Release Notes 07.05.2025
Fixed Bugs
Translate/Rotate/Scale Tool - Material Loss After Discarding Changes: Fixed an issue where deleting an asset using the Translate/Rotate/Scale tool and then discarding changes caused the asset to reappear without its original material.
Archicad - Parallel Light Export Error in Enscape 4.5: Fixed an issue where parallel lights in Archicad failed to export correctly after the transition to Scene Model in Enscape 4.5. Lights now behave as expected, matching the behavior prior to the update.
Incorrect Asset Download Error for Light or Sound Generation: Fixed an issue where an asset download error message was incorrectly shown when a light or sound failed to generate. This no longer triggers an export error.
[Impact] Performance Map Visualization Stuck in White Mode: Fixed an issue where switching off Impact’s cooling visualization failed to restore excluded assets to their original appearance, and switching to 'None' Rendering Style did not reset the view as expected when White Mode was active.
Known Issues
Windows 11 - Crash During Batch Rendering on Some AMD Systems: Enscape may crash during batch rendering when Ray-traced artificial lights are enabled on certain AMD configurations.
