« Previous Version 8 Next »
  • In order to produce correct Render Elements for Fire/Smoke simulations, the Phoenix FD Simulator needs Render Mode to be set to Volumetric Geometry with V-Ray Next and V-Ray 3.
  • In order to produce correct Render Elements, the Particle Shader needs Render as Geometry to be enabled with V-Ray Next and V-Ray 3.
  • Please note that Particle Shader rendering is currently not supported with V-Ray GPU.
  • Keep in mind that V-Ray Next or V-Ray 3 Adv. CPU produce correct results with Progressive sampler for Render Elements only when Enable Filtering is on.
  • Rendering of Fire/Smoke elements with V-Ray Next GPU requires Phoenix FD 3.12 and V-Ray Next update 1 nightly 28798 (18th December 2018) builds or newer.
List of Supported V-Ray Render Elements
Render Element
V-Ray Next/V-Ray 3 Adv
Volumetric
Volumetric Geometry
V-Ray GPU Next
Volumetric
V-Ray GPU Next
Volumetric Geometry
Particle Shader
Particle Shader:
Render as Geometry
Description / Additional Notes
Multi Matte
Creates selection masks based on object G-buffer ID or material ID.
Atmospheric Effects
Gives Fire + Smoke
Background
Image background, such as any Background Texture specified in the Environment overrides.
BumpNormals
The normals generated by bump maps, in screen space (which is not the same as camera space). Use the VRaySamplerInfo render element to get the normals in camera, world or object space.
Caustics
The caustics on the material. These caustics are present only when the Caustics option of V-Ray is enabled. This channel does not include GI caustics.
CryptomatteBucket Sampler
only
Bucket Sampler
only
Bucket Sampler
only
Bucket Sampler
only
Uses the Cryptomatte convention by Psypop to encode mattes into multichannel OpenEXRs.
Denoiser
Applies a denoising operation to the image after it is rendered (with the neccessary channels).
Diffuse
The pure diffuse surface color. Note that this is different from the standard 3ds Max Diffuse render element, which contains the diffuse surface lighting.
Extra TexRenders the entire scene with one texture mapped on all objects.
GI
(when Use Light Cache is disabled)
The diffuse surface global illumination. Only present if Global illumination is enabled.
Lighting
The diffuse direct surface lighting.
Lighting AnalysisProvides visual representation of the lighting intensity within a rendered frame.
Light Select
(since V-Ray Next, update 3)
Extracts the contribution of a user-defined light or a set of lights in the scene as a separate render element.
Matte ShadowNot AvailableNot AvailableThe matte shadow part of the image.
Material ID
Material ID of scene objects.
Material Select
Not Available
Not Available
Renders only the object(s) assigned to a user-specified V-Ray compatible material. The material can be a top-level material or a sub-material of a VRayBlendMtl.
Normals
The surface normals in screen space (which is not the same as camera space). To output the normals in camera/object/world space, use VRaySamplerInfo render element.
Object ID
The object G-buffer ID (set through the node's Properties dialogue).
Object SelectNot AvailableNot Available
Stores only the object(s) called out with a specific Object or Material ID.
Raw Diffuse FilterNot AvailableNot AvailableA solid mask of raw diffuse surface color information not affected by fresnel falloff.
Raw GI
Raw diffuse global illumination (not multiplied by the diffuse surface color). Only present if Global illumination is enabled.
Raw Light
The raw diffuse direct illumination before it's multiplied by the diffuse surface color.
Raw Reflection
The pure surface reflection, before it is multiplied by the reflection filter color.
Raw Refraction
The pure surface refraction before it is multiplied by the refraction filter color.
Raw ShadowNot AvailableNot Available
The raw light that was blocked by other objects.
Raw Total LightNot AvailableNot AvailableThe sum of all raw lighting - direct and indirect.
Reflection
The reflections on the surface.
Refraction
The refractions on the surface.
Render IDThe node render ID of the object that contributes most to the pixel value.
Sample RateShows an image where the pixel brightness is directly proportional to the number of samples taken at this pixel.
Sampler Info
Provides information about various aspects of the shaded points - position, normal, bump normal, reflection/refraction vectors and UVW coordinates. Can be used f.e. for world position passes or normal passes.
Using V-Ray Next or V-Ray 3 Adv. CPU - this Render Element will work correctly only with Bucket sampler and Enable Filtering is off.
Self Illumination
The self-illumination of the surface.
ShadowThe diffuse light that was blocked by other objects.
Specular
The surface specular highlights. Specular should hold direct illumination - illumination from the fire comes as GI so result here should be correct: the element is not affected by the Fire.
Total LightNot AvailableNot AvailableThe total lighting in the scene, direct and indirect.
Unclamped ColorThe unclamped image color.
VelocityThe surface velocity. This channel will not be generated if 3d motion blur is enabled.
ZDepth
The z-depth of the surface.
