This page provides information on the V-Ray UVWGenEnvironment node.
UI Path: ||shop Network|| > V-Ray Material Node > V-Ray > Mapping > Environment
Mapping Type – Specifies the mapping type to use from the following:
Angular
Cubic
Spherical
Mirror Ball
Screen
Spherical (3ds Max)
Spherical (V-Ray)
Cylindrical (3ds Max)
Shrink Wrap (3ds Max)
Wrap U / V / W – Specifies a wrapping mode for U / V / W from the following:
No Wrapping
Wrap
Mirror Tile
Crop U / V / W – Enables or disables cropping in the U / V / W direction.
Duvw Scale – Specifies an additional scale factor for the texture derivatives.
Ground On – Enables or disables the ground plane option.
Ground Radius – When Ground On is enabled, this specifies the radius of the ground.
Ground Position – When Ground On is enabled, this specifies the coordinates for the ground.
