Version 1 Next »
To run Chaos Envision, you have to:
This guide provides steps for installing Chaos Envision. Please check the system requirements before installation.
Get the latest Chaos Envision:  Download Chaos Envision Beta
Running the installer
Before running the installation, make sure your OS account has administrative privileges.
Run the installer. Windows may ask you for permission to run the installer with administrator privileges. Please confirm.
Welcome
Carefully read the End User License Agreement and the Global Consumer Privacy Policy. Click the I accept buttons if you agree to the terms.
Proceed to click the Install button.
If you need to customize your Envision installation, click the Advanced button.
Directories
Here, you can specify the installation paths. Please check if the default folder is correct.
You can specify whether:
  • a desktop icon should be added;
  • association for .envision files should be added so that Chaos Envision can open them directly from explorer.
Licensing
In this step, specify whether the Chaos License Server runs locally or on another machine.
If you select Remote licensing, you have to enter the IP address of your Chaos License Server in the Primary License Server field. Leave port 30304 unchanged. An Alternate License Server can be used for redundancy in case the primary one does not respond. The License Server will not install when the Remote option is selected.
When Local licensing is selected, the Chaos License Server is installed with Envision.
For information about the advanced Chaos License Server installation settings, visit the Advanced Installation page.
Chaos License Server Options
At this step, you can choose where to install the Chaos License Server.
Migrate data during installation – When enabled, it transfers all of your settings made with older versions of the License Server, such as proxy settings, etc. Disabling this option makes a clean install of License Server with any custom settings from previous installations reset to their defaults.
Add firewall exception – Allows the default licensing port (TCP 30304) in the firewall. If you disable it at this step, you must manually add firewall exceptions later.
Chaos Telemetry
Envision installation is successful.
Participate in the improvement decisions for future versions of Envision. No intelligence property is violated when agreeing to participate in the improvement program. Chaos does not gather scenes, assets, materials, etc. For more information, see the Chaos Telemetry page.
Anonymized Telemetry – Includes the most used product functionality and/or parameter values. The data is not personally identifiable and is not tied to the user's individual account.
Personalized Telemetry – Includes the most used product functionality, parameter values, but also contains personally identifiable information tied to an individual user's license. This helps Chaos tailor and optimize the product for better personal use.
Next Step
Go to step 2 to activate your Chaos License.
