Official release
Date – Feb. 14, 2018
Download – Build 3.10.00
New Features
FLIP Solver
  • Variable viscosity for the FLIP solver. Added to the Sources, Grid Texture and Mapper
  • Default RGB color for Initial Fill Up of the simulation and Initial Liquid Fill of interacting geometries
Particle Shader
  • Use texture RGB color to shade particles in the Particles Shader
Ocean Texture
  • Implemented looping and direct frame index option for the Ocean Texture
Particle Flow
  • Implement caching of the Simulator frames in order to speed up the Phoenix Particle Flow operators
  • Option to delete PFlow particles exiting the Simulator grid when using a Force Operator
3ds Max Integration
  • Support XForm modifiers in Volumetric render mode for the Simulator
  • Added the Flip Y/Z option to the Input rollout in 3ds Max
Improvements
FLIP Solver
  • WetMap particles are now able to stick to deforming and fast moving geometries
  • Improved the thread loading of the FLIP solver
  • Added a Fill Up for Ocean option which can be disabled so Initial Fill Up would not produce liquid voxels and mesh under the fillup level
Volumetric Shader
  • Render negative Fire from caches imported from FumeFX
  • Speed up rendering of scenes with Simulators and Particle Shaders in volumetric mode in 3ds Max
Animation
  • Renamed Cache Start to Cache Origin and Play Start to Timeline Origin
V-Ray RT and IPR
  • Ignore the Optimize Big Volumetric Grids option when the current render is V-Ray RT
Ocean Mesher
  • Allow simultaneous use of the Vertical Fade Level and Fade Above Velocity displacement options
  • Added a hidden cache stretching parameter used to fill air pockets in imported Houdini VDB caches used for ocean meshing - "cachestretchzone"
Ocean Texture
  • Optimized the Ocean Texture
Path Follow
  • Reverse the direction or attraction of FollowPath using a negative Follow Speed or negative Pull Speed
VRScenes
  • Resolve environment variables in Phoenix paths during rendering and not during export
Cache I/O
  • Multithreaded writing and loading of AUR caches. After this change, old versions of Phoenix won't be able to open new caches. New Phoenix versions will open old caches without problems.
  • Merged the OpenVDB DLL into the Phoenix plugin
User Interface
  • Added options for using the Timeline beginning/end as the simulation start/stop frame
3ds Max Integration
  • If the connection to the license server is lost, automatically try to reconnect
SDK
  • Allow providing custom motion blur start and end frame times through the Phoenix SDK
Removed Features
Phoenix FD
  • Dropped support for 3ds Max 2013
Bug Fixes
FLIP Solver
  • Random crash with liquid simulation when particles exit the grid and there is an obstacle on the border
  • Random crash while simulating liquid in contact with moving solid source geometries
  • Hang when not all existing FLIP particle systems are affected by a Phoenix force
  • Solid bodies with Clear Inside kill liquid particles on contact
  • Can't use another simulator as an obstacle to FLIP liquid
  • Restoring liquid simulation with moving simulator creates incorrect velocities at the borders
  • Load & Start of a non-backup liquid cache does not load all the liquid particles
  • Animated object entering the simulator does not emit liquid from its entire surface
  • Liquid cannot wet the inside of a Confine Geometry
Grid Solver
  • Overlapping non-solid Surface Force sources sum their temperatures to very high values
  • Crash with fire/smoke simulations and Confine Geometry if Object Voxels is different than Circumscribed
Simulation General
  • Crash during simulation when Phoenix FD runs out of memory
  • Pressing Start quickly and repeatedly could crash the simulation with enabled Force Preview
  • Repeated Stopping and then Starting the simulation quickly could lead to a crash in 3ds Max
  • Hang when using Load & Start for a Resimulation
  • After a recent Windows Update, simulation in 3ds Max could hang on Start
  • Can't Start a simulation from the toolbar after a failed Restore
V-Ray RT and IPR
  • Crash when the Ocean Texture is used as liquid simulator displacement when rendering with V-Ray RT
Volumetric Shader
  • No scene shadows if Visible to Camera is disabled in Volumetric Geometry mode
  • Fire/Smoke in Volumetric Geometry mode does not render at all when Min Visible Opacity is set to 0.0
Particle Shader
  • Crash when rendering a Particle Shader with Liquid Geometry set to a Simulator used by a Particle Texture with motion blur
  • Particle Shader without particles slows down rendering of the entire scene in 3ds Max
Rendering
  • Crash when rendering a simulator without a cache with Velocity render element enabled
Animation
  • Precise Tracing and Interpolation methods don't work smoothly for particles if the original simulation has SPF above 1
Sources
  • Lag when displaying the Modify panel for Liquid Sources in 3ds Max 2018
  • Wrong texture mapping when using a Grid Texture to transfer data from one simulator to another via a Source
Forces
  • 3ds Max forces need huge multipliers in order to work with Phoenix
Body Force
  • Body Force using geometry with modifiers may not use the proper geometry transform in 3ds Max
  • Crash when a body used by Body Force is moved far away from the simulator
Wave Force
  • Wave Force icon helper position in the viewport affects the simulation
Mapper
  • Mapper's Time-Constant is not working correctly with a mask
Grid Texture
  • Crash when trying to add a quick Paint preset with open Material editor and previously used Grid Texture in it
Ocean Texture
  • Crash when rendering Ocean simulation using V-Ray Standalone with -numThreads command
Ocean Mesher
  • Handled out-of-memory when rendering high-poly Phoenix ocean on large resolutions
VRScenes
  • Particle Shaders are not correctly exported to VRscenes from 3ds Max in Phoenix FD 3.05
PRT I/O
  • Export of PRT files from an unsaved scene does not expand the $(cachedir) macro correctly
  • Cannot export PRT files for negative frames
Particle Flow
  • Some PFlow particles randomly get stuck when exiting the Simulator grid when using a Force Operator
3ds Max Integration
  • Cannot render a simulator with modifiers since Phoenix FD 3.05
  • Sources stop emitting through Particle Flow in 'Use Particle Shape' mode if test operators remove some of the particles
  • Crash when setting a Phoenix Simulator as a Clipper mesh
  • Crash when shift+clicking on a Simulator with the move tool
SDK
  • All Phoenix nodes returned NULL for getPhoenixSDKInterface()
