Windows
Please make sure that your system fulfills these requirements before installing V-Ray. For additional information on hardware, see the Hardware Recommendations article.
Processor | 1st Gen Intel® Core™ or compatible processor with SSE4.2 support (x64). |
RAM | 4 GB RAM and 4 GB swap minimum – recommended 8 GB or more RAM, 8 GB or more swap file. |
Hard Disk Space | Minimum 2GB, Recommended 12GB (includes additional downloadable content) |
TCP/IP | Only IPv4 is supported. IPv6 is currently not supported. |
Supported GPU | Maxwell-, Pascal-, Volta-, and Turing-based NVIDIA card(s) with with latest recommended video driver or at least version 441.20; NVIDIA RTX: RTX cards with latest recommended video driver or at least version 441.28; V-Ray Vision requires a Graphic card with DirectX 11 or DirectX 12 and Shader Model 5.0 capabilities |
The following table shows the versions of Rhinoceros 3D and the operating systems on which V-Ray is supported. Note that V-Ray is only supported for 64-bit operating systems and 64-bit versions of Rhino.
Version of Rhino | Supported Operating System |
Rhino 6 (v6.29.20238 or later) | Windows 8.1 and Windows 10 Professional |
Rhino 7 (7.0.20314 or later) | Windows 8.1 and Windows 10 Professional |
Support is available only for V-Ray 5 and V-Ray Next (V-Ray 4). Earlier versions are no longer supported.
