The .vrmesh files and proxy objects can be created through the vrayCreateProxy command. Using the command with different flags allows you to create, export, import, etc. the proxy.
You can use the vrayCreateProxy command with both MEL and Python. For the purpose of the documentation, the examples below are written in MEL.
Syntax
The various options are described below:
Option | Description |
-createProxyNode | After successful export, replaces the original geometry with proxy nodes. Can also be used along with the -existing option to load an existing proxy file. |
-dir | Specifies the path where the .vrmesh file(s) will be created. |
-existing | Uses existing vrmesh file instead of creating a new one. |
-node | The name for the new proxy node when -createProxyNode is specified, and a single proxy is created. |
-animStart | Override start frame when importing a sequence of files with <frame> filename tag. |
-animLength | Override end frame when importing a sequence of files with <frame> filename tag. |
-objectPath | Starting path in the Alembic object hierarchy when importing .abc files |
-geomToLoad | Type of geometry to load:4 1- None 2 - Bounding Box 3 - Preview
4 - Full geometry |
-flipAxis | Transforms from Max to Maya coordinate system. |
-noMaterial | If specified, does not create a VRayMeshMaterial for the proxy. |
-newProxyNode | Uses the new VRayProxy node instead of the old VRayMesh. |
-animOn | If specified, animated .vrmesh files are created. |
-animType | If -animOn is specified, this option determines the animation interval to export: 1 - playback range 2 - animation range 3 - explicit frame range specified with -startFrame and -endFrame |
-startFrame | Specifies the start animation frame when using explicit range. |
-endFrame | Specifies the end animation frame when using explicit range. |
-exportHierarchy | Exports full paths including transforms and groups instead of just shape names. |
-exportType | Specifies the type of export: 1 - export all selected objects in a single .vrmesh file. 2 - export each selected object in a separate .vrmesh file. |
-fname | Specifies the file name when exporting to multiple .vrmesh files. |
-facesPerVoxel | An integer value that specifies the maximum number of faces that a voxel can hold. |
-oneVoxelPerMesh | If specified, export each separate mesh to a single voxel. |
-ignoreHiddenObjects | If specified, hidden objects are not exported. |
-includeTransformation | If specified and exporting objects in separate files , bake the transformation of each object into the vertex positions in the resulting .vrmesh files. |
-makeBackup | Create a backup .ma file containing just the exported objects. |
-overwrite | If specified, any existing .vrmesh files will be overwritten; otherwise, an error will be printed. |
-previewFaces | Specifies the number of faces in the viewport preview for the proxy object. |
-previewType | The simplification method to use when generating a preview. Must be one of the following: "clustering" "edge_collapse" "face_sampling" "combined" |
-lastSelectedAsPreview | Uses the last selected object as a preview mesh. |
-pointSize | If higher than 0.0, create a point cloud representation of the mesh. The specified value is used as a minimum size of the disk samples. |
-velocityIntervalEnd | A value between 0.0 and 1.0 with the time position within a frame for the ending vertex positions. |
-velocityIntervalStart | A value between 0.0 and 1.0 with the time position within a frame for the initial vertex positions. |
-velocityOn | If specified, vertex velocity is also exported. This enables motion blur and smooth interpolation of the resulting animated proxies. The time samples within a frame for computing the velocity are specified with the -velocityIntervalStart and -velocityIntervalEnd options. |
-vertexColorsOn | If specified, vertex color sets are also exported. |
Examples
Export Mesh Example
The command operates on the current selection and has the following syntax, where curly braces {} denote a choice between several values separated by a pipe |, and options in brackets [] are optional:
Single proxy export:
vrayCreateProxy -exportType {1|2} -previewFaces $previewFaces -dir $path -fname $filename [-makeBackup] [-vertexColorsOn] [-ignoreHiddenObjects] [-includeTransformation] [-oneVoxelPerMesh] [-facesPerVoxel $facesPerVoxel]
Animation export:
vrayCreateProxy -exportType {1|2} -dir $path -fname $filename -animOn -animType {0|1|2} -startFrame $startFrame -endFrame $endFrame -previewFaces $previewFaces [-createProxyNode -node $newNodeName] [-velocityOn -velocityIntervalStart $velocityIntervalStart -velocityIntervalEnd $velocityIntervalEnd] [-previewType $previewType];
Note that $filename has to include the correct extension of the file, that is .abc or .vrmesh.
Import Mesh Example
.vrmesh example:
vrayCreateProxy -node $nodename -existing -dir $path.vrmesh -createProxyNode
alembic example:
vrayCreateProxy -node $nodename -existing -dir $path.abc -createProxyNode
This command creates a proxy node and points it to an existing file (.vrmesh or .abc). Please note that "$path.vrmesh/abc" is the full path of the file. $nodename is the name of the new proxy node.
