This page provides an overview of the VRayMtl and its parameters.
VRayMtl is a very versatile material that allows for better physically correct illumination (energy distribution) in the scene and more convenient reflection and refraction parameters. This material can be easily set up to simulate a huge variety of surfaces from plastics to metals, glass and more by adjusting a handful of parameters.
Furthermore, with VRayMtl you can apply different texture maps, control the reflections and refractions, add bump and normal maps, self illumination and translucency.
When VRayMtl is assigned as a Parent and you want to create a solid material with no refractive, transparent or translucent properties, change the Blend Mode in the Material Property Overrides to Opaque.
VRayMtl Parameters
Diffuse
These are the diffuse properties of the material. Note the actual diffuse color of the surface also depends on the Reflection and Refraction colors.
- DiffuseColor – Specifies the diffuse color of the material.
- UseDiffuseTex – Enables the use of Texture for Diffuse.
- DiffuseTexAmount – Specifies the blend amount between DiffuseTex and DiffuseColor.
- DiffuseTex – Specifies the Diffuse Texture when UseDiffuseTex is enabled.
- DiffuseTex_Channel – Specifies the UV channel index for the DiffuseTex.
- DiffuseTex_OffsetU – Specifies the horizontal offset of the DiffuseTex.
- DiffuseTex_OffsetV – Specifies the vertical offset of the DiffuseTex.
- DiffuseTex_TileU – Specifies the horizontal repetition of the DiffuseTex.
- DiffuseTex_TileV – Specifies the vertical repetition of the DiffuseTex.
- DiffuseTex_Triplanar – Enable triplanar mapping for the DiffuseTex.
- DiffuseTex_TriplanarBlend – Specifies the blend amount between the different Texture projections. Lower values produce sharper transitions between projections.
- DiffuseTex_TriplanarScale – Adjusts the scale of the DiffuseTex when DiffuseTex_Triplanar is enabled.
ReflectionColor=0,0,0; ReflectionGloss=1; FresnelIOR=1.6
Reflection
Specifies the reflection properties of the material.
- ReflectionColor – Specifies the amount of reflection and the reflection color. Any value other than black enables reflection.
- UseReflectionTex – Enables the use of Texture for Reflection.
- ReflectionTexAmount – Specifies the blend amount between ReflectionTex and ReflectionColor.
- ReflectionTex – Specifies the Reflection Texture when UseReflectionTex is enabled.
- ReflectionTex_Channel – Specifies the UV channel index for the ReflectionTex.
- ReflectionTex_OffsetU – Specifies the horizontal offset of the ReflectionTex.
- ReflectionTex_OffsetV – Specifies the vertical offset of the ReflectionTex.
- ReflectionTex_TileU – Specifies the horizontal repetition of the ReflectionTex.
- ReflectionTex_TileV – Specifies the vertical repetition of the ReflectionTex.
- ReflectionTex_Triplanar – Enables triplanar mapping for the ReflectionTex.
- ReflectionTex_TriplanarBlend – Specifies the blend amount between the different Texture projections. Lower values produce sharper transitions between projections.
- ReflectionTex_TriplanarScale – Adjusts the scale of the ReflectionTex when ReflectionTex_Triplanar is enabled.
DiffuseColor=0,0,0; ReflectionGloss=1; FresnelIOR=1.6
FresneIOR
Specifies the Index of Reflection for Fresnel calculations of the material.
- FresnelIOR – Specifies the IOR to use when calculating Fresnel reflections.
- UseFresnelIORTex – Enables the use of Texture for Fresnel IOR.
- FresnelIORTexAmount – Specifies the blend amount between FresnelIORTex and FresnelIOR.
- FresnelIORTex – Specifies the Fresnel IOR Texture when UseFresnelIORTex is enabled.
- FresnelIORTex_Channel – Specifies the UV channel index for the FresnelIORTex.
- FresnelIORTex_OffsetU – Specifies the horizontal offset of the FresnelIORTex.
- FresnelIORTex_OffsetV – Specifies the vertical offset of the FresnelIORTex.
- FresnelIORTex_TileU – Specifies the horizontal repetition of the FresnelIORTex.
- FresnelIORTex_TileV – Specifies the vertical repetition of the FresnelIORTex.
- FresnelIORTex_Triplanar – Enable triplanar mapping for the FresnelIORTex.
- FresnelIORTex_TriplanarBlend – Specifies the blend amount between the different Texture projections. Lower values produce sharper transitions between projections.
- FresnelIORTex_TriplanarScale – Adjusts the scale of the FresnelIORTex when FresnelIORTex_Triplanar is enabled.
DiffuseColor=0,0,0; ReflectionColor=1,1,1; ReflectionGloss=1
ReflectionGloss
Controls how blurry, or glossy, the reflections of the material will be.
ReflectionGloss – Controls the sharpness of reflections. A value of 1.0 means perfect mirror-like reflection; lower values produce blurry, or glossy, reflections.
UseReflectionGlossTex – Enables the use of Texture for Reflection Gloss.
ReflectionGlossTexAmount – Specifies the blend amount between ReflectionGlossTex and ReflectionGloss.
ReflectionGlossTex – Specifies the Reflection Gloss Texture when UseReflectionGlossTex is enabled.
ReflectionGlossTex_Channel – Specifies the UV channel index for the ReflectionGlossTex.
ReflectionGlossTex_OffsetU – Specifies the horizontal offset of the ReflectionGlossTex.
ReflectionGlossTex_OffsetV – Specifies the vertical offset of the ReflectionGlossTex.
ReflectionGlossTex_TileU – Specifies the horizontal repetition of the ReflectionGlossTex.
ReflectionGlossTex_TileV – Specifies the vertical repetition of the ReflectionGlossTex.
ReflectionGlossTex_Triplanar – Enable triplanar mapping for the ReflectionGlossTex.
ReflectionGlossTex_TriplanarBlend – Specifies the blend amount between the different Texture projections. Lower values produce sharper transitions between projections.
ReflectionGlossTex_TriplanarScale – Adjusts the scale of the ReflectionGlossTex when ReflectionGlossTex_Triplanar is enabled.
DiffuseColor=0,0,0; ReflectionColor=1,1,1; FresnelIOR=1.6
Refraction
Specifies the refractive properties to the material. Note that the actual refraction color depends on the Reflection color as well. To use it you must also set the Blend Mode in the Material Property Overrides to Alpha Composite.
Refraction – Specifies the amount of refraction and the refraction color. Any value other than black enables refraction.
IOR – Specifies the index of refraction for the material, which describes the way light bends when crossing the material surface. A value of 1.0 means the light will not change direction.
- UseRefractionTex – Enables the use of Texture for refraction.
RefractionGloss – Controls the sharpness of refractions. A value of 1.0 means perfect glass-like refraction; lower values produce blurry or glossy refractions.
RefractionTex – Specifies the refractionTexture when UseRefractionTex is enabled.
RefractionTex_Channel – Specifies the UV channel index for the RefractionTex.
RefractionTex_OffsetU – Specifies the horizontal offset of the RefractionTex.
RefractionTex_OffsetV – Specifies the vertical offset of the RefractionTex.
RefractionTex_TileU – Specifies the horizontal repetition of the RefractionTex.
RefractionTex_TileV – Specifies the vertical repetition of the RefractionTex.
RefractionTex_Triplanar – Enables triplanar mapping for the RefractionTex.
RefractionTex_TriplanarBlend – Specifies the blend amount between the different Texture projections. Lower values produce sharper transitions between projections.
RefractionTex_TriplanarScale – Adjusts the scale of the RefractionTex when RefractionTex_Triplanar is enabled.
ReflectionColor=1,1,1; ReflectionGloss=1; FresnelIOR=1.6
BumpTex
Specifies the bump properties to the material.
UseBumpTex – Enables the use of Texture for Bump.
BumpTexAmount – Specifies the bump amount.
BumpTex – Specifies the Bump Texture when UseBumpTex is enabled.
BumpTex_Channel – Specifies the UV channel index for the BumpTex.
BumpTex_OffsetU – Specifies the horizontal offset of the BumpTex.
BumpTex_OffsetV – Specifies the vertical offset of the BumpTex.
BumpTex_TileU – Specifies the horizontal repetition of the BumpTex.
BumpTex_TileV – Specifies the vertical repetition of the BumpTex.
BumpTex_Triplanar – Enables triplanar mapping for the BumpTex.
BumpTex_TriplanarBlend – Specifies the blend amount between the different Texture projections. Lower values produce sharper transitions between projections.
BumpTex_TriplanarScale – Adjusts the scale of the BumpTex when BumpTex_Triplanar is enabled.
DiffuseColor= 1,1,1; ReflectionColor=0,0,0; ReflectionGloss=1; FresnelIOR=1.6
NormalTex
Specifies a normal bump map to be used with the material and the bump properties for the normal map.
UseNormalTex – Enables the use of Texture for Bump.
NormalTexAmount – Specifies the normal bump amount.
NormalTex – Specifies the Normal Texture when UseNormalTex is enabled.
NormalTex_Channel – Specifies the UV channel index for the NormalTex.
NormalTex_OffsetU – Specifies the horizontal offset of the NormalTex.
NormalTex_OffsetV – Specifies the vertical offset of the NormalTex.
NormalTex_TileU – Specifies the horizontal repetition of the NormalTex.
NormalTex_TileV – Specifies the vertical repetition of the NormalTex.
NormalTex_Triplanar – Enables triplanar mapping for the NormalTex.
NormalTex_TriplanarBlend – Specifies the blend amount between the different Texture projections. Lower values produce sharper transitions between projections.
NormalTex_TriplanarScale – Adjusts the scale of the NormalTex when NormalTex_Triplanar is enabled.
DiffuseColor= 1,1,1; ReflectionColor=1,1,1; ReflectionGloss=1; FresnelIOR=1.6
Selfillumination
Specifies the emissive properties of the material.
SelfIlluminationColor – Controls the emission of the surface. Any value other than black enables self-illumination.
UseSelfIlluminationTex – Enables the use of Texture for Selfilllumination.
SelfIlluminationTexAmount – Specifies the blend amount between SelfIlluminationTex and SelfIlluminationColor.
SelfIlluminationTex – Specifies the SelfIllumination Texture when UseSelfIlluminationTex is enabled.
SelfIlluminationTex_Channel – Specifies the UV channel index for the SelfIlluminationTex.
SelfIlluminationTex_OffsetU – Specifies the horizontal offset of the SelfIlluminationTex.
SelfIlluminationTex_OffsetV – Specifies the vertical offset of the SelfIlluminationTex.
SelfIlluminationTex_TileU – Specifies the horizontal repetition of the SelfIlluminationTex.
SelfIlluminationTex_TileV – Specifies the vertical repetition of the SelfIlluminationTex.
SelfIlluminationTex_Triplanar – Enables triplanar mapping for the SelfIlluminationTex.
SelfIlluminationTex_TriplanarBlend – Specifies the blend amount between the different Texture projections. Lower values produce sharper transitions between projections.
SelfIlluminationTex_TriplanarScale – Adjusts the scale of the SelfIlluminationTex when SelfIlluminationTex_Triplanar is enabled.
DiffuseColor=0,0,0; ReflectionColor=0,0,0
Opacity
Specifies the opacity of the material. To use it you must also set the Blend Mode in the Material Property Overrides to Translucent or Alpha Composite.
Opacity – Specifies the amount of opacity. Any value below 1.0 makes the object transparent.
UseOpacityTex – Enables the use of Texture for Opacity.
OpacityTexAmount – Specifies the blend amount between OpacityTex and Opacity.
OpacityTex – Specifies the OpacityTexture when UseOpacityTex is enabled.
OpacityTex_AlphaFromIntensity – When enabled, opacity will be set from the RGB intensity of the OpacityTex. When disabled, opacity will be set from the alpha channel of the OpacityTex.
OpacityTex_Channel – Specifies the UV channel index for the OpacityTex.
OpacityTex_OffsetU – Specifies the horizontal offset of the OpacityTex.
OpacityTex_OffsetV – Specifies the vertical offset of the OpacityTex.
OpacityTex_TileU – Specifies the horizontal repetition of the OpacityTex.
OpacityTex_TileV – Specifies the vertical repetition of the OpacityTex.
OpacityTex_Triplanar – Enables triplanar mapping for the OpacityTex.
OpacityTex_TriplanarBlend – Specifies the blend amount between the different Texture projections. Lower values produce sharper transitions between projections.
OpacityTex_TriplanarScale – Adjusts the scale of the OpacityTex when OpacityTex_Triplanar is enabled.
DiffuseColor=1,1,1; ReflectionColor=0,0,0
ClearCoat
Adds a layer on top the material with reflection and bump properties. To use it you must set the Shading Model in the Material Property Overrides to Clear Coat.
EnableClearCoat – Enables the Clear Coat layer.
ClearCoatStrength – Specifies the strength of the Clear Coat layer.
ClearCoatGlossiness – Controls the sharpness of reflections of the Clear Coat layer. A value of 1.0 means perfect mirror-like reflection; lower values produce blurry, or glossy, reflections.
UseClearCoatBumpTex – Enables the use of Texture for Bump of the Clear Coat layer.
ClearCoatBumpTexAmount – Specifies the bump amount of the Clear Coat layer.
ClearCoatBumpTex – Specifies the Bump Texture for Clear Coat layer when UseClearCoatBumpTex is enabled.
ClearCoatBumpTex_Channel – Specifies the UV channel index for the ClearCoatBumpTex.
ClearCoatBumpTex_OffsetU – Specifies the horizontal offset of the ClearCoatBumpTex.
ClearCoatBumpTex_OffsetV – Specifies the vertical offset of the ClearCoatBumpTex.
ClearCoatBumpTex_TileU – Specifies the horizontal repetition of the ClearCoatBumpTex.
ClearCoatBumpTex_TileV – Specifies the vertical repetition of the ClearCoatBumpTex.
ClearCoatBumpTex_Triplanar – Enables triplanar mapping for the ClearCoatBumpTex.
ClearCoatBumpTex_TriplanarBlend – Specifies the blend amount between the different Texture projections. Lower values produce sharper transitions between projections.
ClearCoatBumpTex_TriplanarScale – Adjusts the scale of the ClearCoatBumpTex when ClearCoatBumpTex_Triplanar is enabled.
DiffuseColor= 0,0,0; ReflectionColor=1,1,1; ReflectionGloss=0.6; FresnelIOR=1.6
VRay2SidedMtl
Specifies if the material can transmit light on its back side.
Translucency – Specifies the amount of light being transmitted on the backside of objects. Values other than black will result in translucency.
