This page provides information on performing a silent installation of V-Ray Standalone.
Page Contents
A silent installation allows you to complete V-Ray installation without user input during the process using a predefined set of options. To set up a silent installation follow the instructions below.
Windows
- Run the installation file from the command prompt with the -gui=0 argument:
vraystd_adv_3xxxx_x64.exe -gui=0
- Follow the instructions of the install and set-up the installation the way you want to have it on all machines. This will create a file named config.xml in the folder of the installation file.
- Run the installer with the following command:
vraystd_adv_3xxxx_x64.exe -gui=0 -configFile="xml_file.xml" -quiet=1 - This will cause the installer to read the variable values from the xml file and do the installation without asking any questions. If you do not specify the -quiet=1 option, the installer will ask for a confirmation for each variable before proceeding.
Mac OS X
- In the terminal, navigate to the location where you have extracted the vrayastd_adv_3xxxx_snow_leopard_x64.app file.
- Using the cd command, navigate inside the .app file and go to vraystd_adv_3xxxx_snow_leopard_x64.app/Contents/MacOS.
- In the terminal enter:
./vraystd_adv_3xxxx_snow_leopard_x64 -gui=0
- You will be prompted for your password – enter it.
- Follow the instructions of the installer and setup the installation in the way you want it to be installed on all machines. A file named config.xml is created in the folder of the .app file.
- You can now install V-Ray on all machines by navigating to vraystd_adv_3xxxx_snow_leopard_x64.app/Contents/MacOS and using the following command:
./vraystd_adv_3xxxx_snow_leopard_x64 -configFile="config.xml" -gui=0 -quiet=1 -ignoreErrors=1
Linux
- To perform a silent install, first run the installer with the -gui=0 argument:
$ sudo ./vraystd_adv_3xxxx_linux_x64 -gui=0
- Follow the instructions and setup the installation in the way you want it to be installed on all machines. Once the installation is complete a file named config.xml will be created in the folder from which the installation was run.
- You can now use this file to configure your silent install on other machines. To do that run the installer with the following arguments:
$ sudo ./vraystd_adv_3xxxx_linux_x64 -configFile="config.xml" -gui=0 -quiet=1 -ignoreErrors=1
Configuration file
The config.xml file holds configuration information about the settings of the installation. Below is an example of such a config file.
<DefValues> <Value Name="SHOULDUNINSTALL" DataType="value">1</Value> <Value Name="PROGRAMFILES" DataType="value">C:\Program Files</Value> <Value Name="STDROOT" DataType="value">C:\Program Files\Chaos Group\V-Ray\Standalone for x64</Value> <Value Name="STARTMENUPROG" DataType="value">C:\ProgramData\Microsoft\Windows\Start Menu\Programs</Value> <Value Name="WIBU_VERSION" DataType="value">6.20.1230.500</Value> <Value Name="REMOTE_LICENSE" DataType="value">0</Value> <Value Name="INSTALL_WIBU" DataType="value">1</Value> <Value Name="WIBU_General_Gui" DataType="value">0</Value> <Value Name="WIBU_RESTART_REQUIRED" DataType="value">0</Value> <Value Name="CUSTOMIZE" DataType="value">1</Value> <Value Name="REVERT_INSTALL" DataType="value">1</Value> </DefValues>
NOTE: Not all of the settings of the default installer are applicable to the installation of V-Ray Standalone 3.0. Below is a description of the variables used in the installation:
Variable name | Variable description |
STDROOT | Specifies the destination folder for V-Ray Standalone |
REMOTE_LICENSE | Specifies whether the V-Ray license server runs locally or on another machine. 0 - the license server runs locally on the same machine. 1 - the server is on a different machine in the network. |
SHOULDUNINSTALL | Specifies whether or not the installation will uninstall previous version: 1 - uninstalls previous version 0 - skips the uninstallation of previous version |
