This shader can be used to render materials with complex index of refraction. The regular VRayMtl material can compute the Fresnel effect for dielectric materials like plastic and glass based on the refractive index of the material; however metals have a more complicated Fresnel reflective curve that depends also on another parameter called extinction coefficient.
The shader is used as a reflection color map in a VRayMtl material with the VRayOSLTex texture, with the Fresnel option of the V-Ray material turned off (this shader does its own Fresnel calculations).
The site http://refractiveindex.info/ has the measured n and k values for many materials like copper, gold etc.
The shader file can be found here: complex_ior.zip
n - the n values for the red/green/blue wavelengths (f.e. 0.65, 0.55 and 0.45 micrometers).
k - the k values for the red/green/blue wavelengths
Shader code
The shader code is below.
float fresnel(float n, float k, float c) { float k2=k*k; float rs_num = n*n + k2 - 2*n*c + c*c; float rs_den = n*n + k2 + 2*n*c + c*c; float rs = rs_num/ rs_den ; float rp_num = (n*n + k2)*c*c - 2*n*c + 1; float rp_den = (n*n + k2)*c*c + 2*n*c + 1; float rp = rp_num/ rp_den ; return clamp(0.5*( rs+rp ), 0.0, 1.0); } shader complex_ior ( vector n=vector(0.27105, 0.67693, 1.3164) [[ string description = "Refractive index for red, green, blue wavelengths (f.e. for 0.65, 0.55, 0.45 micrometers)" ]], vector k=vector(3.6092, 2.6247, 2.2921) [[ string description = "Extinction coefficient for red, green, blue wavelengths (f.e. for 0.65, 0.55, 0.45 micrometers)" ]], output color Col_Out = color(0.5) ) { float thetaCos = abs(dot(-I,N)); float red=fresnel(n[0], k[0], thetaCos); float green=fresnel(n[1], k[1], thetaCos); float blue=fresnel(n[2], k[2], thetaCos); Col_Out=color(red, green, blue); }
