removed Delay on Asset Placement: Eliminated the 0.25-second delay that previously occurred when placing an asset, resulting in a faster and more responsive asset placement experience.
  • Improved Stability Through Better Error Handling: We’ve improved how Enscape handles internal settings issues to prevent crashes during startup.
  • Normal Maps Now Consistently Handled in White Mode: Previously, normal maps were ignored for transparent or glass materials in White Mode, unlike for opaque materials. This update ensures consistent behavior by supporting normal maps only for opaque materials, clarifying rendering expectations in White Mode.
Fixed Bugs
  • Enscape can't start with specific window restore data: Enscape now starts properly.
  • Unable to place an asset right after rotating around a model/surface (even if the camera has stopped)
  • [SketchUp] Material Editor albedo colours are incorrect after switching document: Material Editor albedo colours now accurately reflect the selected material after switching document.
  • [SketchUp][Enscape Impact] Performance map visualization does not respect sections: Performance map is now aligned with section planes.
Known Issues
Views in Artistic modes freeze Enscape window with 3D stereo mode enabled
  • [SketchUp] False Color Visualization does not work well with White mode overrides and breaks switching to None Mode.
  • Revit-Linked project with copied instances renders incorrectly
Archicad
  • DLSS 4 Super Resolution adjustment
  • Bugfixes and stability improvements
Revit
  • Revit 2026 support
  • Enhanced Revit Filters support
Rhino
SketchUp
Vectorworks
