Square Enix © Goodbye Kansas
Version 1 Current »
Official Release
Date – Oct. 12, 2017
DownloadBuild 3.60.02
New Features
V-Ray
  • Added an option for setting a maximum mip-map resolution for draft renders
VFB
  • Added vfbControl -testresolution command
  • Added vray hideVFB command
Bug Fixes
V-Ray
  • Fixed Render Setup not working with render elements on Maya 2018 Update 1
  • Fixed error when rendering NURBS object
  • Fixed crash with Render Setup with VRayExtraTex
V-Ray IPR
  • Fixed fatal error with a curve connected to a point light's radius
  • Fixed freeze with post effects enabled
  • Fixed constant refreshes with physical camera when moving the timeline
VFB
  • Fixed the copy to clipboard button not copying the whole final image
  • Loading a Multichannel EXR now loads the additional channels
  • Fixed Maya scene marked as changed when the VFB loses focus
VRayProxy
  • Fixed wrong number of geometry samples with certain proxy files
  • Fixed velocity on proxies from Houdini with Subdivision
VRaySoftbox
  • Fixed wrong rendering in animation
VRayTriplanar
  • Fixed triplanar texture not working with VRayUserColorTex texture
  • Fixed artifacts with triplanar used for bump
VRayFur
  • Fixed crash with textured parameters
VRayPluginNode
  • Fixed IPR updates
VRayVolumeGrid
  • Fixed Maya fluids with Auto Resize rendering with motion blur during resize
MultiMatte
  • Color corrections are no longer applied to MultiMatte
Denoiser
  • Fixed denoiser interrupting command line render
ply2vrmesh
  • Fixed wrong normals when converting from geo/bgeo
