© Bertrand Benoit
« Previous Version 57 Next »
This page provides information on Cameras and Camera Settings in V-Ray for Unreal.
V-Ray for Unreal works with standard Unreal cameras and Viewports. However, the standard cameras do not provide exposure control. To use exposure control and other real-world camera settings, it is recommended to use the VRayPhysicalCamera Blueprint Actor.
For maximum visual parity between the viewport and the render, it is strongly recommended to disable some of Unreal's post processing and lighting components.
This is done from Show > Post Processing by leaving only Depth of Field, Post Process Material and Vignetting enabled and by disabling Ambient Occlusion from Show > Lighting Component.
The VRayPhysicalCamera is based on the Unreal Camera, therefore all features are present and accessible but only some are supported in the current version. The VRayPhysicalCamera Blueprint Actor is accessible through the Modes panel by searching for VRayPhysicalCamera or from VRayForUnreal > Content > BP > Actors > VRayPhysicalCamera in the Content Browser Tree. Select the Blueprint and drag and drop it in the level.
UI Path: ||Modes Tab|| > V-Ray Assets > VRayPhysicalCamera
UI Path: ||Content Browser|| > VRayForUnreal > Content > BP > Actors > VRayPhysicalCamera
For the VRayForUnreal folder to be visible, you first need to enable Show Engine Content and Show Plugin Content in the View Options of the Content Browser.
Camera Settings
When rendering with V-Ray the following parameters are supported:
Current Camera Settings
  • Filmback Settings
    • Sensor Width – Specifies the horizontal size of the film gate in millimeters.
    • Sensor Height – Specifies the vertical size of the film gate in millimeters.
  • Focus Settings
    • Focus Method – Specifies if Depth of Field (DoF) is applied to the camera. None means no DoF is applied. When Manual is selected the DoF is controlled by Manual Focus Distance and F-number.
    • Manual Focus Distance – Specifies the distance at which objects are in focus.
  • Current Focal Length – Specifies the equivalent focal length of the camera lens in millimeters.
VRay Physical Camera Settings
  • 3ds Max Compatible – Enables 3ds Max compatible exposure control.
  • Enable Exposure – Enables V-Ray exposure control. When enabled, the F-number, Shutter Speed ^-1, and Film Speed(ISO) settings will affect the image brightness.
  • Film Speed(ISO) – Determines the film power (i.e. sensitivity). Smaller values make the image darker, while larger values make it brighter.
  • Shutter Speed S^-1 – Specifies the shutter speed, in inverse seconds, for the still photographic camera. For example, shutter speed of 1/30 s corresponds to a value of 30 for this parameter.
  • F-number – Determines the width of the camera aperture and, indirectly, exposure. If the Enable Exposure option is checked, changing the F-number will affect the image brightness.
  • White Balance – Allows additional modification of the image output. Objects in the scene that have the specified color will appear white in the image. Note that only the color hue is taken into consideration; the brightness of the color is ignored.
Color Mapping
  • Reinhard Burn Value - Specifies the multiplier applied to bright colors.
Examples
Film Speed(ISO)
(Shutter Speed=100; F-number=1.4; White Balance= (1,1,1) )
Film Speed(ISO) = 50
Film Speed(ISO) = 100
Film Speed(ISO) = 200
50
200
Shutter Speed ^-1
(Film Speed(ISO)=100; F-number=1.4; White Balance= (1,1,1) )
Shutter Speed = 50
Shutter Speed = 100
Shutter Speed = 200
50
200
F-number
(Film Speed(ISO)=100; Shutter Speed=100; White Balance= (1,1,1) )
F-number = 1.4
F-number = 4
F-number =8
1.4
8
White Balance
(Film Speed(ISO)=100; Shutter Speed=100; F-number =1.4)
White Balance= (1,0.7,0.6)
White Balance=(0.7,0.8,1)
Neutral
Warm
