Page Contents
These features are supported by V-Ray for Unreal. Currently supported versions of Unreal Engine are 4.18.3 and 4.19.
For best results when importing vrscene files make sure your scenes are authored and optimized for V-Ray GPU Next or V-Ray 3.6 GPU.
Only Render nodes for V-Ray Next are supported.
Supported Features
Importing vrscene files | |
Cameras | 3ds Max Physical Camera:
VRay Physical Camera
Geometry |
Lights | 3ds Max
Maya
Materials |
Textures | 3ds Max
Maya
Textures with file format:
Other |
Exporting vrscene files | |
Cameras | Unreal
VRay
Geometry |
Lights | Unreal
V-Ray
Materials | Material Instances, V-Ray Material Instances with Parent Materials:
Textures | Texture with Compression Settings:
Additional Notes
- V-Ray rendering of Unreal native materials is not supported. The VRayPBRMtl can be used for a PBR material workflow.
- V-Ray for Unreal only supports normal maps in tangent space.
Light baking through V-Ray for Unreal is currently not supported.
V-Ray for Unreal uses only the V-Ray Hybrid engine.
Animation is currently not supported
Interactive rendering supports only transformation changes( translation, rotation, scale) of objects.
