This page provides an overview of how Pdplayer integrates with other applications.
Section Contents
Page Contents
Pdplayer can integrate with several other applications. The following are supported:
- Extended Command Line Support – Allows you to have full control over Pdplayer through any external application that can pass it commands.
- Pdplayer and Autodesk Maya – Sets Pdplayer as the default for viewing images and sequences in Maya.
- The Lightwave Plug-in – Allows you to access Pdplayer from the Lightwave Render Globals menu.
- Pdplayer and NUKE – Adds a Pdplayer command to the NUKE Render menu.
