Square Enix © Goodbye Kansas
Version 1 Current »
Date – May 31, 2016
DownloadBuild 3.40.01
New Features
V-Ray
  • Add V-Ray Denoiser Render Element
  • ExtraTexInt / ExtraTexFloat Render Element similar to ExtraTex, but for integer/float textures
  • Support for integer user attributes
  • Add another deep fragment merge mode, "None", where fragments are not merged at all
  • VRayMultiSubTex texture like in 3ds Max
  • Add a section in the render settings for controlling the cache size for tiled textures
General
  • Support for Maya 2016 Extension 2 (2016.5)
  • Rendering support for PartIO Visualizer (see http://www.disneyanimation.com/technology/partio.html)
  • Added support for spriteNumPP parameter of particle systems
  • Support for animating the "Eye Distance" and "Focus Distance" parameters of the V-Ray Stereoscopic Camera
V-Ray GPU
  • Initial support for bump mapping with procedural textures
  • Orthogonal camera support
samplerInfo node
  • Added new float output that returns a random number by geometry shell for meshes
VRayStochasticFlakesMtl
  • Support for colored flakes texture
VRayAerialPerspective
  • Filter color for the VRayAerialPerspective
XGen
  • Per spline texture mapping
Bifrorst
  • Support for foam particles in Maya 2016
Modified Features
V-Ray
  • Faster rendering with the light cache
  • Faster rendering of objects visible behind multiple panes of glass
  • Enabled support for processor groups by default
  • Support for the -rep option of Maya batch rendering command
  • Made the 2016 Material Viewer to use low thread priority
  • The default tessellation mode for displacement/subdivision is now "pre-tessellated"
  • Better warning messages when unsupported texture is connected to some plug
V-Ray IPR
  • Faster light updates
  • More responsive updates
  • Region changes without restarting the render are now possible
  • Decreased the initial resolution for undersampling
V-Ray GPU
  • Improved auto texture resizing for better memory usage and quality
  • Support for the Bias attributes for VRayDirt
  • Improved importance sampling algorithm, removed the "texture subdivs" parameter
VRayProxy
  • Try to preserve already attached materials when changing the proxy file
VRayScene
  • Hair preview
  • Support for visibility overrides
  • Support for render layer material overrides
VraySunSky
  • Added attribute for ground blending
  • Added vertical offset for the sky texture
VRayFur
  • Faster strand generation for fur
VRayFur styler
  • Added option for symmetric painting
VRayMtl
  • Improved sampling for GGX BRDF
  • Exposed the opacity for VRayMtl for lookDev view in the Property Editor
V-Ray Object Properties
  • Warnings related to visibility lists now print more information
V-Ray Shelf
  • Extended the Create V-Ray Toon button to allow VRayToon node selections
VRayVolumeGrid
  • Implemented auto-reduction of the VRayVolumeGrid preview
Material Viewer
  • Added support for the new "tumbling camera" in Maya 2016.5
Texture Baking
  • Added dropdown for selecting UV set in V-Ray baking options
General
  • Added support for the Light Editor in Maya 2016.5
  • Added elliptical filtering options to File node
Maya Hair
  • Added a parameter to limit the minimum width of hair strands
Bug Fixes
V-Ray
  • Fixed negative pixel values in specific scenes
  • Fixed random render results on a specific scene with Embree enabled
  • Fixed differently colored surface patches with 2D displacement mapping in specific scene
  • *.exr image files were saved with incorrect pixel aspect ratio metadata
  • The default OpenSubdiv depth is now 2
  • The Renderable camera list is not refreshed
V-Ray GPU
  • Using GPU as production with DR will print a warning
  • Fixed wrong shading for light cache with displacement, subdivision and VRayProxy
  • Fixed slow rendering of motion-blurred hair with light cache
  • Fixed high memory usage with proxies, hair, particles, displacement and subdivision in animation
  • Fixed crashes and leaks with displacement, subdivision and proxy
V-Ray IPR Viewport
  • Fixed V-Ray IPR viewport rendering only a region in the lower left corner
VRayScene
  • Fixed VRayScene node randomly failing to load IES files
  • Node visibility was not handled properly
  • Fixed error when loading files with "." in the name
  • VRayScene node was deleted with the Delete History command
  • Relative paths are only resolved for the first loaded .vrscene
  • Fixed fatal error with imported .vrscene files and Render Stats
VRayProxy
  • Fixed slow rendering for Alembic files with motion blur enabled (specific scene only)
  • The GPU preview didn't work properly with instancing
  • The GPU Mesh preview should disable the Alembic subdivision
  • Added support for V-Ray user attributes when displaced/subdivided
  • The shader names were not always set correctly with "use full names"
  • Fixed wrong hair vertices in GPU preview
VFB
  • Bucket rendering with Fixed/Adaptive sampler was very slow in MacOS ElCapitan
  • Now shows up in the Atmospheric Render Element
VRayLight
  • Multiply by light color doesn't work in temperature mode
  • Multiply by the light color option always renders green light
VRayFastSSS2
  • Fixed infinite recursion with SSS2, raytraced single scatter and surfaceLuminance
  • Scene renders differently with render elements enabled vs. disabled
  • Fixed wrong result with mapped Hilight Glossiness
VRayFur
  • Fixed very high memory usage while rendering in V-Ray IPR viewport
  • Fixed crash when deleting VrayFur properties node while rendering in IPR
VRaySky
  • Fixed wrong parameter label in the VRaySky texture
VRayMeshMtl
  • Fixed not refreshing connections when a material is drag-and-dropped from Hypershade in 2016
  • Fixed material connections not refreshing with Copy Tab
  • Fixed issues with the Maya Attribute Editor
VRayTriplanar
  • The VRayTriplanar texture doesn't properly show it's UV placement attribute
VRayFalloff
  • Fixed issue with multiple VRayFalloff textures attached to a material
VRayVolumeGrid
  • The voxel preview did not update when changing loadNearest and flipUpAxis
  • Frame blending did not work properly with VRayVolumeGrid grid that changes size
  • Fixed animation rendering garbage after the cache sequence ends
  • Fixed wrong shading with Geometry Volumetric render mode in MultiMatte render element
  • Two VRayVolumeGrid in a vrscene sharing a cache with offset animation rendered the same frame
Miscellaneous
  • Fixed wrong Instancer primary visibility per particle override with specific scene
  • Fixed invalid colors with the Cook-Torrance BRDF
  • Fixed Material override extra attributes not updating properly in a specific case
  • Fixed Material override extra attributes not refreshing when accessed from VRaySwitchMtl
Maya Batch
  • Fixed wrong exit code when VRAY_TERMINATE_ON_FRAME_END is enabled and a license error occurs
  • Command-line width/height override flags were not taken into account
Bifrost
  • Fixed crash when trying to render as VRayMetaball
  • Better support for Bifrost Aero
XGen
  • Animated Alembic archives were always looped
