Version 1 Next »
Error rendering macro 'rw-search'
Release Notes 30.04.2025
New
  • Revit 2026 Support: Enscape now supports Revit 2026, ensuring a smooth and uninterrupted workflow for users upgrading to the latest version. This update maintains compatibility so you can take full advantage of Revit’s newest features, performance improvements, and stability enhancements without compromising your visualization process.
* With Revit 2026 now supported, Enscape continues to follow its policy of supporting the latest 4 Revit versions (2023–2026). As a result, Revit 2022 will be removed from the installer and no longer supported 3 months from the official release. We recommend updating to a supported version to ensure compatibility.
Improved Support for Revit Filters and Graphic Overrides: Enscape now supports Revit Filters and Graphics Overrides for linked models, enhancing visual consistency between Revit and Enscape renderings. The update also includes support for background patterns.
 Note: The “Custom” Display Settings option and accurate override display for nested links are not yet supported; these features will be added in a future release.
  • Improved Roughness Value Handling in SketchUp: Improved synchronization between SketchUp and Enscape by introducing a fallback roughness value, ensuring the roughness setting is preserved when a roughness texture is removed.
  • Improved Handling of ArchiCAD Element Properties: To address performance limitations in the ArchiCAD API, we’ve enhanced the element property system to support lazy loading of additional properties when needed, improving stability and preventing future issues related to incomplete data access.
  • Update to DLSS 4 Super Resolution with Optimized Presets: Better image quality and same or faster performance compared to previous versions.
  • Artistic visual mode performance optimization: Removed rendering flush for contours and extended lines, as recent performance improvements eliminate the need for it - even at 4K - reducing potential slowdowns.
  • Trial Survey Prompt After Exit: A survey prompt will now appear after closing Enscape with a trial license, allowing users to provide feedback, delay the reminder, or opt out entirely.
Removed Delay on Asset Placement: Eliminated the 0.25-second delay that previously occurred when placing an asset, resulting in a faster and more responsive asset placement experience. Improved Stability Through Better Error Handling: We’ve improved how Enscape handles internal settings issues to prevent crashes during startup.
  • Normal Maps Now Consistently Handled in White Mode: Previously, normal maps were ignored for transparent or glass materials in White Mode, unlike for opaque materials. This update ensures consistent behavior by supporting normal maps only for opaque materials, clarifying rendering expectations in White Mode.
Before
After
  • New AI Enhancer icon
