This page provides information about the Raw Refraction Render Element in V-Ray for Cinema 4D.
In comparison, the Refraction Filter Render Element is a render element that indicates varying degrees of refraction in the scene, through brightness values in the image. Multiplying these two render elements together produces the Refraction Render Element.
Note: To properly calculate the Raw Refraction Render Element, the Refraction Render Element must also be added to the list of render elements being calculated during the rendering process to properly determine all the refraction information in the scene.
UI Path: ||V-Ray|| > Render Elements > Raw Refraction
Properties
Enable Deep Output – Specifies whether to include this render element in deep images.
Color Mapping – Applies the color mapping options specified in the Color mapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default.
Consider for Aa – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections – Applies the post render color adjustments made from the VFB.
