« Previous Version 2 Next »
This page contains information about Phoenix FD textures.
Phoenix FD provides several textures for use in simulations and rendering.
Grid Textures
Grid textures rely on the grid to generate a texture.
  • Grid Texture - Generates a procedural texture from a simulator grid for use in shading the simulation.
  • Grid Texture 2D - A simplified version of the Grid Texture.
Water Textures
Water textures are used with water effects to make them look more realistic.
  • Ocean Texture - A realistic, non-cyclic procedural texture for representing an ocean surface.
You can also use a Particle Shader to shade foam.
Particle Texture
Phoenix FD can generate WetMap particles that can be used along with the Particle Texture to emulate wet surfaces.
  • Particle Texture - A texture generated from a particle system by blending between sub-maps connected to each particle.
