This page provides information about the Combine Color node in V-Ray for Cinema 4D.
Color – Specifies a custom color that multiplies the texture connected.
Texture – Specifies a texture that will be combined with the color.
Mix Strength – Specifies a multiplier used to blend between the color and the texture.
Result Invert – When enabled, inverts the result of the blending effect.
Result Multiplier – Specifies a multiplier for the result. If Result Invert is enabled, this is performed after the inversion.
