Official release
Date – Mar. 9, 2017
New Features
PhoenixFD
  • Online Licensing support
Rendering
  • Pure Ocean mode that allows to render and preview the ocean or cap mesh without a cache file for each frame
Modified Features
Simulation
  • Optimized Body Force for scenes with multiple moving force geometries
Rendering
  • Modulate the Particle Texture Blend Radius by particle age
  • Abort rendering with Defscanline when a fire/smoke or particle pre-process is canceled
  • Option to disable the "Optimizing Volumetrics" rendering pre-pass
I/O
  • Optimized cache loading times for caches with many particles
Submitter
  • Ability to override the simulation or render output directory of submitted simulations to Backburner
Bug Fixes
PhoenixFD
  • Displacement Volume FadeOut preview won't update after geometry change
  • Crash when plugging PhoenixGridTex for Smoke Opacity of the same simulator
  • Can't add emitter objects to a copied Liquid Source
Simulation
  • Can't use Clear Inside to delete wetmap particles
  • Mist birth from fast moving splash would produce very fast mist jets
  • Mist particles cannot be born when the Splash Amount is zero
  • Crash with Liquid Resimulation and Adaptive grid expanding in a negative direction along an axis
  • User properties that don't end with a newline are not appended to correctly by Phoenix
  • Crash when simulating with a simulator and source having the same name
  • Multiple Body forces with moving objects take very long to simulate each frame
  • Foam appears on the positive simulator borders during liquid resimulation with a moving container
  • Mixing colored liquids with high RGB diffusion draws the colors towards the negative axis directions
  • RGB channel mixing transfers colors across solid walls
  • Moving non-solid bodies create velocities in liquid simulations
Rendering
  • Flickering ocean surface seen in reflections with a moving camera
  • Changing options of the Foam texture does not update in renders until the Ocean texture or the frame is changed
  • Particles in Point Mode are rendered black with V-Ray Adaptive Lights
  • Can't render with Thinkbox Krakatoa when a particle system has 0 particles
  • Can't use Thinkbox Stoke MX's Field Texmap to control the smoke opacity channel
  • Rendering an ocean with a hidden Particle Shader would reset the Ocean Subdivs to 0 after rendering
  • Rendering artifacts in Splash or Bubble mode when looking straight along the X, Y or Z axis
  • Crash when the Particle Shader's Count Multiplier is very high
Submitter
  • Backburner simulation submission does not work with Backburner 2015 and below
