This page provides information on how to get V-Ray up and running.
Setting up V-Ray for 3ds Max comprises of few steps: downloading, installing and licensing and then setting V-Ray as the renderer inside 3ds Max.
Check if you hardware matches the minimum requirements to run V-Ray: System Requirements
Try V-Ray
If you are a trial user, check how to download and install V-Ray for 3ds Max on the Trial Installation of V-Ray for 3ds Max page.
Install V-Ray
If you are an edu/commerical user, check how to download and install V-Ray for 3ds Max on the Installation page.
License Settings
Detailed information about Licensing can be found on the Licensing page.
