Square Enix © Goodbye Kansas
Version 1 Current »
Date – February 26, 2016
DownloadBuild 3.30.01
New Features
V-Ray
  • New adaptive sampling algorithm for better detection and clean-up of noise in the image
  • Added option for automatic subdivs calculations for materials and lights
  • Better GI distribution (more robust handling of reflective GI caustics) for interior scenes
  • Better sub-pixel filtering for the progressive sampler
  • Dynamic noise threshold for the progressive sampler for more even noise distribution
  • Internal spectral color space switched from CIE RGB to sRGB
  • General speed improvements
  • Ability to use the GPU for production rendering
  • Support for Ornatrix beta
  • Implemented raytraced rounded corners that work also at intersections of different meshes
  • New Multi Matte ID render element
  • Material select render element works with volume shaders assigned to shading groups
  • Write the VFB stamp information in the OpenEXR metadata
  • Support the standard Scene Assembly options in the Render Settings
  • Batch Render supports -iip (ignore image planes) flag
  • Support for animation (bezier) curves as remap texture nodes;
VRayRT GPU
  • Support for Projection node
  • Support for VRay User Scalar/Color
  • Support for bitmap aperture to the physical camera
  • Support for VRaySwitchMtl
  • Initial support for GLSL texture shaders
  • Support for hair and particles from VRayProxy objects
  • Speed up loading of resized textures to the GPU
VFB
  • Ability to load color corrections from VFB history
  • Ability to export the color corrections settings as single LUT (.cube) file
VRayScene
  • New Maya node that allows import of an entire .vrscene file as one object with a viewport preview
VRaySun / VRaySky
  • New sky model (Hosek et al)
  • Added ground color parameter
VRayAerialPerspective
  • New aerial perspective atmospheric effect
VRayFalloff
  • New texture that creates a falloff gradient based on the viewing direction, fresnel effect, etc.
VRayTriplanar
  • New texture for triplanar mapping
VRayStochasticFlakesMtl
  • New stochastic flakes material for car-paint like materials
VRayClipper
  • Ability to clip against arbitrary meshes
VRayProxy
  • Added a GPU preview mode for faster viewport performance and less memory consumption
VRayVolumeGrid
  • Added a viewport preview of the grid content
  • Added ability to customize the import of the native vdb/f3d channels
  • Implement support for nameless VDB channels
  • Added support for importing VDB caches from FumeFX 4
  • Added options for probabilistic volume sampling
SynColor
  • Enabled support for sRGB and gamma correction profiles
VRayGLSLMtl / VRayGLSLTex
  • Added support for Hair, Cook-Torrance, GGX and subsurface BRDFs
  • GLSL shaders are now compiled to binary code through LLVM for increased render speed
Texture Baking
  • The Ptex texture baking now works with V-Ray proxy objects
  • Ability to bake objects as a particle cloud to a .vrmesh file
File node
  • Implemented support for signed integer TIFF images
Instancer
  • Ability to override the visibility, object id, frame, user float/color of the instanced objects using per particle attributes
samplerInfo node
  • Added new output that returns random color per instance
XGen
  • Added support for displacement, subdivision and VRayUserColor
  • Added support for frame animation of archive
  • Added the ability to cache XGen collections to .vrscene and general export performance improvements
Miscellaneous
  • Support for the new Look Development shading nodes and simplexNoise in Maya 2016 Ext1
  • Added the lens effects filter generator tool in the installation
Modified Features
V-Ray
  • Optimized UI and new default Render Settings options
  • Faster rendering of particle system with sphere/point rendering mode
  • Ability to handle more than 1000 UDIM tiles per UDIM texture
  • Improved multi-threaded performance for UDIM textures
  • Better management of many tiled OpenEXR and TIFF files
  • Faster activation of the mouse tracking with the progressive sampler and RT
  • Updated the OpenSubdiv library to version 3.0 with faster subdivision performance
  • VRayLightMesh now supports OpenSubdiv subdivision
  • Object select render element can work with more than one object ID
  • Support for per instance unshared UV sets
  • VRAY_TERMINATE_ON_SEQUENCE_END environment variable that terminates the process after a sequence is finished rendering
  • Support the viewport wireframe color object override for V-Ray lights
  • Made it easier to call V-Ray MEL commands from Python
  • Added UI options for creating empty sets for all V-Ray object properties in the Create/V-Ray menu and in the V-Ray shelf buttons
  • Support for intensity curves with the Maya standard lights
V-Ray RT GPU
  • Improved AMD GPUs support
  • Optimized bitmap memory management
  • Improved light cache with support for motion blurred hairs
  • Optimized the "Compiling geometry..." phase on scenes with many nodes
  • Optimized material rendering
  • Print warning for unsupported textures
V-Ray RT GPU CUDA
  • Prevent kernel recompilations while RT is running
VFB
  • Added new options to the vfbControl command to fully control the VFB window form MEL
  • Use Maya's native open/save dialogs in the VFB
  • Added tooltip with the image comment to the images in the VFB history
  • Adding/removing render elements will not delete the contents of the frame buffer
VRayMesh
  • Support for more then two motion blur samples with Alembic files
  • Faster point cloud rendering
  • Ignore the subdivision attributes of Alembic files when making a Maya mesh
VRayFur
  • Added a global "scale" parameter that affects the length, the thickness, the gravity and the density of the fur
VRayDisplacement / Subdivision
  • The "Static geometry" attribute was renamed to "Geometry generation"
Render Settings
  • The translator default path now doesn't expand the layout
  • Added an option to globally turn on/off subdivision surfaces, hair, proxies, particles and plugin geometry
VRayIESLight
  • Support for IES files with the latest format LM-63-2002
VRayMtl / VRayBumpMtl
  • Added new "local space bump map" mode
VRayMtl
  • The refraction now terminates rays based on the "Max transparency levels" option (it was hard-coded limit previously)
VRayRectLight
  • Added a disk shape option for the rectangle light
VRayTexOCIO
  • Apply the OCIO correction to its output color attribute
ply2vrmesh
  • Introduced -mergeShaders switch to merge shaders from different files with equal names
Bug Fixes
V-Ray
  • Rendering .vrscene files over 4 GB with DR was not working correctly
  • Fixed infinite "Render interrupted" messages when rendering with IPR and no render machines are available
  • Fixed difference in rendering with motion blur, geometry samples > 2 in DR
  • The VRAY_TERMINATE_ON_FRAME_END environment variable now terminates the application properly with exit code 0
  • Improve the precision of mapping for 3D textures
  • Fixed rare crash when computing mip-map levels for non-square textures
  • Missing error when parting vrscene with missing include file
  • OpenSubdiv was not working with color sets
  • OpenSubdiv was crashing when subdividing faces with holes;Fixed random OpenSubdiv results with non-manifold geometry
  • Crash with OpenEXR files using custom data windowFixed UI issues with V-Ray windows on high resolution monitors
  • Support for the "Local" attribute of the place3dTexture
  • Fixed crash with NURBS when rendering with changing FormU/V
  • Fixed texturing with NURBS
  • The ramp texture didn't export proper .vrscene with mixed number/texture positions
  • Running vrend always printed "Error Cannot get the object for the current render layer", even if there is no error
  • Maya's particle "Tail Fade" parameter is not respected when rendering
  • Fixed the "Multi Matte" RE when used with blend material, the two sided material or renderable curves material
  • The Material ID of the base material was ignored when used in VRayMtlWrapper and VRayMtlRenderStats
  • Fixed the -crop option of the stand-alone
  • Fixed incorrect deep images when EXR Compression is None
  • Fixed "Affect Swatches" to not apply gamma when SynColor is on in Maya 2016
  • Fixed an issue with the Bifrost export when using network install
  • Opening a scene with material select render element was crashing sometimes
  • Fixed slow rendering with mb embree hair on Linux
  • Fixed incorrect undo/redo with the "Color Mode" of the V-Ray lights
V-Ray RT
  • The SSS prepass was rendered after the frame is done destroying the image, if the object-based illumination map is used
  • The stereoscopic camera was rendered wrong
  • The "Post Render Frame MEL" was not called, which caused issues with other plugins that are expecting it
  • Fixed slow refreshing with large resolutions
V-Ray RT Viewport
  • Disable writing the output image
  • Disable the gamma correction if running in Viewport 2.0 and the gamma correction there is turned on
  • Fixed registering as a viewport renderer in Maya when the OpenGL core profile is used
V-Ray RT GPU
  • VRayFlakesMtl was rendered black in some cases
  • "Cast shadows" was not working
  • UDIM textures were not transferred for DR when using the GPU
  • Fixed wrong results with textured VRayLights
  • Texture baking could produce incorrect results after a regular render
  • Removed artifacts caused by overlapping faces on VRayProxy objects with motion blur
  • MultiMatte render element was not working when rendering with motion blur
  • Displaced geometry was not included in the light cache
  • Incorrect render result on machines with more than one GPU when Maya Gamma correct node is used
  • The decay rates of the point light was not supported
  • Fixed different results compared to CPU with refraction colours larger than 1.0
  • Fixed darkening in corners when using the light cache with "retrace" option
  • VRayFur didn't render with textures in the material
  • Portal lights blocked shadows from other lights
  • Scenes with very large light cache were rendered slow
  • Subdivision and displacement normals were flipped with negative scaling
  • Unsupported procedural textures were not baked into bitmaps
V-Ray RT GPU CUDA
  • Optimized memory allocation when loading scenes with many textures
VFB
  • Fixed crash if you save a comment with more than 1024 symbols in the VFB history
  • Fixed crash with huge font sizes for the frame stamp
  • The history was not properly refreshed after autosave from IPR
Render Settings
  • Fixed issues with the order of the render element list
  • Light cache didn't add automatically extension to the cache file
VRayMtl
  • Fixed wrong reflection filter render element with GGX BRDF
  • Black Diffuse color broke the Affect Channels for Refractions
VRayFastSSS2
  • Splotches with GI when SSS2 is layered with a reflective BRDF
VRayFlakesMtl
  • Fixed crash in some cases
VRayHairMtl
  • Fixed slow rendering with Transmission Glossiness Length and Width set to 1
VRayLightMtl
  • The "Direct illumination" option didn't work with mapped "Light multiplier"
VRayMeshMaterial
  • Fixed various issues with the shader list update
  • VRayUserColor with UV set names didn't work
  • Fixed crash when a compile error message size exceeds 512
  • GLSL had access only to the first texture map
VRayDistanceTex
  • Fixed artifacs with particular geometry
VRayOSLTex
  • Export a proper uvw generator instead of the default one
VRaySoftBox
  • Wrong rendering when using more then 3 colors in the gradient
VRayDisplacement
  • Displacement was not applied to the entire object when it has multiple shaders assigned
  • Fixed crash with VRay Edges used as displacement and "Show Subtriangles" option is ON
VRayLightMesh
  • Node was not rendered without an assigned material
  • Node was not working with VRayVertexColor
VRayMesh
  • Added velocity multiplier parameter for alembic proxies
  • Fixed a crash when exporting a scene with a lot of objects
  • Selecting both the transform and shape node of an object and exporting to proxy was making a duplicate of all the faces within the proxy file
  • Shape nodes were not correctly numbered when importing multiple proxies
  • Fixed slow OpenSubdiv subdivision with many voxels
  • The proxy import window didn't detect sequences with the <frameNN> token
  • Fixed crash with displacement on proxy that does not have smooth vertex normals
  • Fixed crash with motion blur and VRayVertexColor texture used as a texture for a mesh light based on a proxy
  • Fixed double illumination on SSS material covered by a transparent material when both are applied on the same proxy object
  • Fixed crash with alembic hair when colors are missing and the UVs doesn't match the number of vertices
  • Fixed crash with alembic file if it fails to load normally
  • Fixed slow change of the scene time for static meshes with "Geometry to load" set to "Maya mesh"
VRayToon
  • The texture for the line width was clamped to 1.0 internally causing different results compared to V-Ray 3.0
VRayVolumeGrid
  • the normals render element didn't work with the trunc sampler or probabilistic sampling
  • Incorrect rendering of Maya fluids and VRayVolumeGrid with big step size
  • Fixed incorrect position changes with animated .vdb caches
  • Fixed rendering of speed channel from .f3d/.vdb caches
  • Fixed artifacts with grid-based self-illumination with DR
  • Field3D caches over 4GB were not loaded
Texture Baking
  • Artifacts with baking of large scale scenes
  • Loading the default VRay settings in Maya does not reset the baking engine
  • Ptex baking surfaces with bump maps produced shading artifacts
  • The baking engine controls were not updated when a preset is loaded
XGen
  • Fixed issue when rendering in batch mode XGen collections inside a namespace
  • Fixed render canceling when there is XGen collection in the scene
ply2vrmesh
  • Fixed the velocity channel with json bgeo files
  • Fixed missing error message when a bgeo file fails to load
  • Fixed issues when reading some obj files
vrimg2exr
  • Fixed broken files when converting with data window to 16-bit
OSX
  • Fixed issues with the installer when setting environment variables
  • The vrayRenderer.xml file is installed on wrong location under OSX
  • Fixed the GUI installer mode on OS X 10.11
  • Artifacts from the bucket brackets in VFB on Retina displays
Miscellaneous
  • The "Enable Overrides" Maya attribute from "Drawing Overrides" was ignored
  • Surface luminance node was causing wrong lighting render elements
  • The viewport color attribute of some V-Ray nodes didn't work in Viewport 2.0
  • If Maya is loaded from arbitrary location, clicking the folder icon (browse dialog) of the AE for V-Ray nodes, didn't work
  • Fixed the V-Ray shelf creation issue on some systems caused by XGen
  • Fixed various small issues with the Light Lister
  • Fixed crash with Yeti and velocity render element
  • Fixed rendering issue with Yeti and primary visibility turned off
  • The image plane was rendered even if it is not part of the current render layer
