« Previous Version 3 Next »
This page provides information about the Emissive material in V-Ray for Rhino.
The Generic V-Ray material's preset Emissive is generally used for producing self-illuminated surfaces.
UI Options
The Emissive material settings are organized in Basic and Advanced modes. You can switch the mode from the toggle button under the Preview Swatch or globally from the Configuration rollout of the Settings tab.
From the Add Attribute button, you can select additional attributes that can add up to the appearance of the material. For more information, see the Attributes section.
An Add Layer button is provided for some V-Ray materials, including Emissive. You can select an additional layer that can add up to the appearance of the material. For more information, see the Layers section on Materials page.
The Emissive material itself can be created by adding Emmisive layer.
Holding down Ctrl (or Cmd on macOS) while having the Add Attribute or Add Layer menu open, allows selecting multiple entries without closing the dropdown.
The context menu of the Color slot provides options to Copy and Paste, as well as to Reset the color.
A Reset option is provided in the context menu of each Number Slider. You can reset the slider value to the default one.
Emissive
Some options are available only in Advanced mode.
Color – Specifies the color of the light. A texture can be specified as well. For more information, see the Textures example below.
Intensity – Controls the strength of the light.
Transparency – Specifies the color that is transparent. A texture can be specified as well.
Emit On Back Side – When enabled, the object emits light from its back side as well. When disabled, only the front side emits light, and the material renders as black on the back sides. For more information, see the Higher Multiplier/2-Sided On and Off example below.
Compensate EV – Used when rendering with the V-Ray Physical Camera. When enabled, the intensity of the material is adjusted to compensate for the camera exposure.
Color *Opacity – When enabled, the color of the light material is multiplied by the opacity texture. Otherwise, the color and opacity act independently (so-called additive transparency).
Multipliers
This rollout is available only in Advanced mode.
Mode – Specifies one of the following methods for adjusting textures.
Multiply – Multipliers can be specified to adjust colors and textures.
Blend Amount – Blend amounts can be specified to adjust colors and textures.
Color – Controls the intensity of the Emissive Color (light color). See the Default Color and Multiplier Values example
Transparency – Controls the intensity of the Transparency Color, which determines the color that is transparent.
Example: Textures
This example shows using the BRDFLight with a texture in the Color slot. In order to control the strength of the light we will need to adjust the Value of the Color Multiplier parameter in the Color Balance roll out of the texture.
Color Multiplier: 3.0
GI on ;
Emit on Back Side on
Using a File texture connected to the Color slot. The Color Multiplier is quite low, so only the plane and the reflection on the teapot are visible.
Color Multiplier: 15.0
GI on ;
Increasing the Color Multiplier leads to a much lighter overlook of the scene. Notice that now the texture is getting closer to white color look, due to multiplying the (R,G,B) values of the texture.
GI on ;
  Here is another File texture connected to the Color slot. Notice that we haven't changed the VRayMtls for the surrounding walls, but the scene looks different from the previous one due to the new texture.
GI on ;
Increasing the Color Multiplier leads to a much lighter overlook of the scene. Notice now that the texture is getting closer to white color look, due to multiplying the (R,G,B) values of the texture.
Example: Default Color and Multiplier Values
Here is a scene rendered with the default BRDFLight. These examples demonstrate how the material behaves in V-Ray, and how its parameters influence the overlook of the final results.
The white plane is a default BRDFLight. The teapot is a default VRayMtl with Reflection. Rest is just VRayMtl with diffuse colors.
We are going to render this scene with Default Lights - Off till the end of the example and no lights will be used in it as well.
Color value: 1.0
No GI
As you see the image is absolutely dark except the plane (self-illuminated) and the reflection on the teapot. Notice we have no GI and no lights at all here, so the dark part of the scene is totally expected and reasonable.
Color value: 50.0
No GI
Notice that nothing changed in general, BUT the reflection on the teapot got stronger due to the higher color value. Rest is still black: because we still have the GI off.
Color value: 1.0
GI on
As You see turning GI on almost didn't change the overlook. That is because of the Color value: 1.0. It acts mainly as just self-illuminating the object that has the BRDFLight.
Example: Higher Multipliers/2-Sided On and Off
Color value: 5.0
GI on
Emit on Back Side off
Now you can notice that increasing the Color value has influenced visibly the scene (shadows also appear).
Color value: 5.0
GI on
Scene starting to gather more light because of the 2-sided - on.
Color value: 15.0
GI on
As you see the back is still dark, but You can already notice the blue wall receiving some GI, due to higher Color value. Shadows also appear more defined.
Color value: 15.0
GI on
Binding
Texture – Selected Bitmap texture is displayed in the viewport and it overrides all other material parameters. The viewport texture does not affect the way the material is rendered with V-Ray. It is mainly used for preview purposes.
Keep in mind that procedural textures are not shown in the viewport, however, any Bitmap textures, including ones nested in procedurals, will be automatically displayed.
Override Control
Can be Overridden – When enabled, the material can be overridden by the Material Override option in the Settings.
Attributes
The attributes from the following expandable menus are available for the Emissive material.
Translucency
Back Material– Defines the material V-Ray uses for back side faces as defined by their normals.
Translucency – Determines if the front or the back side of the material is more visible in the rendering process. By default this value is 0.5, which means that both sides are equally visible. When this parameter is closer to zero, the material facing the camera is more visible, when it is closer to one, the back material is more visible. A texture can be used to control the variation of the effect.
Mult. by Front Diffuse – When enabled, the translucency is multiplied by the diffuse of the front material.
Bump
This option gives the ability to add bump map and normal map effects when using any material.
Bump/ Normal Mapping – Enables or disables the bump or normal effect.
Mode/Map – Specifies the bump map type.
Bump Map – A height map should be used.
Bump Texture Channel – It is most commonly used for Round Edges effect. Edges texture is used as a bump.
Normal map – RGB map should be used with this option. If a Bitmap texture is slotted its color space must be set to Rendering Space (Linear).
Normal Map Type – This option is available only when the Mode is set to Normal Map. It specifies the space for the Normal Map.
Tangent Space – Uses tangents set to each individual face.
Object Space – Uses each object's local coordinates.
Screen Space – Uses a flat projection along the camera direction.
World Space – Uses world coordinates.
Amount – Multiplier for the bump/normal map.
Delta Scale It specifies a scale for sampling the bitmap when Bump Map is selected. The exact value is calculated automatically by V-Ray, but can be changed here.
Dispacement
This is a legacy attribute that will be removed in the future. Consider using the geometry displacement modifier instead. It can be created as a geometry asset in the Outliner and can be applied to objects in the scene. Note that the displacement effect will no longer appear in the Preview Swatch.
Displacement1 – Enables or disables the displacement effect.
Mode/ Map2 – Specifies the mode in which the displacement is rendered.
2D Displacement – Bases the displacement on a texture map that is known in advanced. The displaced surface is rendered as a warped height-field based on that texture map. The actual raytracing of the displaced surface is done in texture space and the result is mapped back into 3D space. The advantage of this method is that it preserves all details in the displacement map. However, it requires the object to have valid texture coordinates. You cannot use this method for 3d procedural textures or other textures that use object or world coordinates. The parameter can take any values.
Normal Displacement – Takes the original surface geometry and subdivides its triangles into smaller sub-triangles, which then are displaced.
Shift – Specifies a constant, which is added to the displacement map values, effectively shifting the displaced surface up and down along the normals. This can be either positive or negative.
Keep continuity – When enabled, tries to produce a connected surface, without splits, when there are faces from different smoothing groups and/or material IDs. Note that using material IDs is not a very good way to combine displacement maps since V-Ray cannot always guarantee the surface continuity. Use other methods (vertex colors, masks etc.) to blend different displacement maps.
Resolution – This option is available when the Mode/Map is 2D Displacement. It determines the resolution of the displacement texture used by V-Ray. If the texture is a bitmap, it is recommended to match this resolution to the size of the bitmap. For procedural 2D maps, the resolution is determined by the desired quality and detail in the displacement. Note that V-Ray also automatically generates a normal map based on the displacement map in order to compensate for details not captured by the actual displaced surface.
View dependent – When enabled, Edge length determines the maximum length of a subtriangle edge in pixels. A value of 1.0 means that the longest edge of each subtriangle is about one pixel long when projected on the screen. When disabled, Edge length is the maximum sub-triangle edge length in world units.
Edge length – Determines the quality of the displacement. Each triangle of the original mesh is subdivided into a number of subtriangles. More subtriangles mean more detail in the displacement, slower rendering times and more RAM usage. Less subtriangles mean less detail, faster rendering and less RAM. The meaning of Edge length depends on the View dependent parameter. The slider's minimum range is set to 0.4. Using lower values is still possible by manually typing them in the input box but it may cause significant render delay.
Max subdivs – Controls the maximum sub-triangles generated from any triangle of the original mesh when the displacement type is Subdivision. The value is in fact the square root of the maximum number of subtriangles. For example, a value of 256 means that at most 256 x 256 = 65536 subtriangles will be generated for any given original triangle. It is not a good idea to keep this value very high. If you need to use higher values, it will be better to tessellate the original mesh itself into smaller triangles instead. The actual subdivisions for a triangle are rounded up to the nearest power of two (this makes it easier to avoid gaps because of different tessellation on neighboring triangles).
Water Level – Clips the surface geometry in places where the displacement map value is below the specified threshold. This can be used for clip mapping a displacement map value below which geometry will be clipped.
Level Height – Value below which the geometry is clipped.
Materials need to be applied to objects (groups/components) to have working displacement. If various materials are applied to different faces of an object, the displacement from the top-level (group/component) material will be used on all of them. Normal Displacement will take into account the texture size of each different face material, while 2D Displacement will ignore them.
Raytrace Properties
Visible to Reflections – When enabled, this option makes objects using this material visible for to Reflection rays.
Visible to Refractions – When enabled, this option makes objects using this material visible for the Refraction rays.
Override
Shadows – The material that is used when a shadow ray hits the surface.
Reflection – The material that is used when a reflection ray hits the surface.
Refraction– The material that is used when a refraction ray hits the surface.
GI – The material that is used when a GI ray hits the surface.
Environment – The texture that will be used instead of the scene environment maps.
Material ID
ID Number – Isolates objects as an R/G/B mask in the MultiMatte render elements.
ID Color – Allows you to specify a color to represent this material in the Material ID VFB render element.
Each material is assigned with an automatically generated ID Color.
  • You can use the BRDFLight as a light source assigned to an object. Increasing the Value of the color will affect the GI solution and will produce more light. Note that overbright colors may look the same as pure white but the GI results will be different.
  • If you know the photometric power of a self-illuminated object in lumens (e.g. 1700 lm for a 100-watt bulb) you can calculate the multiplier for BRDFLight if you divide the lumens by the surface area of the object in meters, provided that the self-illuminated color is pure white.
  • The direct illumination options currently only work properly if the BRDFLight material is the only material applied on the object. They will not work if the material is part of a complex material like a VRayBlendMtl material. This restriction will probably be removed in a future release.
