© Bertrand Benoit
« Previous Version 4 Next »
This page gives details on how to use the online licensing system for Chaos Group products.
The page LICENSE4EDIT:Online Licensing was not found  -- Please check/update the page name used in the MultiExcerpt-Include macro
Installation
The installer is fairly straight forward and easy to run, but if you need help, please see the Installing the Online License Server page for details on the process. This includes using your Chaos Group account to access your purchased licenses from anywhere online.
USB Dongle and Online Licensing
The Online Licensing system allows you to use seats associated with your Chaos Group account easily from anywhere you can log in to over the internet. If you also have a V-Ray USB License dongle attached to your computer, you can utilize those available licenses within the online system. For more details on this process, please see the Dongle and Online Licensing page.
In most situations, adjusting the Settings for the online licensing system is not necessary. But if you need to adjust something like your connection settings because your using a Proxy server, you can get to these through the drop-down menu in the top right corner of the License Server webpage and choosing Settings. For more details on what settings are adjustable from this area, please see the Advanced Online Licensing Settings page.
Borrowing Licenses for Offline Use
The V-Ray licensing system includes a way to "borrow" a license for offline use. Borrowing a license means you can still have access to your Chaos Group software without needing a USB dongle or an internet connection. For more details on this process, please see the Borrowing Licenses for Offline Use page.
