©BBB3viz
« Previous Version 2 Next »
Official release
Date – 22 May, 2018
Download – Build 4.02.04
New Features
VRayMtl
  • Add "Metalness" parameter for easy support of PBR workflows
VRayLightSelect
  • Add "indirect", "indirect diffuse" and "indirect specular" modes
VRayOSL
  • Support for OSL scene attributes
  • Ability to attach textures to arbitrary OSL parameters
.vrscene exporter
  • Initial support 3ds Max 2019 native OSLMap
V-Ray
  • Add dialog to confirm file overwriting with Separate Render Channels
Modified Features
V-Ray
  • Always use low thread priority in an interactive GUI session
  • Change the default motion blur "Interval center" to 0.0
  • Optimize object space bounding box calculation for meshes instances
  • Submit to V-Ray Cloud dialog implements scene analysis for incompatible features
V-Ray GPU
  • Expose the "Undersampling" parameter and make it adjustable during IPR
  • Add support for basic UVW transformations for Bercon noise texture
  • Add support for the "Keep continuity" option
  • Add vendor information in the "C++/CPU" device type
  • Enable QMC for CUDA CPU
  • Gray-out texture button for direct illumination of the VRayLightMtl material
  • If there are no CUDA devices, "C++/CPU" should be used
  • Improve GPU Light Linker memory efficiency
  • Remove the warnings for non-physical features when exporting to a .vrscene
VRayInstancer
  • Instances are rendered with the particle materials instead of the instanced geometry material
  • Optimized instancing speed
VRayFastSSS2
  • Improve the sampling to reduce noise
VRayProxy
  • Alembic instances/objects to work with MultiSubTex random by instance id
VRayScene
  • Add Lights support
VRayVolumeGrid
  • Add warning message box when opening the deprecated AURA 1 caches
  • Right-align the text in the Show File Name window so the file name can be seen if the text overflows
  • Speed up and use less memory for Grid-Based Self-Shadowing of huge sparse OpenVDB grids
  • Speed up Grid Smoothing of OpenVDB grids
  • Speed up the Optimize Big Volumetric Grids pre-process of OpenVDB grids
VFB
  • Add "Image info" window for VFB history context menu
  • Add Exposure Highlight Burn color correction to vfbControl (#sethighlightburn/#gethighlightburn)
  • Add option to disable replacing # with frame numbers for separate render channels
  • Export color corrections settings for .vrscenes
V-Ray Toolbar
  • The hair material button creates VRayHairNextMtl;
V-Ray scene converter
  • Convert Mental Ray Lighting Analysis render effect to VRayLightingAnalysis render element
  • Enhanced Corona material and texmaps conversion
  • Convert 3ds Max light meters to VRayLightMeter
Bug Fixes
V-Ray
  • Adaptive dome light artifacts with "cast shadows" off
  • Artifacts with adaptive dome light when rendering with V-Ray Standalone
  • Crash with AXYZ ANIMA meshes and VRayVelocity render element
  • Embree crashes when building trees on machines with many cores
  • Error while building Embree tree when moving VRayFur in IPR
  • Exported scene from 3ds Max renders very slow in V-Ray Standalone due to excessive sampling of hairs
  • Less than normal samples are calculated with Use camera path with Irradiance map GI engine
  • Light Cache is about 3 times slower since V-Ray Next, Beta 2 compared to V-Ray 3.60 with transparent materials
  • Overbright pixels (fireflies) with adaptive dome light
  • Resumable rendering doesn't work correctly with adaptive dome lights and auto exposure
  • The final info message in the VFB is "Hair and Fur" if you have Hair and Fur in the scene
  • The output image vrayInfo/renderTime EXR attribute is not correct
  • Standard materials don't render correctly when nested in other materials
V-Ray Standalone
  • Standalone: Lens effects from vrscene are not applied with -display=0 option
V-Ray/V-Ray GPU
  • 3ds Max crashes if Start IPR button is hit during render warmup
V-Ray IPR
  • Crash when modifying Multi/Sub-Object sub material on VRayInstancer instanced objects
  • Crash with VRayDisplacementMod with texture map
  • Not keeping the aspect ratio when Fit to VFB is enabled
V-Ray GPU
  • A3ds Max UI becomes unresponsive after disabling VFB region rendering during IPR
  • Adaptive lights render noisier a specific scene
  • Artifacts with adaptive dome lights
  • Artifacts with VRayAerialPerspective in specific light setup
  • Auto exposure's "Transfer to camera" button does not work
  • Black outlines with refractive VRayMtl and VRayFastSSS2
  • Bump is always tiled
  • Color correction remap does not work properly
  • Crash at every frame after the first one with environment map assigned both to the environment and a dome light
  • Crash on calculating mip-map levels for missing bitmaps
  • Crash when changing materials in VRayOverrideMtl
  • Crash when scrubbing the time slider due to material anisotropy
  • Crash while resizing the VFB during IPR session
  • Crash with a specific scene with VRayClipper
  • Crash with MultiSub material when deleting invisible to camera geometry during IPR
  • Crash with specific VRayProxy without normals and displacement
  • Crash with VRayEdgesTex in opacity slot in specific material setup
  • Crash with VRayFur with "Lock to surface" and "Ignore scale" enabled
  • Custom output channels of Color Correction are not exported properly
  • Different render of reflective material when Dome Light's "Cast shadows" is off
  • Effects result is missing when saving through 3ds Max Output
  • Extend stereoscopic rendering options (Eye distance, Focus method, Swap left/right, Follow VR headset)
  • Forest Color is not working when used with only default color and no texmaps
  • Inconsistent Forest Color randomization between DR slaves
  • Incorrect fog color of VRayEnvironmentFog when light's shadows are turned off
  • Incorrect output FOV with Sperical panorama camera with overriden Vertical FOV in 3ds max 2019
  • Instanced VRayProxies with VRayInstancer are missing in the first frame of V-Ray GPU production animation
  • Occasional crash when working with Physical Camera in IPR session
  • On-demand mip-mapped textures render with lower resolution on GPU when used in Bump, Displacement and Metalness
  • Refraction with nested volumes is wrong
  • Rendering differently spherical camera
  • Scene loads slower compared to CPU
  • The "*_tex_mult" parameters of the SettingsEnvironment plug-in are ignored
  • The "RGB and alpha source" rollout settings in VRayHDRI are ignored
  • The "Use roughness" option in VRayMtl has no effect
  • Unhandled exception when modifying one of the VRayInstancer lists during IPR
  • Unhandled exception when rendering with disabled VFB
  • Unahndled exception with Particle flow and motion blur in a scene with zero vertices meshes
  • Very small triangles disappear from the rendering
  • VRayDirt's "double sided" parameter is not working correctly
  • VRayScannedMtl is black during the mip-map on demand loading phase
  • VRayScannedMtl renders black in specific scene
  • VRayScannedMtl with triplannar mapping produces artifacts with specific geometry
  • Wrong opacity with VRayBlendMtl and VRay2SidedMtl
  • "Visible to camera" does not work with volumetrics
  • Remove "non-physical" warnings
  • GPU CUDA AA Gaussian not matching CPU;
VRayDenoiser
  • "Update" button is not working as expected during IPR
  • VRayDenoiser/vdenoise.exe: Denoising produces blurry artifacts when threshold is set to 0.0
VRayFastSSS2
  • Material in Raytraced (refractive) mode is lit by excluded V-Ray light with Cast Shadow disabled
VRayGLSL
  • "vr_Position" returns wrong results
  • Wrong normals in GLSL shaders
  • Wrong shadow calculation when used as opacity map;
VRayHairNextMtl
  • NaN pixels caused by negative value for the diffuse amount parameter
  • Randomization dye hue parameter renders differently with V-Ray GPU
  • The subdivs parameter should be dimmed when "Use local subdivs" is disabled in the Global DMC settings
VRayInstancer
  • Wrong instances rotations with PRT source particles
VRayLightMeter
  • Missing text ("Error" instead of "Error tolerance") in the UI for 3ds Max 2016 and older versions
VRayLightSelect
  • Fix artifacts in with adaptive dome light when mode is different from "Full"
VRayOptionRE
  • Add "Whole image" ability to the "exr data window" option to save the whole image even if a region is rendered
VRayOSL
  • OSL shading system leaks memory
  • The 'camera:fov' OSL attribute must be in degrees
  • VRayOSLTex crashes if attached to VRayEnvironmentFog
VRayPluginNode
  • Using in IPR may leave render license engaged
VRayProxy
  • Preview cache is not cleared when override is specified
VRaySoftBox
  • Gradients UI controls are not working since V-Ray Next, Beta 2
VRayVolumeGrid
  • Enabling GI has no effect with "Disabled" scattering on volumes with V-Ray GPU
  • Even when there aren't active render elements warnings appear in the V-Ray messages
  • Incorrect motion blur on moving grid with a static or moving camera locked to it with V-Ray GPU
  • Incorrect render result due to Channel Smoothing option set to Temperature with V-Ray GPU
  • Light Cache renders differently on GPU compared to CPU in Volumetric Geometry mode
  • Shadow Strength parameter doesn't work with scattering set to "Ray-traced" with V-Ray GPU
  • The VRayVelocity render element is not rendered in Volumetric Geometry mode if Motion Blur is off
  • Wrong render of VDB caches which have a background value outside the tree min-max range
VFB
  • 3ds Max crashes when copying an image from VFB to the clipboard and then copying text from Layer/Scene explorer
  • Image shifts one pixel up/down when dragging the separator line during horizontal A/B compare
  • Using the drop-down channels list causes crash when renderring with disabled memory frame buffer, but with raw output preview enabled
.vrscene exporter
  • Composite texture with layers with no texture attached produces invalid vrscene files
V-Ray Bitmap to VRayHDRI converter
  • Tiled EXR conversion tool (img2tiledexr.exe) discovery error
  • Some camera settings are not transferred when converting Standard Camera to Max PhysicalCamera or VRayPhysical camera
V-Ray Toolbar
  • 3ds Max crashes when creating a mesh lights from grouped objects
vdenoise.exe
  • The denoiser tool doesn't preserve the pixel aspect
.vrscene exporter
