Square Enix © Goodbye Kansas
Date – October 16, 2014
Download – No longer available
New Features
Probabilistic Light Sampling
Modified Features
V-Ray
  • Improved the render speed when not using any render elements
  • Improved the Render Settings DR dialog
  • Made V-Ray compatible with Maya's filePathEditor. This change requires not using the '%' symbol in file names any more
  • Made DR asset transfer to work also with osl and simbiont files
  • Made it possible to set zero or negative Dynamic Memory limit, in order to specify the amount of memory V-Ray should not use
  • Added vector and transform attributes for automatically created shading nodes through desc.txt file
  • Improved the anaglyph stereoscopic preview to reduce retinal rivalry
  • Added a warning if the license is going to expire soon
V-Ray RT
  • Implemented more efficient calculation of the AA mask for the progressive render
VFB
  • Added ability to dock/lock History window
GGX brdf
  • Unify the look of the brdf in Maya and 3ds Max
  • The glossiness was rescaled for better control similar to the other brdfs
  • Added a parameter for controlling the tail size of the highlight
  • Added Viewport 2.0 support
  • Support exporting to vrmat
VRayUserColor
  • Make it possible to read named UVW channels and color sets
VRayVolumeGrid
  • Reduced the memory usage with motion blur
VRayDomeLight
  • Added an option to not affect the alpha
VRayToon
  • Line width can now be animated
Maya Fluids
  • Added support for mappable Input Bias for the Color, Incandescence and Opacity
VRaySimbiont
  • Now registered as a node only on Windows, since it's not supported on Linux/OSX
VRayMesh
  • Removed the parameter "Don't set normals" from the AE for Maya>=2013. It was fixing an issue with older Maya versions
  • Create proxy now exports UV map to the proxy preview mesh
Bug Fixes
  • Fixed the UI of Spherical Harmonics GI to not flood the script editor with messages
  • Fixed a rare crash when computing mip-map levels for non-square texture
  • Fixed non-tiled bitmaps to not take more RAM than they actually need
  • Fixed V-Ray standalone to not always auto-save images in the history
  • Fixed a crash when overloading a material with the same one (from the V-Ray material override attributes)
  • Fixed incorrect rendering of volumetrics with are lights
  • Fixed a crash when image sampler max. subdivs are zero
  • Fixed a bug with the render region when RT is running in the viewport
  • GLSL shader parameters were not updated when rendering animation
  • PTex baking wasn't working properly in animation
  • PTex baking was producing images with wrong normals when looking from particular angles
  • Image sequence was broken with PTex textures
  • PTex textures were not automatically connecting a frame expression to the image sequence
  • PTex baking was starting to render, even if there is no image file name specified
  • V-Ray was still trying to render when local machine and all hosts are disabled for DR
  • Nurbs were crashing if V-Ray fails to evaluate them
  • NURBS didn't support changing the number of CVs in animation
  • Particle were crashing with the mountain lion OSX build
  • Particles were crashing when using the Sprite render type with motion blur
  • GI post-processing settings were applied even with disabled GI
  • V-Ray for Maya was producing incompatible irradiance maps in animation mode, which can't be used with the stand-alone/DR
  • VRayLightDome was not rendered when "Auto Render Clip Plane" for the camera is off
  • Opening VRayFastSSS2 map now excludes the frame number in the file name, since it's automatically appended by V-Ray
  • VRayMesh: alembic meshes exported from RealFlow didn't read velocity data when imported as proxy
  • VRayMesh: VRayVertexColors was not able to find the correct color set when using separate files for every frame
  • VRayMesh: fixed a crash with show whole mesh with specific hair alembic file
  • Fixed a freeze if a bitmap file name contains '<' and '>' right next to each other by mistake
  • VFB: Render view region was not rendered in the VFB
  • Fixed incorrect depth of deep images rendered with camera motion blur
V-Ray RT
  • Fixed showing of already unloaded proxies
  • Connecting material to the VRayMeshMaterial slot was replacing materials for non proxy objects
  • Fixed a crash when changing the environment color of a camera with image plane
  • Fixed an issue with the sub-pixel mapping option
V-Ray RT GPU
  • Objects with primary visibility off were also not visible in the reflections
  • The Ramp texture was not working with OpenCL
  • Properly support the samplerInfo flipped normal mode
  • Fixed the uvCoord output of the samplerInfo texture
  • Fixed a crash with proxies without vertex normals
  • Fixed a crash when moving the time slider on a scene with velocity RE and motion blur turned off
V-Ray RT Viewport
  • Fixed various random crashes
