Square Enix © Goodbye Kansas
Version 1 Current »
Official update
Date – April 15, 2016
DownloadBuild 3.30.02
Bug Fixes
V-Ray
  • Fixed OpenSubdiv slow-down with meshes missing uv/color data in some areas
  • Fixed invalid colors produced by the subdivision for meshes with zero-length normals
  • Layer overrides were not working on the "Renderable Camera" option
  • The GUI license was not released immediately after .vrscene export without rendering
  • Renderable curves now don't impose 2000 segments limit
  • The progressive sampler didn't change the AA type in baking for big textures to preserve memory
  • Local subdivs have been disabled for swatch rendering
  • Fixed a crash with tiled OpenEXR and TIFF files on Linux
  • Fixed a crash when exporting vrscene file on Linux
  • Fixed undo not working after vrayUpdateVRayCommonGlobalsTab command
V-Ray RT Viewport
  • Fixed issues with the camera pan and zoom
V-Ray RT / GPU
  • Fixed a crash with the GPU production render
VFB
  • The color corrections were always applied to single channel EXR
Quick Settings
  • The sampling values were not matching the new V-Ray defaults
VRayProxy
  • Fixed a crash in batch on Linux when the proxy file fails to load
  • The proxy material was not changing the current material connection properly
  • The shader names in the proxy material were not always set correctly with "use full names"
  • Fixed slowdown with alembic in a specific scene
  • Fixed a crash with alembic particles when scrubbing in Viewport 2.0
VRayScene
  • The .vrscene file was not released after loading
  • The viewport preview was not updated for animated scenes
VRayVolumeGrid
  • Fixed the registering in the Maya's File Path Editor
  • Fixed random artifacts with the heat haze render mode
  • Fixed the heat haze render mode to work with the probabilistic rendering option
VRayLightDome
  • Fixed error message appearing when assigning texture to VRayLightDome
VRayMtl2Sided
  • Fixed slow rendering with GI
VRayFastSSS2
  • Fixed invalid colors produced in some rare cases
VRayStochasticFlakesMtl
  • Fixed missing subdivs slider
VRaySwitchMtl
  • Fixed wrong rendering if there are empty sub-material slots
VRayTriplanar
  • Fixed artifacts with the "Random..." options on Linux/OSX
  • Fixed slow rendering when used for displacement
  • Fixed texture offset and rotation now work
VRayCurvature
  • Fixed issue causing the usage of geometry normals instead of smooth normals for opaque objects
Geometry
  • Animating transform will not trigger geometry export in Maya 2016
Installer
  • Previous versions of V-Ray could not be uninstalled properly on OSX
  • Windows Installer was missing vraymayaspawner.exe in standalone install mode
