This page provides information on the V-Ray Light Dome Blueprint.
Page Contents
The VRaySunAndSky Blueprint Actor is accessible through the Modes panel by searching for VRaySunAndSky or from VRayForUnreal > Content > BP > Actors > VRaySunAndSky in the Content Browser Tree. Select the Blueprint and drag and drop it in the level.
UI Path:||Modes Tab|| >Search Classes > VRaySunAndSky
UI Path:||Content Browser|| >VRayForUnreal > Content > BP > Actors > VRaySunAndSky
In order to see the VRayForUnreal folder you first have to enable Show Engine Content and Show Plugin Content in View Options of the Content Browser.
VRayLightDome Settings
General
- On - Turns off and on the dome light.
- Use Dome Tex - Enables the use of a .hdr textures for lighting.
- Dome Tex - Specifies the .hdr texture for lighting.
- Dome Tex Rotation - Specifies the horizontal rotation, in degrees, of the Dome Tex.
- Dome Color - Specifies the color of the dome light when Use Dome Tex is disabled.
- Intensity - Specifies the intensity multiplier of the dome light.
- Auto Update - Enables the automatic update of reflections.
