This page provides information about the Raw Total Light in V-Ray for Cinema 4D.
The Raw Total Light Render Element is the sum of all raw lighting (both direct and indirect) in the scene, without any diffuse details. This render element is useful for changing the appearance of the scene's lighting in a compositing or image editing application.
Properties
Enable Deep Output – Specifies whether to include this render element in deep images.
Color Mapping – Applies the color mapping options specified in the Color mapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default.
Consider for Aa – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections – Applies the post render color adjustments made from the VFB.
