« Previous Version 5 Next »
How to use Phoenix FD Wetmap
 The video below shows how to use the Phoenix FD Wetmap.
Click the Phoenix FD Simulator → Liquid roll-out → Enable "Wetting".
Click the Phoenix FD Simulator → Output roll-out → Make sure that the Wetmap particles are enabled for export.
Open the Hypershade and create two V-Ray materials.
Create a V-Ray Blend Material and connect the already created V-Ray materials as Base color and Coat 1.
Create a Phoenix FD Particle Texture → Edit Particle Systems → Select the phxParticleTex_set and connect it to the PG_PhoenixFDSimulator_WetMap
Connect the Phoenix FD Particle Texture as a blend amount mask for the V-Ray Blend Material.
Assign the V-Ray Blend Material to your geometry and render.
How to export a Phoenix FD cache to Alembic
 The video below shows how to export a Phoenix FD cache to an Alembic file.
Set Phoenix FD Simulator → Rendering roll-out → Mesh sub-roll-out → Mesh Type: Maya Mesh (not suitable for Ocean).
Double-check to make sure the Velocity Color Set field at the bottom of the Mesh roll-out is set to velocity.
Select the liquid mesh and go to Cache → Alembic Cache → Export Selection to Alembic (option box).
From the Alembic Export Options dialog, make sure Write Color Sets is enabled under the Advanced Options roll-out.
How to export a Phoenix FD simulation to OpenVDB
This video shows how to set the output format to OpenVDB and import the cached simulation inside of a V-Ray Volume Grid.
Click the Phoenix FD Simulator → Output roll-out → '...' button next to the Simulation Save Path option.
Select Browse and navigate to a preferred folder. Set the File Name option and choose OpenVDB Cache from the Files of Type drop-down.
Start the simulation as usual. The output cache files are now OpenVDB instead of AUR.
