This page contains information about the V-Ray Int To Float.
V-Ray Int To Float can be used to convert an integer value to a float value.
UI Path
||mat Network|| > V-Ray > Texture: Utility > V-Ray Int To Float
Node
The V-Ray TexIntToFloat node provides inputs that correspond to the parameters in the section below.
Int – Specifies the integer value.
