Square Enix © Goodbye Kansas
Version 1 Current »
Official Release
Date – March 22, 2018
DownloadBuild 3.60.04
New Features
VFB
  • Track mouse can now be locked to a specific position
Cryptomatte
  • Support for DWA compressed OpenEXR files
XGen
  • Support for multi-interval motion blur with a changing number of vertices
Modified Features
IPR
  • Out of process IPR server will now use the number of threads from the Maya UI
Python
  • Post translate Python script now supports complex parameters like Instancer plugin's instances
Bug Fixes
VRaySun
  • Fixed wrong render with manual position
  • Fixed crashes with multiple suns and manual position
VRayProxy
  • Fixed slow loading of proxies
  • Fixed incorrect render with animated start offset and playback speed
V-Ray
  • Fixed incorrect camera motion blur in the first frame of an animation
  • Fixed Auto Update option in Swatch Properties
  • Fixed "not expected as texture input" warning when exporting vector plugs
  • Fixed "Don't save image" affecting EXR settings in exported vrscenes
  • Fixed start/end frame overrides in batch when the scene was saved with "Specific Frames" option
  • Selecting a render element will no longer open the Attribute Editor if it was closed
VRaySky/VRayDomeLight
  • Fixed Viewport 2.0 preview in Maya 2018.2
VrayMtl
  • Fixed fog multiplier not working in animation
VRayStereoscopic
  • Fixed an error when attaching a stereo camera attribute when no VRaySettings node is present
VRayFur
  • Fixed selection in Viewport IPR
VRayVolumeGrid
  • Fixed wrong texture mapping on Maya fluids with Auto Resize
