This page provides information about the Object ID Render Element in V-Ray for Cinema 4D.
Two or more objects in the scene can share the same Object ID.
The Object ID Render Element creates selection masks based on Object ID that shows each object (by Object ID) in a solid unshaded color.
UI Path: ||V-Ray|| > Render Elements > Object ID
Properties
Enable Deep Output – When enabled, the render channel is rendered in the V-Ray Virtual Frame Buffer.
